Like Tree1Likes
Old 01-19-2015, 06:50 AM   #1351
Mike, any idea when we might expect the servo saver plate and the machined front damper tubes to be available?
...now I see the damper tubes for 1st week of Feb, still wondering on the plate... maybe around the same time as they're "in production"?
Last edited by kineteks; 01-19-2015 at 09:17 AM. Reason: need to read posts more carefully
kineteks is offline   Reply With Quote
Old 01-19-2015, 08:18 AM   #1352
NutDriver's Avatar
Trader Rating: 14 (100%+)
I'm pretty sure Mike said February 1st for the new front end parts. Might want tout go back a page or two to see if I'm right.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is online now   Reply With Quote
Old 01-19-2015, 10:24 AM   #1353
MikeR's Avatar
Originally Posted by gary47 View Post
Is there set upsheet you can down load with Exotek new front end?
Not that I know of. My 'to do' list is about 3 pages long so cannot make a custom pdf doc at this time.
Are there any skilled pdf set up sheet makers our there for hire
Yes should be first week of Feb for both. Note the servo plate is for the xray servo saver only. My experience is that the Tamiya servo saver is too soft.
Originally Posted by charl View Post
Anyone know the standard caster angle of the 104?
Just got the adj upper arms and they don't seem to be able to adjust much more than the kit standard setting?
The Exotek adjustable arms will easily surpass any angles of the stock 104 arms if built correctly. Do you have a pic of your assembly?
Originally Posted by kerry View Post
Thanks Aaron
Front of car = 4mm ride height, 8 deg castor, 1.5 camber, 1 deg toe out, stiff front springs ( kit) .5mm of droop as per instructions
Short wheel base, center shock will be 30wt I believe, 1mm pod droop, side springs associated white, thick crc lube in damper tubes, center shock location towards the rear of the chassis ( back hole )
Hi,
Too much caster will jack the car over and cause the inside wheels to lift. 5 is what I'd be at.
What front lube are you using? But make sure you have enough lube in the front damper to slow down the front suspension and try the outer hole on the front tower.
I'm not sure if you have tried it but a lot of carpet guys (Tamiya cars) are using the f103 diff thrust washer with tamiya awg grease to prevent 'diffing' on carpet.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-19-2015, 10:36 AM   #1354
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Very positive testing with the IFS yesterday on the F1R2, really effortless to drive and less "on the edge" feel of normal F1 cars. Looking forward to the machined damper tubes so we don't have to run crazy thick lube.
Dan is offline   Reply With Quote
Old 01-19-2015, 03:59 PM   #1355
wheelz's Avatar
It's not fancy but Ive attached PDF's of my setup for the IFS. Let me know If I missed something or something else that needs to be on there and I can add it as we go
Aaron
Aaron Lane
Team Associated | Reedy | Jconcepts | Exotek Racing | Airtronics l OCRC l Sticky Kicks l
B6 | B64 | F6 l TC7.1
AE Design Engineer
wheelz is offline   Reply With Quote
Old 01-19-2015, 09:13 PM   #1356
MikeR's Avatar
Thanks Aaron! You are an alright guy
Old 01-19-2015, 10:37 PM   #1357
Trader Rating: 19 (100%+)
That's awesome Aaron.
May be asking a lot of you but do you by chance have something similar for the exotek F1R2 rear end too?
Thanks again.
bee200sx is offline   Reply With Quote
Old 01-19-2015, 10:42 PM   #1358
wheelz's Avatar
Thanks again.
I don't have anything for the rest of the car yet but I can make something similar like this during the week and post it up for everyone
Aaron Lane
AE Design Engineer
Old 01-19-2015, 10:43 PM   #1359
Awesome man!
That would be great. I am sure everyone will appreciate it.
Old 01-20-2015, 07:16 AM   #1360
tudor_47's Avatar
Been reading about the new front end...
i've got an F1R and getting the itch to mount the new front end in it...
wonder will it be possible to run normal 2 cell touring LiPo after the new front end?
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 01-20-2015, 08:52 AM   #1361
Dan
Dan's Avatar
You can but you need to purchase the side winglets to mount the ESC/RX.
Old 01-20-2015, 11:51 AM   #1362
wheelz's Avatar
hold on... the rear section is messed up lol revising now
Aaron Lane
AE Design Engineer
Old 01-20-2015, 12:04 PM   #1363
wheelz's Avatar
here is the revised blank setup sheet... sorry
Aaron Lane
AE Design Engineer
Old 01-20-2015, 12:52 PM   #1364
aussierevo's Avatar
thanks Aaron for these. I pushed the button on the F1R2 and IFS yesterday so all this setup information will be very handy in the coming weeks.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 01-20-2015, 05:28 PM   #1365
That is awesome Aaron, thanks a million mate. It looks great.
Sorry if this is too much to ask of you but would you mind posting your setup?
Or Mike any chance of getting your setup too using Aaron's setup sheet.
Thanks guys.
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
