Like Tree1Likes
Old 01-11-2014, 05:57 PM   #856
I have delivered the f1r2 to its rightful owner. He raced it for the first time today and did very well. He could not be happier! I'm feeling a little bummed though. After driving both the f1r2 and my f104 pro v2 back to back to back on the same layout over the course of three weeks my v2 is lacking. I really didn't mess with set up since there was no need. I simply built the f1r2, attached my front end with servo and rear axle, used the same tires and picked up 3 tenths! Put my v2 back together and of course gained those 3 tenths back. It's truly amazing what that little bag of parts can do! Those 3 tenths are the difference between running a 27 lap pace and a 26 lap pace at my local carpet track.
My birthday is coming up soon. I think I should treat myself.
racer robert is offline   Reply With Quote
Old 01-15-2014, 11:53 AM   #857
JayL's Avatar
F1R2, asphalt, pit 571/572, stock setup from F1R2 build sheet
need some tips for more off power corner entry, has alot of push. Mid and exit are great
paragon white works great at my track, have tried half fronts full fronts no real change
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 01-15-2014, 12:34 PM   #858
Rick Vessell's Avatar
More rear droop
More caster
Lighter damper tubes
Softer side springs
Move battery back if running shorty pack forward
Rick Vessell is offline   Reply With Quote
Old 01-15-2014, 05:24 PM   #859
I played around with the toe my last trip out and it made a huge difference on entry. I'd give that a shot.
I would love to see some setup sheets in here. It'd be great to see what others are finding.
Pipe Killer is offline   Reply With Quote
Old 01-15-2014, 05:32 PM   #860
JayL's Avatar
toe out or in?
Old 01-15-2014, 06:06 PM   #861
edhchoe's Avatar
Trader Rating: 41 (100%+)
Do you have Soft front springs?
Do you have any drag brake?
Brake harder
edhchoe is offline   Reply With Quote
Old 01-16-2014, 05:43 AM   #862
Actually, I meant toe out. I tried running no toe after seeing a post from Mike at Exotek. But I think, in retrospect, that he said to run less toe to give you mid- to exit steering. When I did that, it lost a bunch of turn in.
So if you want initial turn in, I think you'd want to try 1 to 1.5 degrees of toe out. Just a few turns of the wrench: give it a shot both ways and see what you like. Your mileage may vary - I am not a Fast Guy so I reserve the right to be wrong. This was just my experience.
Old 01-16-2014, 09:57 AM   #863
MikeR's Avatar
Trader Rating: 14 (100%+)
+1 and the same holds true for caster- less caster means more initial steering less exit and vice versa.
Also I find alot of times a soft servo saver kills turn in and steering response (ie Tamiya). Go to the Xray servo saver with all springs installed for real steering response.
If all else fails use the new option shimizu soft front insert. Definitely more overall steering but on some tracks too much so mark the wheels 'soft insert'
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-16-2014, 01:31 PM   #864
bd581's Avatar
Nearly finished building mine, just waiting on a TRF shock that I forgot to order and to wire up the motor.
Quite impressed with the quality, everything lined up perfectly and went together smoothly.
The only issue I have is with the Speed passion 21.5T i have, the plugs are at the back of the motor, not much room between the plug and the rear bulk head. Will attempt to see how i can wire it up better this weekend.
Looking forward to testing it out next weekend
Brad
Xray T4 '16, Xray X1, Tamiya M05 Ver.II Pro.
X-ray XB4 '16, TLR 22 3.0, TLR/Exotek 22T 2.0, Mugen MBX7R Eco.
bd581 is offline   Reply With Quote
Old 01-16-2014, 01:45 PM   #865
JayL's Avatar
I am running the tamiya saver, but with a zip-tie cranked around it, does that help?
front insert ps-0550, correct?
also would front pit 574 make any difference or stick with another set of 571 with the new option insert?
thank you
Old 01-16-2014, 07:24 PM   #866
clint's Avatar
Trader Rating: 23 (100%+)
Send a message via MSN to clint
Hey guys curious what rear axle inserts to use in my F1R2 as the tamiya ones fit quite loose in the pods..
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
Old 01-16-2014, 07:37 PM   #867
bd581's Avatar
No such issue on mine
Have you tried adjusting the exotek inserts up to lock the tamiya ones in place?
Brad
Old 01-16-2014, 09:03 PM   #868
clint's Avatar
ah good call my man, have not done that..will give it a go.
Old 01-17-2014, 05:21 AM   #869
Ph3nyx's Avatar
Exotek F1R2 with tamiya F103 MacLaren Mp4/5b body
for the tires : pit shimizu rubber PS-0541 PS-0545. First run with the rubber tonight on high grip carpet
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 01-17-2014, 07:32 AM   #870
NutDriver's Avatar
@Ph3nyx,
Outstanding job! I still enjoy seeing the low-nosed bodies. Is that Berger driving?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9356 Yesterday 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
