Like Tree12Likes
Old 09-29-2014, 01:19 PM   #1111
Paco1001's Avatar
Hey Aaron. I was hoping you would chime in.
We are running on carpet.
-I had 2 degrees of castor on the first run but switched to 1 later in the night. Steering got better but not by much.
On the first run it would pull real hard to the left on acceleration. So much that it was almost impossible to get it going to top speed on the straight. I did tighten the diff a bit and the pull is almost gone but it still has a hint of left pull if your a bit too hard on the gas.
-I also lowered the side springs a bit to the links.
-I am at 1mm of droop right now.
-I am running the tamiya aluminum steering blocks as well.
-I have my akerman set forward a bit as well.
Also just sitting here looking at the front of my car I see that the front wing of this ferrari is frowning. I am going to try to stiffen up the wing with a chunk of carbon rod to stop that from happening again. I also think I will pick up a mclaren wing and give it a try.
Battery is a shorty pack all the way forward.
Thanks for the help.
P.S. I did have the f1r as well. That car was really good. I won the points race for the season last year with that car. Thought I would try out the new f1r2 for this year but so far its not going well. I do believe it has the potential to be better than my f1r was though.
Paco1001 is offline   Reply With Quote
Old 09-29-2014, 01:33 PM   #1112
wheelz's Avatar
Typically when I ran the old kingpin 104 suspension I ran 8 degrees of caster. if you're looking for more steering adding caster would be a good place to start. Right now I am running 5 degrees but that isn't quite the same setup as what you have
Definitely the front wing scrapping makes a huge difference in handling as well. I find that the Mclaren wing has a bit more down-force. but strengthening the existing wing will only improve things for you
also for the pulling to the left... what diff grease are you running on carpet??
Aaron Lane
Team Associated | Reedy | Jconcepts | Exotek Racing | Airtronics l OCRC l Sticky Kicks l
B6 | B64 | F6 l TC7.1
AE Design Engineer
wheelz is offline   Reply With Quote
Old 09-29-2014, 01:37 PM   #1113
wheelz's Avatar
after looking at your picture I see that you may have been talking about camber rather than caster. caster the the angle at which the front kingpin is laid back between the lower and upper arms. With the standard plastic front arms I would try adding washers to the back of the upper arm mounts to raise the ball stud and increase the caster in the front kinpins that should give you more steering
Aaron Lane
AE Design Engineer
Old 09-29-2014, 02:28 PM   #1114
Paco1001's Avatar
Yeah sorry I was talking about camber not caster.
Associated stealth diff lube is what I use with ceramic balls. I have heard of guys using synthetic mobil 1 grease as well. I have that as well. What do you use?
Old 09-29-2014, 02:33 PM   #1115
Paco1001's Avatar
So what your saying is put a spacer under the ball on the trailing end of the upper arm?
Old 09-29-2014, 02:44 PM   #1116
wheelz's Avatar
Use tamiya Anti-Wear Grease. It is silver and super thick. It comes in a squeeze tube and also a little jar. I feel that the squeeze tube is easier and cleaner to work with. you just need to apply a tiny little bit on each ball. The diff will feel really viscous and will need to be re-lubed more often than the AE diff lube. But on carpet it is an instant 0.2 of a second faster per lap. It takes all of the diff slip out of the car and makes the car a rocket ship under acceleration and even carries more corner speed. Not many people will tel, you that they use it. makes a HUGE difference on carpet! My car will not touch the carpet without AW grease in the diff.
If you try it and the car is super loose at first give it a pack or so to break in. the grease is really really thick.
So what your saying is put a spacer under the ball on the trailing end of the upper arm? Wouldn't that lower the castor? Standing the kingpin up and not laying it back.
I believe it would increase the castor because by making the ball taller you are increasing the length of the rear section of the arm in relation to where the spindle is and would cause the kingpin to get sucked back.
Aaron Lane
AE Design Engineer
Old 09-29-2014, 03:17 PM   #1117
hello,
on asphalt do you use aw-grease for the diff or other?
thanks.
Rally-game proto Clo-products - Toro 150a - HW 2250kv - Turnigy a-spec - Futaba 3PKS
Tamiya M03S mini cooper - Novak 410M1C - Orion Core 27x1
Kyosho Mini-Z MR03 and MA015
Xray T4-2014 - Hobbywing V3.1 - LRP X20 spec 10.5 - Turnigy ultimate
Xray X12-2014 - Reedy Mach2 6.0
christophed83 is offline   Reply With Quote
Old 09-29-2014, 03:46 PM   #1118
Paco1001's Avatar
I do have some AW grease. I will give it a shot. What size of spacer do you suggest to start with?
Old 09-29-2014, 07:29 PM   #1119
wheelz's Avatar
Originally Posted by christophed83 View Post
hello,
thanks.
I only use Aw-grease on carpet. Asphalt I typically use grease from:
http://www.casper-rc.com
it is a better quality associated stealth type of lube that I've had a lot of success with!
i think go for like a 2mm spacer to make a big change and see if you like the difference. if its too much then maybe 1mm might be a better compromise let me know if that helps at all and we can go from there
Aaron Lane
AE Design Engineer
Old 09-29-2014, 08:22 PM   #1120
MikeR's Avatar
Trader Rating: 15 (100%+)
Mr Wheelz, the current UF1 champ, knows his F1R2
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-29-2014, 10:11 PM   #1121
Paco1001's Avatar
Thats why I'm askin here.
Old 09-30-2014, 12:25 PM   #1122
thanks
but Casper-rc don't sent overseas, I will seach an over diff-grease to run on asphalt.
Old 09-30-2014, 12:34 PM   #1123
MikeR's Avatar
thanks
You can order here;
http://www.tqrcracing.com/shop/produ....asp?p_id=5323
Old 09-30-2014, 12:46 PM   #1124
I can't order Casper-rc premium diff lube.
I have already tamiya aw-grease, asso stealth(black) and silicone grease(red).
If i have understood, aw-grease is for carpet, and for asphalt stealth, right?
Old 09-30-2014, 02:38 PM   #1125
MikeR's Avatar
Oh yes, sorry I misunderstood.
Tamiya F103 Forum TFR Electric On-Road 2242 09-14-2017 12:57 PM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3141 09-10-2017 12:45 PM
Tamiya F104 Pro! NT Electric On-Road 9377 09-05-2017 08:04 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
