Old 01-21-2014, 04:02 PM   #886
clint's Avatar
Trader Rating: 23 (100%+)
Send a message via MSN to clint
Originally Posted by mikpiz View Post
let me know what you figure out , you use the Padus tires correct ? my car is ok with the pardus but not enough rear grip is a problem , and I'm out of things to try
Are you running a steel rear shaft?
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
Old 01-21-2014, 04:07 PM   #887
Trader Rating: 44 (100%+)
Hey i got an f1r for sale in the for sale section if anyone is interested. Great car
Justin33 is offline   Reply With Quote
Old 01-21-2014, 06:20 PM   #888
Yes steel shaft
mikpiz is offline   Reply With Quote
Old 01-22-2014, 11:29 AM   #889
Rick Vessell's Avatar
I ran Pits this weekend. I will work on Pardus also.
What is your current setup? I found my starting setup with the Pits had too much traction and rolled easily. Hope to get to the track tomorrow for some more testing.
Futaba, O.S. Engines, Trakpower, HB Racing, SpeedPassion USA, Eggroll Inc., Vesselli Racing
Rick Vessell is offline   Reply With Quote
Old 01-23-2014, 01:11 PM   #890
bd581's Avatar
Here's my F1R2
Really needs a motor with the wireing on top and not the back, next to no room to get the wires neat.
1st race this weekend, hope it goes as good as it looks.
bd581 is offline   Reply With Quote
Old 01-23-2014, 01:16 PM   #891
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
You can run 16ag wire with 21.5 easily.
Dan is offline   Reply With Quote
Old 01-23-2014, 02:55 PM   #892
bd581's Avatar
It fits, just a little tight. Change in gearing would probably help too
Old 01-23-2014, 03:11 PM   #893
Currently I'm running
exotek adjustable Front arms . 1* camber , 6* caster. titianium coated kings pins , low friction balls , 20k on the pins , Tamiya silver front springs .
center shock has red Tamiya spring 30wt , 3 hole with 2 mm spacer on the inside . and 3 mm spacer under the front mount .
side springs are exotek kit springs , with 1 mm spacer under front ball mounts
side dampers have 20k in them ( I have tried 7, 20, 30, 50 , 75 K 20 seems to work the best)
rear diff is Tamiya f104 with a 103 bearing
ride height is 4 mm all the way around .
Car has a ton of steering and traction roll is not a problem . my main complaint is the rear end " fish tails " if you punch it and if you punch it to early out of a high speed turn it will almost spin 180
Old 01-23-2014, 06:06 PM   #894
Maybe you could loosen the diff just a tad?
Pipe Killer is offline   Reply With Quote
Old 01-24-2014, 06:54 AM   #895
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Questions?? Compatibility
Does the F1R2 front chassis plate bolt up to the rest of the original F1R?
John Higgins
liljohn1064 is offline   Reply With Quote
Old 01-24-2014, 09:15 AM   #896
Yes.
Old 01-24-2014, 11:11 AM   #897
Try:
More front droop - more weight transfer rearward on power
Stiffer center spring - jacks both rear tires into the track harder=more fwd grip
Stiffer side springs - jacks the tire into the track harder=more grip
Also, crank in a bunch of neg expo on the throttle. The Pardus tires do not have the same bite as the Pits. I run between -60 and -80 on my Futaba. Other than that, best advice is to not be too greedy accelerating out of the corners.
Try removing the spacers under the front of the links. I know it creates anti squat which should give you more forward traction. However it also increases roll steer which is why the problem is worse when accelerating out of hairpins.
Old 01-24-2014, 11:13 AM   #898
Loosening the diff would make the car rotate even more and if too loose will shorten the diff life and kill acceleration.
Old 01-24-2014, 11:14 AM   #899
Originally Posted by bd581 View Post
Here's my F1R2
Looks pretty good. I'll try to get a pic of mine posted up this weekend. I had fun trying to fit everything in and keep it low.
Old 01-24-2014, 11:59 AM   #900
JayL's Avatar
What is top sauce for Pits on asphalt?
I have been using white paragon but have been hearing good things about sxt on here but maybe that is just for carpet?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 09:28 AM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
