Old 12-25-2011, 01:31 AM   #16
narcotiks's Avatar
oh and no it was still working just extremely hot to the touch. it was my fault that little thing came off because i took out and inserted the rotor the wrong way
narcotiks is offline   Reply With Quote
Old 12-25-2011, 10:15 AM   #17
Most electronic components are installed writing side up. Short of that I think that under a magnifying glass you would be able to match up the broken edges to see which way it was installed. The small sensor components are easy to damage from the heat when soldering. A micro sized tip on the soldering iron and quick touch to the leg of component to be soldered to minimize heat soak.
Pete Hauser
luckyhomes is offline   Reply With Quote
wheels wobble but they dont fall down rpmdj1 Electric Off-Road 15 06-16-2012 11:34 PM
B.R.C.C.C (Tingalpa) hooked_on Australian Racing 6962 11-07-2011 01:58 AM
grip enemy RC DRIFT BATTLE 2010 @ RCP Fas N furious Malaysian R/C Racers 21 02-10-2010 07:40 PM
SEO by vBSEO 3.5.0
