Like Tree10Likes
Old 12-24-2014, 10:48 AM   #1291
wheelz's Avatar
Originally Posted by Boostinswifty38 View Post
I like that idea! Link to parts☺?
35mm screws:
http://www.tqrcracing.com/shop/produ....asp?p_id=1124
3mm nut:
http://www.tqrcracing.com/shop/produ....asp?p_id=6732
Aaron Lane
Team Associated | Reedy | Jconcepts | Exotek Racing | Airtronics l OCRC l Sticky Kicks l
B6 | B64 | F6 l TC7.1
AE Design Engineer
wheelz is offline   Reply With Quote
Old 12-24-2014, 01:22 PM   #1292
Thank you
~Xray~RCAmerica~Motiv~Gravity RC~
Boostinswifty38 is offline   Reply With Quote
Old 12-24-2014, 05:48 PM   #1293
NutDriver's Avatar
Trader Rating: 15 (100%+)
Don't the threads on the 3 x 35mm screw cut into the pivot balls over time?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 12-29-2014, 05:51 PM   #1294
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
http://www3.towerhobbies.com/cgi-bin...?&I=LXN077&P=7
http://www.ebay.com/itm/3Racing-FGX-...item2a49d728ec
These look like they may work too. I think the stock king pins are 33.4mm long. I might get one of those but still setting up my front end. Lot of trial and error shimming, instructions was not a good starting reference. Just need to see if my steering link has enough clearance before I try a shorter kingpin.
Dan is offline   Reply With Quote
Old 12-30-2014, 09:19 AM   #1295
wheelz's Avatar
Hi Dan,
Those would indeed work as well.
What are you trying to get your car to do differently?
Aaron
Aaron Lane
AE Design Engineer
Old 12-30-2014, 09:31 AM   #1296
Dan
Dan's Avatar
Nah, just throwing it out there for initial setup for anyone else thinking of getting it. I eventually just screwed in most of the ball connector for the shock since at 39mm length, it was already nearly coming off the threads. Re-corrected the ride height by playing around with shimming top/bottom of the steering knuckle.
I still have the aluminum Tamiya uprights in case I want to go trailing, those are even shorter, so instead of having a stack of spacers, I can just use a slightly shorter kingpin.
Overall the front end suspension action is smoooooth. I wish I can slap this on my Street Jam F1 for the ultimate in suspension smoothness.
Old 12-30-2014, 12:20 PM   #1297
wheelz's Avatar
I am actually messing with trailing spindles right now and I've really been liking the way that the car transitions from corner to corner!
Aaron Lane
AE Design Engineer
Old 12-31-2014, 09:17 AM   #1298
monkeyracing.cz's Avatar
I put EXOTEK F104 ADJUSTABLE FRONT ARM SET #1205 (ordered from RCMART) on my F1R today and I found a significant loose between turnbuckles and alloy arms for setting caster. I can shift turnbuckle inside and out about 0.5mm and bend whole arm up and down approx 3mm.
I tried to apply blue thread lock inside alloy part, helped a bit, but connection is still not tight. Looks like thread inside alloy part is for turnbuckles with larger diameter.
Is it "feature" or "issue"?
Thanks for advice.
www.monkeyracing.cz | www.rallybrno.cz
monkeyracing.cz is offline   Reply With Quote
Old 12-31-2014, 09:25 AM   #1299
wheelz's Avatar
Thanks for advice.
hello! I use a couple revolutions of nylon plumbing tape around the turnbuckle to ensure that there is no play. Like you said, lock tight will help but not be the solution. with the tape my links have no slop and have lasted quite a while without touching the tape
Aaron
Aaron Lane
AE Design Engineer
Old 12-31-2014, 06:39 PM   #1300
Trader Rating: 19 (100%+)
Hey guys,
I just put together the IFS and F104 Adjustable front arm set on my F1R2 chassis last nite.
I followed the two separate instructions (1 for the IFS and 1 for the F104 Adjustable Arms) to the T and I noticed with the standard settings for the Adjustable Arms (71mm for caster arms and 62 mm for the camber arms) that the camber comes out at about negative 8-9 degrees! I had to massively wind out the camber arms to get my desired camber angle of negative one degree. Now by winding out the camber I realised that I must have effected the caster settings as well. I'm not sure if this normal or if I have done something wrong here. Plus I don't have anything to measure caster.
Does anyone by chance have the length measurements for the caster and camber arms for the IFS + Adjustable Front arms setup?
Thanks.
bee200sx is offline   Reply With Quote
Old 01-01-2015, 12:15 AM   #1301
How does the lower mounting hole that hangs down under the lower arm of the IFS set affect ground clearance? Everytime I see pictures it concerns me that it might rub...
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 01-01-2015, 12:00 PM   #1302
wheelz's Avatar
Originally Posted by bee200sx View Post
Hey guys,
Thanks.
I can measure them for you when I get back from vacation late tonight! The interactions/lengths for the upper arms are based off of the original tamiya suspension so they will not be correct for the IFS
Aaron
Aaron Lane
AE Design Engineer
Old 01-01-2015, 12:02 PM   #1303
wheelz's Avatar
I can double check and measure the distance to the groud for you. But in over 6 months of running ptoduction molds I have never scraped an arm either indoor carpet or an asphalt
Aaron
Aaron Lane
AE Design Engineer
Old 01-01-2015, 03:24 PM   #1304
JayL's Avatar
new IFS:
I'm kinda confused as to the spindle shimming for pit tires and 5mm ride height
Mike says 1mm under spindle, and shows in his pic, and Aaron says 3mm under.
how many mm TOTAL shims and how many mm of those under the spindle??
Also for damper end spares it looks like the 3racing ball ends come in 15mm,13mm and 16mm my IFS kit ones look like 15mm is that correct?
http://www.tqrcracing.com/shop/produ....asp?p_id=1945
or
http://www.tqrcracing.com/shop/produ....asp?p_id=4681
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 01-01-2015, 05:26 PM   #1305
MikeR's Avatar
Trader Rating: 14 (100%+)
Happy New Year all!
Sorry I have been away this week. I have been away with family for the holidays.
Hey guys,
Thanks.
Hi, You must adjust final castor by using a caster gauge. Good tools equals good results Also the instruction diagram is not to scale so you cannot just match the part to the picture (no room) so that could be why yours are so short?
This simple gauge will work for you;
http://www.tqrcracing.com/shop/produ....asp?p_id=2726
Same height as the wheel so as long as you use tires you will be ok lol.
Thanks for advice.
Hi,
3mm is a lot of deflection and really not possible I think. Are you sure you meant .3mm movement? Mine have some play but no issue really. It is the tolerance needed so that metal thread can screw into metal thread.
Originally Posted by JayL View Post
new IFS:
or
Hi,
As that pic shows- I used 1mm spacer above the supplied coned spacer. Maybe Aaron lost his coned spacers but he was trying to emulate my setting as he found it drove easier (higher roll center).
The included cups are 13mm short ones.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9357 06-05-2017 08:51 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
