Like Tree1Likes
Old 10-12-2014, 09:23 PM   #1156
Cadman1981's Avatar
Hey guys, what front wing do you recommend on these cars? i have the F60 body, and my front wing is drooping and looking sad. I heard the F2012 wing is worse, what else is there? how's the Mclaren wing? I was also looking at the stock F104 wing, but it doesnt look "right" to me on a modern f1...
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 10-12-2014, 09:56 PM   #1157
Paco1001's Avatar
Originally Posted by Cadman1981 View Post
He guys, what front wing do you recommend on these cars? i have the F60 body, and my front wing is drooping and looking sad. I heard the F2012 wing is worse, what else is there? how's the Mclaren wing? I was also looking at the stock F104 wing, but it doesnt look "right" to me on a modern f1...
A couple of guys are running the McLaren wing in our club. No drooping at all. I am going to glue in a carbon rod under my 2012 wing with goop. Should be perfect then. I had a carbon tube glued in but it didn't last.
Paco1001 is offline   Reply With Quote
Old 10-13-2014, 10:52 AM   #1158
Paco1001's Avatar
Hey Aaron are you running a thrust bearing in your diff?
Old 10-13-2014, 02:05 PM   #1159
wheelz's Avatar
yes I typically run a thrust bearing but on carpet sometimes I will run the standard bearing I think the standard bearing is maybe a little faster on carpet but they don't last very long...
Aaron Lane
Team Associated | Reedy | Jconcepts | Exotek Racing | Airtronics l OCRC l Sticky Kicks l
B6 | B64 | F6 l TC7.1
AE Design Engineer
wheelz is offline   Reply With Quote
Old 10-13-2014, 02:57 PM   #1160
MikeR's Avatar
Trader Rating: 14 (100%+)
Just be done with that 2012 wing. More trouble than it's worth
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 10-13-2014, 03:10 PM   #1161
Paco1001's Avatar
Thats the plan but its on backorder right now.
Old 10-13-2014, 07:48 PM   #1162
Cadman1981's Avatar
What wing do you recommend Mike?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 10-13-2014, 09:59 PM   #1163
MikeR's Avatar
Usually it depends on the body. I have had good luck with the F60 and Mclaren in the past but have grown to like the 2012 handling except for the front wing issue. I ended up modifying an F60 wing to work but it looks strange under the nose cone...
I think Aaron has modified the 2012 nose to mount onto the Mclaren wing;
With protoform releasing body sans wings the Tamiya wings will be harder to find
Next time I run carpet I'm tempted to use the F104pro front wing. I see some cars doing well with it on carpet and when they tag the pipes the wing does not get wedged into or under the pipe.
Old 10-14-2014, 07:29 AM   #1164
wheelz's Avatar
the Mclaren wing bolts onto the front of the 2012 nose piece with no cutting to either component
but they appear to be out of stock everywhere....
Aaron Lane
AE Design Engineer
Old 10-17-2014, 01:06 PM   #1165
Paco1001's Avatar
So I was doing a little tweaking on the F1 last couple of nights.
Moved the battery to the back.
New servo saver.(The one I was using was out of a m05 that was raced for 2 years. Might have been a bit soft.)
New TQwire to the motor.
New carbon rod installed in the 2012 wing.
Going to try the tire cleaner tonight as well. I hope things are going to be better than last week.
Have you guys tried the Gravity RC traction compound?
Again thanks for the help Mike and Arron. I will report on how it did tomorrow.
Old 10-17-2014, 01:46 PM   #1166
MikeR's Avatar
Good luck with practice!
Locally on carpet we are only allowed SXT3.0 or Jack (like most carpet tracks). Keeps the traction more consistent without having cross contaminated compounds on track.
The reason these sauces were selected though is because they help prevent grime build up on the tires which is a big problem with most other tire sauces on carpet. Not sure though if Gravity has similar ingredients as SXT (kerosene).
Old 10-18-2014, 07:53 AM   #1167
Paco1001's Avatar
Last night went not bad. At the start of the night the car was better but still not good buy any stretch of the imagination. After talking to a good friend about the car we did a little work on the diff.
Took out the aluminum spacer and 2 washers and put in the thrust bearing. Took out the AW grease. Re-lubed with stealth diff lube an semi broke in the diff.
By far the car is the best it has ever been. Had first place in the bag but got tied up with slower traffic near the end of the race and didn't have enough time to get it back.
I really have to find the McLaren wing. The carbon rod I put in broke right in the middle.
We have a 3 day race coming up at the end of the month. F1 has been entered into this race for the first time ever. Hope I can find a wing before then.
Old 10-20-2014, 12:35 PM   #1168
wheelz's Avatar
That's great I'm glad it went better for you!!! honestly even when the 2014 wing doesn't drag it still doesn't handle well at all...any wing is better than the 2014 front wing in my opinion. you would be better off putting one of the 3 racing lexan wing on the car if you really had to until you can find a mclaren wing
Aaron Lane
AE Design Engineer
Old 10-20-2014, 06:53 PM   #1169
IlikeF1's Avatar
Mike and Aaron - thanks for all the help and advice over the last month or so!
I just returned from the IIC in Vegas, which was the first "big" race I ever attended. As far as I know I was the only one with an F1R2. I qualified 10th and won the B-Main, which earned me the last spot in the A-main later in the day. In the A-main I was able to work from 10th up to 4th.
I am by no means a pro, and I feel I could have done better had I figured some things out earlier (traction was crazy high).
I just wanted to say that in the face of the CRC WTF1 craze, the F1R2 is the chassis I believe in.
Can't wait to get my hands on that IFS now!
IlikeF1 is offline   Reply With Quote
Old 10-20-2014, 07:12 PM   #1170
MikeR's Avatar
That is no small feat! To get 4th in the A main in a field of known talented drivers is awesome! Good job and congrats!
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
