Old 01-01-2015, 09:16 PM   #1306
JayL's Avatar
Thanks Mike, i'm gonna run 1mm under and 4mm on top.
Aaron or Mike: What size(thickness) shim are you running under the xray saver?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 01-01-2015, 10:35 PM   #1307
MikeR's Avatar
Trader Rating: 14 (100%+)
I'm using 3mm. We both actually made custom plates that acts as 3mm spacers but also bolt onto the servo saver and lengthened the arm by about 8mm to help reduce the ackerman for more aggressive mid corner steering.
Something I might release later to get rid of that dreaded mid corner push these f1 cars seem to have on asphalt
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-02-2015, 02:37 AM   #1308
Awesome thanks. I will have to try using tires some day
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 01-02-2015, 09:12 AM   #1309
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
Originally Posted by MikeR View Post
Hi,
3mm is a lot of deflection and really not possible I think. Are you sure you meant .3mm movement? Mine have some play but no issue really. It is the tolerance needed so that metal thread can screw into metal thread.
Hi Mike.
Just an idea: do you, or the company that anodize your parts protect the threads? This might cause the problem Monkey is reffering. Machined M3 thread doesnt have such play.
(edit)
Problem might be of course in the turnbuckle as well. Easiest Monkey can do is to measure the outer diameter of turnbuckle.
(/edit)
"If you no longer go for a gap that exists, you're no longer a racing driver"
Ayrton Senna
Acid_CZ is offline   Reply With Quote
Old 01-06-2015, 05:08 AM   #1310
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Had my first run with the IFS this evening and overall impressions are very positive. Generally, the whole front end is much more progressive and predictable which has made the car easier to drive.
My first learning is that the inner camber link ball studs I used were too short and one popped out after a relatively minor hit. I then replaced both of them with 8mm ones (see picture).
However, I'm finding rear grip a bit of a problem with my F1R2 (even before the IFS), so I'm looking for suggestions. My current choice of centre springs is limited, so I'm running a Tamiya red (white with the red dot) which is probably the softest I have. On-power steering isn't too bad, but it pushes quite badly off power. I have quite a lot of pod droop, most likely too much, but I'll need to put an o-ring in the damper to reduce it any more. That may sound like the rear isn't too bad, but that's with Ride S1's up front and Shimizu 575's at the back. With anything grippier on the front, it spins very easily. It's also very difficult to get power down out of corners as the rear squirms very badly.
I've attached some photos - silver side springs, 450 weight oil in the centre damper, 100k oil in the side damper tubes. The pod movement is smooth and seems quite heavily damped. Despite appearances, the wiring is loose and flexible.
I'm no expert, but the diff seems smooth and only slips under quite firm hand pressure.
The tracks I race on are almost always low-medium grip outdoor asphalt.
Phil.
Exotek F1R-ballstuds.jpg   Exotek F1R-img_0188.jpg   Exotek F1R-img_0190.jpg   Exotek F1R-img_0191.jpg
T4 | X1 | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 01-06-2015, 05:25 AM   #1311
I would say your damper tube grease is waay too thick. I operate in the 10k to 30k range.
Try a neon red center spring, a little less Pod droop, and what rear axle are you running? Cf or steel? Also try Associates black side springs or tamiya coppers.
Hope this helps the rear.
X-ray T4'16 stock TC, Xray T4'15 mod sedan, Xray xb4. Xray, Motiv, Team debit card.
Boostinswifty38 is offline   Reply With Quote
Old 01-06-2015, 06:54 AM   #1312
The tracks I race on are almosAnt always low-medium grip outdoor asphalt.
Phil.
For rear grip I would reduce your rear droop to 2mm by reducing the shock length (not with o rings in the shock). There should be plenty of thread to do this if you relocate the ball end on the battery brace to the forward hole instead of the rearward one as you have it curretly. Looks like you must have the standard length trf shock not the mini trf shock hence you've run out of thread.
I'd also move your battery to the back and rewire your esc to be infront of your battery.
damper tube grease should be closer to 10k not 100k.
shock oil should be a bit thinner. Probably close to 300-400cst with a 3 hole shock piston.
With the IFS I would assume rear grip is more the priority. There should be plenty of front grip.
J-PaP is offline   Reply With Quote
Old 01-06-2015, 08:09 AM   #1313
monkeyracing.cz's Avatar
(Hi,
There was play bending up and down 3mm in total for real. Next day, when thread lock get completly solid, connection looks solid. Lets see after some driving if it last.
www.monkeyracing.cz | www.rallybrno.cz
monkeyracing.cz is offline   Reply With Quote
Old 01-06-2015, 09:03 AM   #1314
Acid_CZ's Avatar
just curious, what turnbuckles do you use in that loose connection? Material and brand.
Ayrton Senna
Old 01-06-2015, 09:39 AM   #1315
Turnbuckles are included in the kit and they are made of some kind of aluminium alloy I guess.
Old 01-06-2015, 12:37 PM   #1316
wheelz's Avatar
Phil.
Dang... J-pap and Boostinswifty38 beat me to it!!! there advice is exactly what i would have suggested
Aaron
Aaron Lane
Team Associated | Exotek | AKA | LRP | Airtronics l OCRC l Sticky Kicks l
B5m | B44.3 | Exotek F1R3 l TC7
wheelz is offline   Reply With Quote
Old 01-06-2015, 03:06 PM   #1317
PDR
PDR's Avatar
Thanks for the advice guys, much appreciated.
I should be able to implement most of the changes without too much hassle. I'll need to find the fluro spring somewhere and will need to hunt down a longer sensor lead.
As I said, initial impressions of the IFS are very encouraging, but the F1R2 definitely has a lot more steering than my previous F1 iterations
Old 01-06-2015, 11:56 PM   #1318
I just tried the F1R2 today with the IFS and have to say the car felt really good. Lot less bouncy on rougher surfaces. In fact it was a lot smoother coming in and out of turns rather than the car fighting for grip through the corner. I normally run Pit 571 front/ Ride R1 rear but switched to Ride R1's front and rear. These tyres on the front normally cause a heap of understeer but the car felt well balanced. Was untimed so I don't know if there was any sort of improvement in lap time. I'll be testing it further in a few weeks at an event so hopefully not much will change set up wise.
Old 01-07-2015, 12:07 AM   #1319
MikeR's Avatar
I know right?! No more bouncing Mario Kart and now a real carving race car
Old 01-09-2015, 12:05 PM   #1320
JayL's Avatar
you need to make these plates! I want one bad
please
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 09:28 AM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
