Like Tree1Likes
Old 12-14-2014, 10:38 PM   #1246
tudor_47's Avatar
Originally Posted by DamageNZ View Post
Hey guys,
I have the Exotek F1R, and having trouble with the rear side damper. The threads keep stripping and the top cap (hope that's right?) twists slightly which makes the damper crooked.
Is there another suitable damper out there I could replace this with?
Any help greatly appreciated!
Cheers,
I've mounted the Tamiya sida damper tube instead, it stays in one piece and it works
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 12-14-2014, 11:52 PM   #1247
wheelz's Avatar
Originally Posted by Fran View Post
Hey Aaron, where do you suggest running my shortie battery, you've raced at our track in Camarillo. It's med grip and a little bumpy.
I've been running my battery (shortie) all the way back in my V2 with a Exotek chassis, but I built a F1R2 with the IFS. Thanks!
Hey hows it going!! I run the battery between the receiver and the esc. My front to rear weight bias is 45% front and 55% rear. The battery in the middle will keep the entire car planted and stable through bumps. Honestly the most important thing is your weight bias.
Let me know if you need any help getting your car all setup! Camarillo is an awesome track. Hopefully this picture helps to describe my electronics setup
Aaron
Aaron Lane
Team Associated | Reedy | Jconcepts | Exotek Racing | Airtronics l OCRC l Sticky Kicks l
B6 | B64 | F6 l TC7.1
AE Design Engineer
wheelz is offline   Reply With Quote
Old 12-14-2014, 11:57 PM   #1248
wheelz's Avatar
Hey guys,
Cheers,
the suggestion of a tamiya damper tube would solve the problem you're having. if you really like the stock damper though, I believe it is just an associated damper from the old 12th scale car. I'm sure Associated would still carry them as another option for replacing the old one.
Aaron Lane
AE Design Engineer
Old 12-15-2014, 01:17 AM   #1249
DamageNZ's Avatar
Hey Guys,
Thanks very much, that's great! I'll try out the Tamiya and see how I go!
Thanks again
Awesomatix A800 - Modified
Yokomo YRX12 - Modified
Exotek F1R3 -- 21.5 Blinky
FANTOM / TEKIN / HIGHEST / SANWA / PROTOFORM
DamageNZ is offline   Reply With Quote
Old 12-15-2014, 05:39 AM   #1250
NutDriver's Avatar
Trader Rating: 15 (100%+)
Aaron,
Which ESC are you running? I can't see it on my phone.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 12-15-2014, 11:22 AM   #1251
wheelz's Avatar
Originally Posted by NutDriver View Post
Aaron,
I am running the lrp sxx v2 esc. With the updated board its basically just a lrp flow. So technically a flow inside of an old sxx v2 case haha
Aaron
Aaron Lane
AE Design Engineer
Old 12-16-2014, 12:24 AM   #1252
Will then F1R2 be for sale as a kit with the new front end?
charl is offline   Reply With Quote
Old 12-16-2014, 12:33 PM   #1253
wheelz's Avatar
Calling all F1R2 fans out there!!!!
F1rc.net is having their annual f1 car of the year award! It would be great to show just how many people support this car all over the world with your vote! Especially now With the new front suspension I really believe we drive one of the most developed and well thought out f1 chassis.
http://www.f1rc.net/2014/12/16/f1-rc-car-year-2014/
Let's all support Mike and acknowledge all the hard work he puts into giving us the best equipment possible
It's hammer time!!
Aaron
Aaron Lane
AE Design Engineer
Old 12-16-2014, 01:51 PM   #1254
Who's got pics of their front ends!? Mine is due to arrive this week, hopefully in time to test this weekend.
~Xray~RCAmerica~Motiv~Gravity RC~
Boostinswifty38 is offline   Reply With Quote
Old 12-16-2014, 01:57 PM   #1255
wheelz's Avatar
Originally Posted by BoneCrusher View Post
If the inside of my rear tires lift on turns, what is causing that setup wise?
Follow up question is what setup changes and in what order would you try to curb that from happening?
Thank you,
Ivan
hi Ivan!
I'm sorry I missed your question on the forum... I am assuming that you are running on carpet where the grip is extremely high. what side springs and oil are you running?
Typically that is caused by the rear pod is either reacting too slowly or too quickly when transferring weight in the corners. the key is to find the right balance of side spring and damper oil where the car is always stable but has as much corner speed as you can handle. On carpet I go to a softer spring than on asphalt (black associated spring on carpet, silver on asphalt)
-when the pod reacts too quickly it maxes out the suspension too fast and the remaining weight of the car not being absorbed by the suspension is then transferred into lifting up the inside tire.
-when the pod reacts too slowly (side spring or more often the oil is too thick) the car will not transfer enough weight in the corner and this will cause the car to lock up in the rear end and can also cause the car to lift the inside rear tire.
I typically always run 10k oil in my rear dampers. One setup tip that i have recently figured out is to lower the inside ball-studs of the dampers 2mm to level them in the car it really stabilizes the car and made a bigger difference than i thought!
Aaron
Aaron Lane
AE Design Engineer
Old 12-16-2014, 04:22 PM   #1256
Also, anyone run the exotek widening kit? Think the new ifs will help calm the car and make it more stable in cornering, on and off power?
Old 12-16-2014, 04:43 PM   #1257
wheelz's Avatar
I am running my car standard width. But having almost a year of testing on the new front end I can honestly say that the car turns nothing like an F1 car! it turns more fluidly and doesn't have that weird "hop" in the front that is stereotypical of F1 chassis. The car travels over bumps and wont upset the car during cornering.
The biggest improvement I've also seen is on carpet. My car will not traction roll. the linear progression of the suspension mellows out the front end yet still allows it to rotate through the corner. This is all achieved through droop and the linear progression of an A-arm type of suspension. The car now also has the capability to adjust geometry like camber gain and bump-steer which all adds to the overall performance of the chassis.
Aaron
Aaron Lane
AE Design Engineer
Old 12-16-2014, 04:48 PM   #1258
Ok, so medium bite Carpet. What's your camber and caster and toe and etc settings? I am willing to take the widening kit off and try the old famous Blue front steering blocks, in line or trailing. Currently, car is wide, and copper side springs, silver front kingpin screws, and neon orange shock spring. 4mm height all around. Pit 571/572.
Old 12-16-2014, 06:09 PM   #1259
MikeR's Avatar
Trader Rating: 14 (100%+)
Hi, No plans to combine these into 1 package. The F1R2 and upper arms have been available for a few years so most are picking up the IFS sets only.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 12-16-2014, 06:16 PM   #1260
Talk to Brad at f1paintlab. He can hook ya up with whatever combo you want.
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
