Old 11-26-2013, 09:37 AM   #751
Ph3nyx's Avatar
Awesome job !Great for all the possible settings (ackerman is a real plus, adjustable wheelbase ...). Does the hybrid link/tbar solution make the chassis more flexible ? does this explain the two side dampers ?
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 11-26-2013, 10:05 AM   #752
Vyger's Avatar
Damn Mike, thatís a good looking well thought out car. I just added it to the Christmas list. Or, I could just stop by and pick one upÖ.let know when is a good time.
Side note: you do realize that patents donít really mean a whole lot in China.
Tamiya Road Wizard, F101ís, F102ís, F103ís, F103RSís, F103LM, F103RXís, F103RMís, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 11-26-2013, 10:54 AM   #753
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Great job Mike! This might push me to get another f1!
RCBuddha is offline   Reply With Quote
Old 11-27-2013, 12:11 AM   #754
tudor_47's Avatar
aouch Mike!
I thought I would not need a new car for 2014 as I have the F1R ....
Now you go and make this, superb car, and yes I do need it....
I wonder the bell crank steering with the servo further back in the chassi is that possible to use in the F1R2?
Have you run the new car on asphalt with foam tires?
We run with 13.5T and foams on asphalt and rubber tires is not up to the task, with rubber tires i am 1 second slower per lap.
were do we sign up?
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 11-28-2013, 08:59 PM   #755
MikeR's Avatar
Trader Rating: 14 (100%+)
Default HAPPY THANKSGIVING DAY
Originally Posted by Giorgio View Post
Hi Mike...
Seems that you like the feature we introduce first on I-mola and Su-zuka.....
Hi, I won't take credit for the first to have 2 wheelbases. I credit the HPI Micro RS4 for the idea. About 10 years ago I used to make a chassis conversion for it too
Thanks!
Correct for the rear.
As long as patents means something to the western world along with chinas favorite distributor- ebay, we will be fine
Come down and we'll grab lunch 10 days or so.
Originally Posted by tudor_47 View Post
aouch Mike!
were do we sign up?
Hi,
Foam racing has died out so no testing sorry.
The steer set may work with the F103 parts but I think the post would move if mounted on the chassis slot. I don't think it's needed so much though.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 12-01-2013, 11:38 PM   #756
Typeone's Avatar
Trader Rating: 30 (100%+)
On the new Exotek F1R2 can I use the TRF101 front end and rear shaft and hub assembly? Really need to know before buying the conversion?
TRF101/Tamiya F104-V2/ TRF Tamiya 417/ Smokem FX chassis & V7 conversion/ Speed Passion/ Sweep Racing/ Futaba/ SMC
Typeone is offline   Reply With Quote
Old 12-02-2013, 02:14 PM   #757
MikeR's Avatar
Hi Sir!
The front might be ok but I'm not sure about the rear axle. I'm not sure what the center is for the 101 axle so may cause problem in the F1R2. Better to sell the 101 for more money and then use some of the money to buy F104 axle and Exotek front arms
Old 12-02-2013, 05:39 PM   #758
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
Dude, you just switched to a TRF101 after barely having a F104v2. Put some more laps down first!
Dan is offline   Reply With Quote
Old 12-02-2013, 05:44 PM   #759
Typeone's Avatar
I know but this setup seems like it would handle better on my track since it's a little bumpy. I like how the trf101 handles but this new kits seems like it would do a lot better on my local asphalt track and considering the weather too it's getting cold so low traction will come into play.
Old 12-03-2013, 01:03 AM   #760
Trader Rating: 22 (100%+)
@Dan.....funny, I also want the new F1R2 and I haven't even put one lap down on any F1~!
JoeyE is offline   Reply With Quote
Old 12-03-2013, 08:18 AM   #761
MikeR's Avatar
Good Morning All!
Preorders are now open. First batch will sell out fast
http://www.exotekracing.com/f1r2-pro...hipping-dec-7/
Old 12-03-2013, 08:28 AM   #762
Ordered.
Serzoni is offline   Reply With Quote
Old 12-03-2013, 08:40 AM   #763
MikeR's Avatar
INTERESTED IN BUILDING THE F1R2 INTO A ROLLER FROM THE GROUND UP?
These are the parts needed. Swap out model numbers as desired for after market hop ups.
This list is a work in progress and does not include all of the required hardware.
EXOTEK F1R2 CONVERSION
Tamiya 54240 Wheel Stopper F104 / F103
Tamiya 54158 F104 Alum Diff Housing Set
3Racing BS-F104/V1 Ball Bearing Set For F104
Tamiya 54162 F104 Carbon Rear Shaft
Tamiya 84171 2mm C-Ring (8pcs)
Exotek FRONT BULKHEAD HEX SCREWS- TITANIUM
Tamiya 9808241 Stainless Shaft: 58431 - 3x33.4mm F104
Tamiya 50509 Tamiya F1 Front Spring Set
Tamiya 54154 Carbon Reinforced Uprights - Front F103 / F104
Tamiya 51347 F103/F104 Disc Ball Set (diff rings)
Tamiya 51381 F104 F Parts - Suspension Arm/Front
Tamiya 51000 Hi-Torque Servo Saver set (ADDING THE ALLOY ARM IS SUGGESTED) or XRAY HEAVY DUTY SERVO SAVER SET
Tamiya 53601 Tamiya Low Friction Adjuster 5mm (BALL CUPS)
Tamiya 54249 Aluminum Turnbuckle Shaft - 3x32mm (2pcs)
Tamiya 53640 5mm Aluminum Ball Nut - Blue 10pcs
Tamiya 53901 F104 TRF DAMPER
Wheels and tires
Tamiya body set
Tamiya spur gear spacer adapter
1/10 SPUR GEAR WITH 1/8TH DIFF BALLS (72T 48 PITCH KIMBROUGH IS A GOOD START)
Old 12-03-2013, 09:03 AM   #764
Rick Vessell's Avatar
Mike,
You got email.
Futaba, O.S. Engines, Trakpower, HB Racing, SpeedPassion USA, Eggroll Inc., Vesselli Racing
Rick Vessell is offline   Reply With Quote
Old 12-03-2013, 10:03 AM   #765
These are the parts needed. ..
Kingpins?
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 09:28 AM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
