Like Tree12Likes
Old 01-17-2014, 07:43 AM   #871
Giorgio's Avatar
A nice mix'n'match...
Exotek R2 and Fenix front beam
Multi-wheel-base at rear and multi-wheel-base at front
https://www.facebook.com/FenixRacing.it/
www.fenixracingshop.com
Giorgio is online now   Reply With Quote
Old 01-17-2014, 08:18 AM   #872
clint's Avatar
Trader Rating: 24 (100%+)
Send a message via MSN to clint
Originally Posted by bd581 View Post
No such issue on mine
Have you tried adjusting the exotek inserts up to lock the tamiya ones in place?
did the trick! thanks for the suggestion..
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
Old 01-17-2014, 08:34 AM   #873
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Where can you order that Fenix lower front arms?
Dan is offline   Reply With Quote
Old 01-17-2014, 10:13 AM   #874
Giorgio's Avatar
Dan, just ask Brad, at Paintlab. He will do the trick for you.
Old 01-17-2014, 10:16 AM   #875
wheelz's Avatar
Default Exotek F1R2 Carpet Setup
Hello,
My name is Aaron Lane and I have had a lot of success with this setup on carpet so far. I am always trying little things here and there but this is what I mainly run and or go back to!
I think I got most everything written down, but let me know what you guys think and if you have any questions. I am happy to help!
Conditions:
TQ RC Raceway
Carpet
65-75 degrees outside temperature
Front:
3.5mm hide height
8.5 degrees caster
Associated 0.016 front springs
-1.5 degrees camber
2 degrees toe out
Standard Tamiya In-line front axle
2mm bump steer
Main Shock:
3-hole piston
20 weight (Associated oil)
Tamiya Red Spring (looks like orange though)
1mm droop
raise the rear female ball stud 6mm for better shock movement
Side Suspension:
Associated black spring
10-15K oil in dampers
No washers under any of the side links
Rear Pod:
Short wheelbase
31/88 gearing
Tamiya 101 rear axle
3.5 mm ride height
*Tip: if your bearing insert is lose inside of the rear pod, the holes for the wing mount plate are drilled and tapped through to the axle. I used a slightly longer screw through the top hole to act as a setscrew.
Tires:
Pit 74/75 combo with optional soft insert in the front
Sauce the entire rear and 1/3 to of the inside front tire
SXT 2.0 tire sauce
Cleaned with Tuning Haus Tire Cleaner/ Conditioner
Other:
Winglets with 5 grams on each side
Reedy Sonic 2 Motor
Reedy short pack mounted forward
LRP SXX V2 mounted in the back with optional 3-barrel capacitor
X-ray servo saver
Tamiya F2012 Step nose body, rear wing, and front nose piece. I run the McLaren front wing (The holes line up between nosepiece and wing. The old Ferrari wing will not line up with the F2012 nosepiece however)
Asphalt:
the only thing i really change is running the standard associated silver side spring, long wheelbase, running pit 71/72's with the softer front insert, and I use Associated chassis tape on the bottom of my car.
Aaron Lane
Team Associated | Reedy | Jconcepts | Exotek Racing | Airtronics l OCRC l Sticky Kicks l
B6 | B64 | F6 l TC7.1
AE Design Engineer
wheelz is offline   Reply With Quote
Old 01-17-2014, 11:19 AM   #876
edhchoe's Avatar
Trader Rating: 41 (100%+)
70F weather... I am jealous.
What motor timing do you have with that gearing?
So you like 574/575 better than 571/572?
edhchoe is offline   Reply With Quote
Old 01-17-2014, 11:45 AM   #877
JayL's Avatar
Aaron, I think we all know who you are
?'s
3.5mm hide height even on asphalt?
any tips on how to measure caster and camber?
thanks for your help!
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 01-17-2014, 12:08 PM   #878
wheelz's Avatar
I just checked... its actually 82 degrees at school today lol sorry
anyways I typically run around 40 degrees of timing.... anymore than that and the car fades really bad during a UF1 race.
I switch back and forth between the 71/72 and 74/75 combos on carpet. Right now my car is faster on 74/75's. But i also feel that the 74/75's heat up too much and I end up slowing down over long runs. 71/72 seem to be much more neutral and consistent over the duration of a long race!
Aaron Lane
AE Design Engineer
Old 01-17-2014, 12:14 PM   #879
wheelz's Avatar
?'s
I never run more than 4mm of ride height... but keep in mind that 3.5-4mm is also including the chassis tape that is at least 1mm thick. so technically i do raise the car up for asphalt. An advantage of running the Associated chassis tape is that one piece lasts me an entire season and its super heavy which equals a lower cg for looser surfaces
easiest and quickest way i measure the caster is putting the car flat on the setup board with no tires, take a camber gauge and set it to what i want, then line up the camber gauge to the kingpin and compare it. its not an exact way to do it but it gets me pretty close when i want to try something quickly.
Aaron Lane
AE Design Engineer
Old 01-17-2014, 05:42 PM   #880
NutDriver's Avatar
Trader Rating: 15 (100%+)
Slapmaster tools makes a caster gauge for 1/12th scale kingpins, but I don't know if it'll work with metric ones.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 01-17-2014, 06:25 PM   #881
Whoa - thanks Aaron!
Pipe Killer is offline   Reply With Quote
Old 01-18-2014, 06:45 AM   #882
Ph3nyx's Avatar
Originally Posted by NutDriver View Post
@Ph3nyx,
Outstanding job! I still enjoy seeing the low-nosed bodies. Is that Berger driving?
Thank you
Yes it's Gerhard !
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 01-20-2014, 09:12 AM   #883
MikeR's Avatar
Congrats again Aaron- TQ and winner with max points at the last round of the highly competitive UF1 January round! Aaron used the set-up he just posted the page before.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-20-2014, 10:10 AM   #884
Rick Vessell's Avatar
Finally had the chance to run mine this weekend. I will have to rethink setup with this one.
Rick Vessell is offline   Reply With Quote
Old 01-20-2014, 02:27 PM   #885
let me know what you figure out , you use the Padus tires correct ? my car is ok with the pardus but not enough rear grip is a problem , and I'm out of things to try
mikpiz is offline   Reply With Quote
Tamiya F103 Forum TFR Electric On-Road 2230 08-18-2017 05:54 PM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3140 07-24-2017 06:43 PM
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
