Old 12-03-2013, 11:57 AM   #766
JayL's Avatar
any opinion on the original F104 diff vs the V2 diff that uses the 417 rings?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 12-03-2013, 01:54 PM   #767
Originally Posted by Serzoni View Post
Kingpins?
Tamiya 9808241 Stainless Shaft: 58431 - 3x33.4mm F104
Sydewynder is offline   Reply With Quote
Old 12-03-2013, 01:58 PM   #768
Only difference I can tell are the diff rings and the matching machining on the hubs to fit them. The diff action feel the same to me. The 417 rings cost more.
Old 12-03-2013, 02:51 PM   #769
Thanks. For some reason, when I searched for that part # earlier I kept getting the small stainless pins that hold the end cap onto the right side diff hub.
Serzoni is offline   Reply With Quote
Old 12-03-2013, 02:57 PM   #770
Monsta's Avatar
Originally Posted by MikeR View Post
Good Morning All!
Preorders are now open. First batch will sell out fast
http://www.exotekracing.com/f1r2-pro...hipping-dec-7/
just told the missus this is high on the christmas list
BD7 '14 / Trinity / LRP / SANWA
F1R2 / Reedy / Hobbywing / SANWA
1:1 racer
HR31 Skyline - 350Kw RB30DET, 1130kg and 255 wide R comp tyres... needs more traction!
Monsta is offline   Reply With Quote
Old 12-03-2013, 04:26 PM   #771
JayL's Avatar
F1R2: how do the front arms mount? do we need your ADJUSTABLE ARM MOUNT PLATES?
Old 12-03-2013, 04:39 PM   #772
You got one big diff with a 33.4mm long end cap pin. Lol
Old 12-04-2013, 09:13 AM   #773
MikeR's Avatar
Trader Rating: 14 (100%+)
The Tamiya arm set includes the plastic arm mount plate.
If building a roller from parts I highly suggest downloading an F104 manual to help guide everyone on the Tamiya parts portion.
http://www.petitrc.com/reglages/tami...amiyaF104.html
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 12-06-2013, 10:58 PM   #774
MikeR's Avatar
First wave of kits shipped out a day early today! Next wave goes out Monday.
Some ideas for those building cars next week;
Old 12-07-2013, 10:12 AM   #775
Send a message via ICQ to JiuHaWong
What does the angled side links do vs. straight ones?
Great looking chassis MikeR, I like all the thought you put into it.
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 12-07-2013, 03:10 PM   #776
idbdoug's Avatar
Trader Rating: 33 (100%+)
Will a low profile Orion servo work with new F1Rv2?? Exotek's website recommends a KO or Futaba
idbdoug
www.fantomracing.com
www.falconsekido.com
www.reflexracing.net
www.gizmoracingusa.com
idbdoug is offline   Reply With Quote
Old 12-09-2013, 11:27 AM   #777
JayL's Avatar
MikeR: any chance of a side pic of that car? and/or where is the recv, in front of the battery?
also : is that the clamp hub on the right rear wheel, is seem like another spacer is on there?
Old 12-09-2013, 01:58 PM   #778
Trader Rating: 22 (100%+)
Just received my kit in the mail today~! Time to build, well, when I get home from work.
Thanks Exotek~!
JoeyE is offline   Reply With Quote
Old 12-09-2013, 02:02 PM   #779
There are more pictures on the Exotek site. Looks like the TAMIYA clamp hub. I have the same one. The receiver is in front of the battery. Looks like it is attatched to the back of the servo. Going to do the same thing on my build.
Old 12-10-2013, 10:09 AM   #780
MikeR's Avatar
Thanks,
To make it look cool! lol
- New angled side links. The triangulated angle improves suspension geometry resulting in much freer rear pod movement at extreme left right angles. The older 'square' link angles were free when flat but binds up the further the suspension lifted left or right. The result is improved bumpy track and high speed handling.
idbdoug
Hi,
If it has similar dimensions to the KO or Futabas then you should be fine. Maybe shims if at all.
Hi,
Yes rcvr in front of battery.
There is a spacer by the clamp. Did I leave that part off the builders list?
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 09:28 AM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
