Old 12-16-2011, 09:11 AM   #1
vti-chris's Avatar
Default Pinion gear for T3 drift?
What pinion gear should i use for the Xray T3 11' pro when i use 19t motor?
7.4v lipo battery!
Axial XR10
Sakura Zero S/Castlecreations
vti-chris is offline   Reply With Quote
Old 12-16-2011, 11:31 PM   #2
WheelNut's Avatar
Send a message via MSN to WheelNut
It depends on the size of area you are running in. You shouldn't have to be too picky with gear ratios when drifting because the motor isn't under a lot of stress. If you don't have a pinion collection already you could pick up an RRP pinion starter pack. Otherwise, just start conservatively (20t) and work your way up depending on how much wheel speed you need.
•Brad Comis
WheelNut is offline   Reply With Quote
XRAY T3 mario Electric On-Road 3480 05-30-2014 07:42 AM
SEO by vBSEO 3.5.0
