Like Tree12Likes
Old 01-31-2014, 08:08 PM   #916
vabroom's Avatar
Is there another front suspension that you can use? Would like to be able to get it stateside.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 01-31-2014, 08:11 PM   #917
clint's Avatar
Trader Rating: 24 (100%+)
Send a message via MSN to clint
are you looking for something other than the F104 front suspension?
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
Old 01-31-2014, 08:30 PM   #918
vabroom's Avatar
Yes, trying to be different. lol
Old 01-31-2014, 09:08 PM   #919
MikeR's Avatar
Trader Rating: 15 (100%+)
This Summer there will be a very different front arm set only for the F1R2
I forgot to mention here- new delrin F1 spur gears in stock!
http://www.exotekracing.com/
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-01-2014, 03:19 AM   #920
idbdoug's Avatar
Trader Rating: 33 (100%+)
Awesome news on spur gears, will be on order soon.
So new "summer" front arm set will not work on your Exotek F104V2 Flex Chassis??
idbdoug
www.serpentamerica.com
www.r1wurks.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
Old 02-01-2014, 08:32 AM   #921
Hi, At the bottom of the F1R2 product page is a list if you want to build your car without a donor
I just called Brad at F1RCLab and said send me everything I need to build a F1R2 and a week later I had everything in " Kit " form .
mikpiz is offline   Reply With Quote
Old 02-03-2014, 10:30 AM   #922
Rick Vessell's Avatar
Were there any Exotek cars at the Snowbirds? From what I could tell the F1 field was primarily CRC, VBC, and Speedpassion.
Rick Vessell is offline   Reply With Quote
Old 02-03-2014, 11:18 AM   #923
NutDriver's Avatar
I am interested in the preferred aluminum axle carriers/motor mount for the F1r. I have an F1R2 as well, so I already have those.
@MikeR, would the F1R2 rear axle carriers/motor mount for the F1R2 work on the F1r? If so, can I buy them from you?
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 02-03-2014, 11:30 AM   #924
MikeR's Avatar
idbdoug
F1R2 only.
None I'm aware of.
Scott
For the F1R you have to use F104 motor plates. Tamiya brand worked pretty well for us, just a bit heavy.
Old 02-05-2014, 04:08 PM   #925
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Got mine in today (fast shipping).
What size diff balls?
I assumed it 1/8 balls (since it was 64p)...I was wrong
*edit---3mm
Heads up to those looking. (they look great btw).
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 02-10-2014, 02:53 AM   #926
Running F1R with 21.5 on a medium grip track, problem I am having is a lack of initial turn in compared to competitors.Are there basic set up changes that will increase corner entry speed?
Set up:
Tyres Pits 573/575 104 size
shorty pack forward
6degrees of castor
Min toe out
RS Sector kit narrow front
fluro red spring
40 weight 3hole shock
Tamiya black side spring
Gold front springs
1mm front droop
1.5mm rear droop
5.5mm front ride height
5.5mm rear ride height
Any ideas welcomed
Bob
ALL THINGS OLD AND BLUE
BEWARE THE OLD PEOPLE
OLD ONE is offline   Reply With Quote
Old 02-10-2014, 04:01 AM   #927
Ph3nyx's Avatar
you can try less caster ( around 2 ou 3 )
battery backward
a diving chassis (5mm front , 5.5mm rear)
a stiffer grease on the side dampers.
Pit PS-0574
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 02-10-2014, 04:52 AM   #928
Some additional toe out will assist too.
J-PaP is offline   Reply With Quote
Old 02-10-2014, 07:29 AM   #929
Default F1R and F1R2 for sale!!!!
I am leaving F1 and so someone will be making out like a bandit! I am selling ALL OF MY F1 EQIPMENT. Its in the for sale section on rc tech. A great deal for someone.
TWILL is offline   Reply With Quote
Old 02-17-2014, 12:24 PM   #930
MikeR's Avatar
Aaron Lane with the F1R2 does it again! Back to back TQ and triple A main wins for the UF1 Winter Series!
Congrats Aaron! I only wish we had finished the chassis sooner for the start of the series but at least you are on a roll now and sure to finish strong
http://www.tqrcracing.com/uf1/
Tamiya F103 Forum TFR Electric On-Road 2242 09-14-2017 12:57 PM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3141 09-10-2017 12:45 PM
Tamiya F104 Pro! NT Electric On-Road 9377 09-05-2017 08:04 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
