Like Tree1Likes
Old 10-20-2014, 07:46 PM   #1171
I'm waiting for that ifs too...
~Xray~RCAmerica~Motiv~Gravity RC~
Boostinswifty38 is offline   Reply With Quote
Old 10-21-2014, 10:21 AM   #1172
MikeR's Avatar
Trader Rating: 14 (100%+)
Me three!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 10-23-2014, 11:40 PM   #1173
Paco1001's Avatar
Any update on a release yet?
Paco1001 is offline   Reply With Quote
Old 10-26-2014, 11:49 PM   #1174
Trader Rating: 19 (100%+)
Any pre-release pics by chance?
bee200sx is offline   Reply With Quote
Old 10-27-2014, 01:52 AM   #1175
Originally Posted by IlikeF1 View Post
Mike and Aaron - thanks for all the help and advice over the last month or so!
I just returned from the IIC in Vegas, which was the first "big" race I ever attended. As far as I know I was the only one with an F1R2. I qualified 10th and won the B-Main, which earned me the last spot in the A-main later in the day. In the A-main I was able to work from 10th up to 4th.
I am by no means a pro, and I feel I could have done better had I figured some things out earlier (traction was crazy high).
I just wanted to say that in the face of the CRC WTF1 craze, the F1R2 is the chassis I believe in.
Can't wait to get my hands on that IFS now!
What was your set-up ? thanks
Rally-game proto Clo-products - Toro 150a - HW 2250kv - Turnigy a-spec - Futaba 3PKS
Tamiya M03S mini cooper - Novak 410M1C - Orion Core 27x1
Kyosho Mini-Z MR03 and MA015
Xray T4-2014 - Hobbywing V3.1 - LRP X20 spec 10.5 - Turnigy ultimate
Xray X12-2014 - Reedy Mach2 6.0
christophed83 is offline   Reply With Quote
Old 10-27-2014, 12:30 PM   #1176
IlikeF1's Avatar
I used Aaron's set up from page 59 of this forum for the most part.
I still run the stock tamiya front end though with 1.5 degrees camber, and I tend to favor the tamiya soft front springs over the Associated ones.
I added 4.5mm under the upper shock ball stud, but only becuase I didn't have one long enough to accomodate 6mm worth of spacers - I want to try this out soon.
The biggest thing for me was the Tamiya AW (anti-wear) grease as the diff lube. Aaron decribed his method with this recently on this forum and it is amazing!
One thing I noticed at both the IIC in Vegas and at my home track of 5280 raceway, is that I can carry a lot more corner speed though high speed sweepers that any other chassis, now I want to find a little more nimbleness though the tight sections.
I have a CRC WTF1 as well and even after tuning all I could I was .500 second slower than my F1R2.
Preparations are already underway for next year's IIC - it was amazing!
IlikeF1 is offline   Reply With Quote
Old 10-27-2014, 03:00 PM   #1177
wheelz's Avatar
Awesome I'm so happy my setup was a good starting point for you!!!
the 6mm for the shock angle was for a better and more consistent stroke in the shock. I used a female ballstud and put a screw through the bottom of the u-plate (I used a screw because they are cheaper than a longer ballstud). it allows you to run lighter weight shock oil but still have better dampening. thats one of the main reasons i can run such light weight shock oil
if youre ever at the track and want to try something for nimbleness: try adding 1mm to the front and rear of the side links. leave the football alone. adding those shims is equivalent to raising your roll center. keep in mind that you will have to raise your side spring 1mm to compensate for the higher side link!
Aaron Lane
Team Associated | Reedy | Jconcepts | Exotek Racing | Airtronics l OCRC l Sticky Kicks l
B6 | B64 | F6 l TC7.1
AE Design Engineer
wheelz is offline   Reply With Quote
Old 10-27-2014, 06:33 PM   #1178
Hey Aaron,
Do you by chance have a setup for asphalt? I found your carpet setup on pg. 59.
What what you change to suit asphalt? I mainly run at night on low to med grip surface.
On our track the Ride R1 rears and pit 571 fronts seems to work well, so i will be running these tyres.
I just completed my Exotek F1R2 build with TRF101 front end.
Thanks.
Old 10-27-2014, 06:55 PM   #1179
wheelz's Avatar
Originally Posted by bee200sx View Post
Hey Aaron,
Thanks.
This is what I ran this Saturday at Tamiya for the Grand Club Race. These are the settings I used to run with the old style front end... what I ran saturday was a weee bit different lol
the setup is almost identical just change the diff lube and the side springs. I do not have much experience with the ride tires but i know that my setup works well with both shimi and sweep and tamiya kits. If rides are the best tire for your track Im sure the setup will be an ok starting point.
