Like Tree10Likes
Old 03-12-2014, 06:50 PM   #946
haywood's Avatar
Trader Rating: 48 (100%+)
Originally Posted by Boostinswifty38 View Post
Ok, I guess just looked a bit different on the site. Thought it might have included the adjustable front arms or something
Where you gonna race this Quick Swift?
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 03-13-2014, 05:19 AM   #947
Originally Posted by MikeR View Post
A bit of sticky anti wear grease or just a 'smidge' of blue thread lock should take care of that.
Thanks for that advise and for coming on here to help out. You make some awesome products.
Pipe Killer is offline   Reply With Quote
Old 03-13-2014, 03:03 PM   #948
When is this new ifs due out for the f1r2?
~Xray~RCAmerica~Motiv~Gravity RC~
Boostinswifty38 is offline   Reply With Quote
Old 03-14-2014, 01:07 AM   #949
wollow86's Avatar
Hey guys, I need some help with electronics layout on my f1r2. Trying to get it ready for the weekend.
Car will be raced on outdoor asphalt (med grip). I have a shorty Lipo, Novak edge, and airtronics receiver. I don't have the wings for electronics either, and I'm hoping for a solution that doesn't need them.
Should the shortly be used forwards or rearwards? And, if forwards I can't seem to figure out a layout that will fit the body without stacking the receiver on top of the esc?
If anyone's got some example pics that would be great.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 03-14-2014, 12:15 PM   #950
edhchoe's Avatar
Trader Rating: 41 (100%+)
My f104x1 is being run without the side wings either.
I have the shorty battery all the way back.
ESC in front of the battery.
Receiver on top of the battery in front of the center shock.
Transponder on the left side of the battery vertically affixed with double sided tape.
I charge the battery in the car.
edhchoe is offline   Reply With Quote
Old 03-14-2014, 01:16 PM   #951
wollow86's Avatar
I ended up running battery forward, Esc in the rear, and using the little cf plate that came with the x1 that mounts at the back of the front arms to put the receiver on. It's not ideal for CG, but the receiver is light so it shouldn't be too much of a problem.
Old 03-14-2014, 01:38 PM   #952
edhchoe's Avatar
I ran bettery all the way forward last week and the car lost too much turn in. The weight was too much for my front end to handle. I am trying full back position tomorrow.
Old 03-16-2014, 07:22 PM   #953
wollow86's Avatar
Car was pretty good yesterday. Had a lot of mid to exit push on power push. Pushed through the sweeper too I less I got my line exactly right I couldn't hold full power through it. High speed off power entry was very responsive, so much I used a little steering expo to settle the car down on the straight and entry.
The pod has heaps of droop. I got the damper on an f104x1, and it was built with a single o ring. I added two more before it seemed to have an effect on pod droop.
I also went to a stiffer centre spring to try and get more on power steering. It didn't help.
The car is built to kit, 104 wheelbase, mp4-24 body and wings, battery about 10mm back from full front on shorty Lipo, 30wt center damper, originally tried 30k on damper tubes (I didn't have the 100k specified in the manual) I did try to mix a dab of 300k on the tubes with the 30k, but I didn't get to run that as it rained out.
Running ride R1s.
Ive ordered some 100k damper lube, front spring set, associated side springs in black and green, an exotek spur with the 3mm diff balls. I've also got some pit 571 and 572s on order with the new tuning haus rims.
I'm not new to pan car racing, but I didn't need to do a lot with my 12r5.2 so I haven't learned a lot with tuning them. Am I right in thinking centre spring, and tube dampening have a lot to do with adding on power steering? Or should I be looking somewhere else?
Old 03-17-2014, 05:08 AM   #954
Running ride R1s.
I think you might be going the wrong way. I know what you're thinking because that seems like the right way for me too: if you want the rear to rotate more, go stiffer. But I think the fast guys will (hopefully) come on here and tell you different. I listened to them and went much faster more comfortably. I would say get rid of that droop: I used a number of o-rings inside as limiters to pull the droop out. And Mike from Exotek has argued on here to go softer (fluorescent red Tamiya spring) on the shock. I believe he's said it allows the car to "spool up" on throttle.
You might want to put the Pits on and get them scrubbed in before coming to judgment: find your new baseline and go from there. But I am pretty sure you'll want to shoot for ~1mm of pod droop with a soft spring and ~20 wt inside. It will get really, really good.
Old 03-17-2014, 05:19 AM   #955
wollow86's Avatar
Yeah your right, I was thinking along the lines of weight transfer. Stiffer center spring would mean more weight over the front tyres
In the photos I posted above you can see the spring I started with. It's a fluro red tamiya mini spring. Is that the spring I should be using?
Old 03-17-2014, 08:22 AM   #956
MikeR's Avatar
Trader Rating: 14 (100%+)
Running ride R1s.
The Rides always pushed bad for us as well. Not sure if they have produced a grippier front tire yet but I used to have to remove some of the belts to generate more front bite. In the end the Shimizu tires are the defacto tires to get on Podium in our highly competitive circles Before completely losing your set up try the Shimizus.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-17-2014, 08:26 AM   #957
MikeR's Avatar
Congratulations goes out to Aaron Lane for winning Saturdays UF1 finale to wrap up the Winter UF1 points and take the overall UF1 Championship!
Old 03-17-2014, 01:26 PM   #958
wollow86's Avatar
Thanks Mike. I'll throw the pits on when they arrive and go from there :-). Only reason I started with the rides is the 2nd hand donor x1 came with them.
Old 03-18-2014, 08:06 AM   #959
Rick Vessell's Avatar
Mike,
You have email.
Rick Vessell is offline   Reply With Quote
Old 03-18-2014, 09:17 AM   #960
cmunro's Avatar
has anyone bent the bulkhead opposite the motor mount , my bent right where the screw hole for the fan . I didn't even hit any thing hard I think this is a weak point
cmunro is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9357 06-05-2017 08:51 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
