Pinion gear for T3 drift? >
Old 12-16-2011, 09:11 AM
vti-chris's Avatar
Default Pinion gear for T3 drift?
What pinion gear should i use for the Xray T3 11' pro when i use 19t motor?
7.4v lipo battery!
vti-chris is offline
Old 12-16-2011, 11:31 PM
WheelNut's Avatar
It depends on the size of area you are running in. You shouldn't have to be too picky with gear ratios when drifting because the motor isn't under a lot of stress. If you don't have a pinion collection already you could pick up an RRP pinion starter pack. Otherwise, just start conservatively (20t) and work your way up depending on how much wheel speed you need.
WheelNut is offline