Front:
4.0mm hide height
8.0 degrees caster
Associated 0.016 front springs
-1.5 degrees camber
2 degrees toe out
Standard Tamiya In-line front axle
2mm bump steer (the steering links should be slightly pointing down toward the center of the car at hide height \ servo /)
Main Shock:
3-hole piston
25 weight (Associated oil)
Tamiya fluorescent Red Spring (looks like orange though)
1mm droop (thread lock the spring retainer onto the shock shaft)
raise the rear female ball stud 6mm for better shock movement
Side Suspension:
Associated kit silver spring (asphalt)
10-15K oil in dampers
No washers under any of the side links
Rear Pod:
Long Wheelbase
34/86 gearing (64 pitch)
Casper Rc Diff lube on diff balls. Ae stealth lube is also good (asphalt)
4.0 mm ride height
*Tip: if your bearing insert is lose inside of the rear pod, the holes for the wing mount plate are drilled and tapped through to the axle. I used a slightly longer screw through the top hole to act as a setscrew.
Tires:
Pit 72 rear
Kit Tamiya front with stock foam
Cleaned tires with lighter fluid
LRP asphalt tire sauce. Whole rear and half front. Baked at 55 degrees C for 15 minutes. Tire tweak with no warmers is what i normally run though!
Other:
No Winglets
LRP X20
LRP short pack mounted forward
LRP SXX V2 mounted in the back with optional 3-barrel capacitor
X-ray servo saver
Tamiya F2012 Step nose body, rear wing, and front nose piece. I run the McLaren front wing (The holes line up between nosepiece and wing. The old Ferrari wing will not line up with the F2012 nosepiece however)
Hope this helps!
Aaron
Aaron Lane
AE Design Engineer
Old 10-27-2014, 09:39 PM   #1180
Paco1001's Avatar
is there any side damper tube options for the f1r2?
I have a loose damper end that I need to replace.
Old 10-27-2014, 10:38 PM   #1181
Awesome thanks Aaron.
Old 10-28-2014, 01:36 AM   #1182
Sunday, great Touring and F1 race in Vic la Gardiole(France), my friend was happy with his Exotek: pole position and victory. small asphalt track, sunny, 26c and nice people.
no restriction in rules(just have fun), my friend'car was a F1R2 wifh 3racing(f103) front end, 17.5T motor and GQ tires.
Old 10-31-2014, 11:49 AM   #1183
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
Does anyone have a decent starting setup for the F1R2 on low to medium traction carpet? My car feels ok but just mainly looking for more traction everywhere and a bit more stability thru the chicanes, here is my current setup, if its not on there its the kit settting.
Front:
4.0mm hide height
8.0 degrees caster (Exotek adjustable front arms)
Tamiya black front springs
-2.0 degrees camber
2 degrees toe out
Main Shock:
3-hole piston
30 weight Associated oil
Tamiya Red Spring
2mm droop
Side Suspension:
Associated blue side spring
CRC 20k oil in dampers
1mm shim between plate and spring holder
Rear Pod:
Long Wheelbase
32/100 gearing 64 pitch
Hudy super diff lube with cermaic diff balls
4.0 mm ride height
Tires:
Pit 74 front
Pit 57 rear
Liquid Gravity compound appiled to tires right before hitting the track after sitting on the warmers at 36C front 38C rear for 30 mins
Other:
Killshot HT/HT 21.5
Tekin RS SPEC
Trinity shorty run in the middle of the chassis (esc and receiver behind lipo)
Tamiya F2012 Step nose body, rear wing, and McLaren front wing
CR Performance Custom RC Parts (PM for details)
Colin Roussel
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 10-31-2014, 12:19 PM   #1184
Paco1001's Avatar
Well there is a big race here this weekend. My f1r2 is getting better and better. New motor went in yesterday. Practice tonight and some tuning. Hope all goes well this weekend.
Old 10-31-2014, 01:04 PM   #1185
wheelz's Avatar
Front:
4.0mm hide height
-2.0 degrees camber
2 degrees toe out
Main Shock:
3-hole piston
Tamiya Red Spring
2mm droop
Side Suspension:
Rear Pod:
Long Wheelbase
4.0 mm ride height
Tires:
Pit 74 front
Pit 57 rear
Other:
Killshot HT/HT 21.5
Tekin RS SPEC
Your setup seems to be ok to me I run a softer side spring and run my main shock a little bit lighter as well.
I just want to be sure after reading your setup... is your main spring the tamiya red or flourescent red spring?
First thing I would try is adding 5-10 grams to the esc receiver area. Trinity batteries are fairly heavy... your weight bias front to rear may be off a percent of two.
Aaron
Aaron Lane
AE Design Engineer
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
