Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-09-2002, 02:48 PM   #1
Default Ko Ps2174
would this be a good servo for indoor carpet racing? it is 171oz@.13sec i was going to get a couple for my pro3 and tc3. open to other suggestions too. thanks
Jarrod Langlois is offline   Reply With Quote
Old 06-09-2002, 04:30 PM   #2
rccarracer's Avatar
I've had this servo for some time in my 414M and Yok Special, but since changing to the 2173, I wouldn't use the 2174. The 2173 is quicker and has plenty of power for touring.
The 2173 is the servo of choice of most KO sponsered and non sponsered touring drivers!!
rccarracer is offline   Reply With Quote
Old 06-09-2002, 05:33 PM   #3
ok thanks ill check it out
Old 06-09-2002, 08:38 PM   #4
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
Im using the KO 2174 servo for asphalt touring in kod and find it drains a bit too much power and on the last lap if low on power the car gets a delayed steering action. Adding a bigger capacitor may help. Its still a really good servo but too much torque for touring. 2173 is the choice servo.
Oasis2001 is offline   Reply With Quote
Old 06-09-2002, 09:00 PM   #5
Regional Moderator
R/C Tech Charter Subscriber
i would go with the ko 2173 i have used this servo
for a good while and its the best i have used .
i wouldnt buy anything but a ko !
it will work for asphalt or carpet track.
Ko Racer is offline   Reply With Quote
Old 06-09-2002, 10:56 PM   #6
rccarracer's Avatar
Yep, I wouldn't have anything but KO!!
The 2173 is the way to go for Touring.
Old 06-10-2002, 12:19 AM   #7
Trips's Avatar
Trader Rating: 16 (100%+)
No one using the 2143 digital from KO? I'm wondering what advantage the 2173 might have over it if any?
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 06-10-2002, 12:35 AM   #8
Shop Owner
nnick's Avatar
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
I would propose the 2143 or 2123. Both are digitals and very fast!
2143 0.08, 2123 0,06 but with fet (extra cable). I have them both and never regreted it!
Ko is the way!!
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
nnick is online now   Reply With Quote
Old 06-10-2002, 12:36 AM   #9
Shop Owner
nnick's Avatar
Default technical specs for the KO servos
PS-2173 FET Power Servo
#30015
High Speed Analogue Type Metal Gears 54.5g 38x41x20mm
Torque / 8.0kg-cm Speed / 0.09s / 60° Double Bearings, Coreless Motor
Supply Voltage 6.0V
PS-2174 FET Power Servo
#30016
High Torque Analogue Type Metal Gears 54.5g 38x41x20mm
Torque / 12.0kg-cm Speed / 0.13s / 60° Double Bearings, Coreless Motor
Supply Voltage 6.0V
PDS-2123 FET Power Digital Servo
#30021
High Speed Digital Type Metal Gears 55.0g 38x41x20mm
Torque / 9.5kg-cm Speed / 0.06s / 60° Double Bearings, Coreless Motor
Supply Voltage 7.2V
PDS-2143 FET Power Digital Servo
#30022
High Speed Digital Type Metal Gears 54.5.0g 38x41x20mm
Torque / 8.0kg-cm Speed / 0.08s / 60° Double Bearings, Coreless Motor
Supply Voltage 6.0V
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 06-10-2002, 10:31 AM   #10
psycho's Avatar
I run 2143's in all of my cars. They're not cheap, but once you use one, you won't use any other steering servo.
psycho is offline   Reply With Quote
Old 06-10-2002, 10:32 AM   #11
ok thanks guys i think i am going to go with the 2173 that seems to be the servo of choice for most, i looked at the 2143 they seem almost equal besides being digital butthe 2173 is 20 buck cheaper and im going to be getting two of them so ill just get the 2173 and save about 40 bucks.
Forum Jump
Powered By: vBulletin v3.7.6
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
