Like Tree10Likes
Old 04-16-2014, 03:21 PM   #991
What shocks will it use? I'm suprised it's this way vs. pushrod style. Pretty neat either way!
~Xray~RCAmerica~Motiv~Gravity RC~
Boostinswifty38 is offline   Reply With Quote
Old 04-16-2014, 03:43 PM   #992
wheelz's Avatar
push-rod s like the fgx have the ability to accumulate a lot more play and slop overtime. Since the servo is in the front of the car and has the ability to adjust the Ackerman by sliding forward or back makes it hard to have push-rods both as low as possible and not in the way for a potentially moved servo...
Aaron Lane
Team Associated | Reedy | Jconcepts | Exotek Racing | Airtronics l OCRC l Sticky Kicks l
B6 | B64 | F6 l TC7.1
AE Design Engineer
wheelz is offline   Reply With Quote
Old 04-16-2014, 03:57 PM   #993
MikeR's Avatar
Trader Rating: 14 (100%+)
Yes, and pushrods would be more complex, many more parts (= much more expensive for the customer), sloppy and much heavier. Pushrods do look cool though so I'm sure someone would try to convert it to that
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 04-16-2014, 08:18 PM   #994
Originally Posted by MikeR View Post
Hi,
You realize I do race in the UF1 Series yes? I used it to TQ the last round of the UF1 2013 Summer series and received full points.
• All front suspension mount points must be located entirely within the body shell (no pan-car front suspension systems). Adjustable link front ends are OK as long as the inner mount point is located within the body. Custom ‘flared’ bodies are not legal.
• IFS suspension systems are now allowed in the UF1 Series as long as the car meets the rest of the UF1 rules.
Hi Mike, I appreciate the work you do, and I did realize you raced in the UF1. I had not read the rules properly apparently.
I still think the pushrod design (which to me = IFS) is much more cool, but I understand your rationale as well.
.............Aaaaaaaaaaand I may still purchase it
napoleon1981 is offline   Reply With Quote
Old 04-16-2014, 09:14 PM   #995
MikeR's Avatar
Heheh thanks and I see your point as well! Regarding IFS, we are targeting the independent front suspension instead of the inline front suspension acronym.
Old 04-18-2014, 10:24 AM   #996
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Bummer, was hoping it would be something like the FGX IFS setup with maybe some revised servo mounting.
Oh well, I'll stick with my cheap $6 Tamiya front end. Going to do a shakedown run of my F1R2 this weekend on a parking lot track. Can't wait to compare it with my TRF101.
Dan is offline   Reply With Quote
Old 04-19-2014, 07:00 AM   #997
Anybody know the length of the turnbuckles in the adjustable front arm set?
J-PaP is offline   Reply With Quote
Old 04-20-2014, 03:44 AM   #998
Monsta's Avatar
What is the difference like between ifs and standard setup? Just easier setup or more grip?
BD7 '14 / Trinity / LRP / SANWA
F1R2 / Reedy / Hobbywing / SANWA
1:1 racer
HR31 Skyline - 350Kw RB30DET, 1130kg and 255 wide R comp tyres... needs more traction!
Monsta is offline   Reply With Quote
Old 04-20-2014, 05:31 AM   #999
Way I understand it is that with IFS you can properly damper suspension movement thus have greater tyre contact with the road and more grip overall, particularly in bumpier conditions. You should also be able to have more suspension travel which assists with the above.
I'm curious if the new IFS set up will allow for pro dive/anti dive to be tuned?
Old 04-21-2014, 11:28 AM   #1000
MikeR's Avatar
Stock is 24mm but you can use between 20-24mm lengths.
Smoother suspension due to more travel, much more linear spring action and actual damping. All means the car is much more predictable and easier to drive which may allow you to dial in more aggressive set ups to take advantage of this. In other words it will feel more like a race car! lol
Old 04-21-2014, 11:58 AM   #1001
JayL's Avatar
Mike: I still can't keep my F1R2 from looping on corner exit, I have even switched back to full tamiya front end and removed and re-checked the rear, can't find anything untrue or tweaked. Any idea's??
Could I talk you into taking a quick look Sat at Speedtech race?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 04-21-2014, 01:57 PM   #1002
MikeR's Avatar
For sure can take the car for a spin Sat! Just ask for me and anyone there should be able to point you my way.
Old 04-22-2014, 07:52 PM   #1003
craig santry's Avatar
Hey guys, what diff balls and lube is everyone running when using exotek spur gear. Just curious. I have always used associated stealth lube but if there is something better I want to try something different. And now with the 3mm diff balls, are you using tamiya or something else. Carbide? Ceramic? Thanks
craig santry is offline   Reply With Quote
Old 04-22-2014, 07:57 PM   #1004
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
I just grabbed some 3mm ceramic balls and used the stealth lube. Diff feels *very* nice
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 04-22-2014, 08:25 PM   #1005
aussierevo's Avatar
I had this problem last weekend racing. I rebuilt the diff, changed bearings, check the pod for tweak etc and the only thing that I could think of was that it was the front tires I was using. I was running some newish Shimizu fronts and they simply gave me too much front grip so when I turned in the rear would snap loose. They got better after a couple of runs. When I went back to an older pair the problem stopped.
Just a thought.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9357 06-05-2017 08:51 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
