Old 02-26-2014, 10:30 AM   #931
JayL's Avatar
F1R2 asphalt
on corner exit the rear keeps rotating if I get on the power at all. The tires are not sliding. I'm thinking I need stiffer side springs. I tried adding tension to the stock ones but it did not help
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 02-26-2014, 11:27 AM   #932
MikeR's Avatar
Trader Rating: 14 (100%+)
Originally Posted by JayL View Post
F1R2 asphalt
There are many things to try but can you first post an over head shot of your car and list what tires you are running?
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-27-2014, 11:03 AM   #933
JayL's Avatar
[IMG][/IMG]
Exotek rims pit 571/572 with the pit soft fronts inserts , but I have regular inserts fronts and 574 fronts all on the exotek rims as options
in the pic I am replacing the diff with the new exotek spur
big asphalt track: http://www.speedworldraceway.com/
I built everything with the stock F1R2 setup
Old 02-27-2014, 11:34 AM   #934
MikeR's Avatar
[IMG][/IMG]
Excellent- thanks for that.
Looks like thin wires so that is good and front angles looks good.
What I would look into;
1. Softer top spring. That is the red sedan spring you have? The red generates more on power steering. You want to go with the flourescent red (much thinner, softer) or pick up some associated b4.1 green off road springs and cut shorter. It lets the rear pod articulate and spool up for better on power rear traction.
25wt oil w/ 3 hole piston.
Check that the rear center ride height is not too low so that it doesnt bottom out though.
2. Try sliding the battery back about 8mm if you have room.
3. I don't know if the Norcal temps are too cool right now for the hard rears you are using. You may need to go to 75 rears for out door Winter.
Let me know how it goes and if you need further improvement.
Old 03-12-2014, 05:16 PM   #935
Looking to get back into f1. With an exotek f1r2 (had f1r) but I don't wanna buy a tamiya kit and then the exotek chassis. Anyone have a complete parts list they would be nice and pm me so I can order it all?
X-ray T4'16 stock TC, Xray T4'15 mod sedan, Xray xb4. Xray, Motiv, Team debit card.
Boostinswifty38 is offline   Reply With Quote
Old 03-12-2014, 05:37 PM   #936
edhchoe's Avatar
Trader Rating: 41 (100%+)
The list is on exotek website under f1r2 product description.
edhchoe is offline   Reply With Quote
Old 03-12-2014, 05:41 PM   #937
Shit, thank you!
Old 03-12-2014, 05:46 PM   #938
I think someone said that F1 paint lab would bundle it for you. BP Shadow on here...I think.
Pipe Killer is offline   Reply With Quote
Old 03-12-2014, 05:49 PM   #939
My f1r2 is feeling pretty dialed right now, but the quick-adjust shock end keeps backing out and coming completely undone. Do I have to thread lock it or is there another less invasive solution I am missing?
Old 03-12-2014, 05:50 PM   #940
What's the difference in the f1r2, and the f1r2 pro conversion?
Old 03-12-2014, 05:56 PM   #941
JayL's Avatar
Changed to a cut b4.1 green spring and did everything else you listed except tires, track temp is 80+ and WOW,WOW that gave me alot of entry and mid steering but with the rear still planted, thanks!
But I am still having the issue where on corner exit if the front wheels aren't totally straight and I get on power at all the car wants to rotate, but it's not losing rear traction/grip, the rear tires are not sliding at all.
I am guessing I need stiffer side springs or to put more tension on them. ??
Old 03-12-2014, 06:14 PM   #942
MikeR's Avatar
A bit of sticky anti wear grease or just a 'smidge' of blue thread lock should take care of that.
Old 03-12-2014, 06:15 PM   #943
MikeR's Avatar
They are the one and only same thing
Old 03-12-2014, 06:22 PM   #944
MikeR's Avatar
Are you sure the axle hubs aren't moving or spinning on the rear axle? Using the correct sized diff balls with the spur? Matching ride height rear axle spacers? Matching front droop and springs? Free moving front and rear suspension? You can try back to back runs with different side springs but sounds like a little tweak somewhere...
Old 03-12-2014, 06:52 PM   #945
Ok, I guess just looked a bit different on the site. Thought it might have included the adjustable front arms or something
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 09:28 AM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
