Old 11-25-2013, 12:22 PM   #736
MantisWorx's Avatar
Trader Rating: 27 (97%+)
Congrats MikeR!! Finally an innovative designed car, it looks like you guys REALLY did your homework on this one and left no stone unturned! What are the possibilities of a black edition? I will order as soon as it is available.
MantisWorx is offline   Reply With Quote
Old 11-25-2013, 01:07 PM   #737
mtveten's Avatar
Trader Rating: 27 (100%+)
Mike,
Can you please explain the hybrid link, the website photos don't illustrate the difference.
Thanks,
Mark
mtveten is offline   Reply With Quote
Old 11-25-2013, 01:28 PM   #738
MikeR's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Gero View Post
Hello
I'm searching for the "EXOTEK F1R steering crank set [1178]"!
It's no more avaible here in Germany...
Anyone got one or better two for sell?
Please PM.
Regards, Gero
Hi, email Exotek. We have a few of the alloy parts still.
Originally Posted by Mechintosh View Post
Moved Battery forward to gain in steering and reduce the traction roll. Running 571/572's which I have the front sidewall CA'd. Initial turn in is awesome, but at med to high speed middle off the steering goes away. If I run the non CA'd tires, car rolls over. Any suggestions how to pick up the steerng on the ed high speed corners? Maybe I am just over driving the car. I am about .4 off the really fast cars at my local track.
The diff still diffs out with the thrust bearing. I just got a new F103 setup and will swap out. Hopefully it is just worn spring washers.
Some quick remedies (1 at a time);
-Reduce toe out
-Increase anti squat- add 1mm spacer under the 2 side links at the forward links only
-Increase ackerman- move servo forward.
-Increase steering knuckle throw- grind a few mm off the steering stoppers on the lower arm.
Originally Posted by godzukihop View Post
Make sure you have the correct diff balls? Stock spur gear 3mm diff balls, Kimbrough spur 1/8 diff balls. I made this same mistake and it drove me crazy.
Good point
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 11-25-2013, 01:47 PM   #739
MikeR's Avatar
Default Happy Monday
Originally Posted by wheelz View Post
Hey guys check out the website for pictures of the new car!!!
http://www.exotekracing.com/f1r2-pro...ion-eta-dec-3/
Originally Posted by nrtv20 View Post
saw that earlier as well, car looks fantastic!
Thx!
Thx Marcus! Everytime I thought the car was ready to go to production we kept getting inspired to update more and more and more. Luckily still completed in time for the Holidays lol.
Originally Posted by mtveten View Post
Mike,
Thanks,
Mark
Hi!
I thought a picture was worth 1000 words, lol.
Note the standard link suspension- has the normal 5 pivot balls.
Then see that the chassis is cut into a 'T-plate' type suspension.
Some experienced pan car racers know that link suspension excels on carpet while 't-plate' excels on asphalt. Link is more responsive while t-plate absorbs more bumps. I have come up with the simple solution to have both.
Testing over the past year went incredibly well with the new solution. So well I promptly filed for patent pending on it to keep the others from duplicating the solution
We are closing for a few days for Thanksgiving break but hope to start preorders next week and begin shipping a few days after.
Mark your calenders;
Preorders Dec 3.
Shipping Dec 6.
Thanks All!
Old 11-25-2013, 01:51 PM   #740
Mechintosh's Avatar
-Reduce toe out
Toe out was already reduced. I will test the Anit squat on Friday. Car was wicked fast but not fast enough on Sat, got a second place with the car's first ever race. Not a bad start. Car was slow to start the run but the last 4 minutes it was really fast. Ended up going to a Tamiya Blue Main Spring and Tamiya Gold Side springs with 1 turn of preload.
Xray T4-14,T4-15, X1
Pro Mini Truggy Mid Motor Mafia Xfactory
Serpent SRX4, 811 TE-e
Kyosho RB6, MP9e TKi
Mechintosh is offline   Reply With Quote
Old 11-25-2013, 02:18 PM   #741
IAmGreatDane's Avatar
@MikeR: A very impressive conversion kit. Love it!
I understand that the wheelbase is adjustable. But by how much?
Thx and happy thanksgiving :-)
Best Regards,
I Am GreatDane c'',)
IAmGreatDane is offline   Reply With Quote
Old 11-25-2013, 02:55 PM   #742
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Looking at the rear pod, 4-5mm?
Dan is offline   Reply With Quote
Old 11-25-2013, 03:20 PM   #743
MikeR's Avatar
Thanks Sir!
Long wheel base equals 269mm. Short wheelbase equals 263mm.
Old 11-25-2013, 04:07 PM   #744
Trader Rating: 21 (100%+)
@ MikeR
Can I get away with using the RM-01/Version 2 Pro's pitch damper, will that extra hole on the battery brace accept it's use?
RS_ZACH is offline   Reply With Quote
Old 11-25-2013, 05:29 PM   #745
Very very cool car. I may have to rethink my crc wtf1 plans. Looks like a really complete conversion kit too. Is it just add axle and front end of choice to make it a complete roller?
racer robert is offline   Reply With Quote
Old 11-25-2013, 05:38 PM   #746
wheelz's Avatar
rear axle, front clip (for now) , wings, and a body
Aaron Lane
Team Associated | Exotek | AKA | LRP | Airtronics l OCRC l Sticky Kicks l
B5m | B44.3 | Exotek F1R3 l TC7
wheelz is offline   Reply With Quote
Old 11-25-2013, 07:40 PM   #747
Trader Rating: 57 (100%+)
Front end
Axle/diff
axle locators
Shock
Body/wings
Depending on what the complete CRC car cost, I may go with the exotek as well!
PROMODVETTE is offline   Reply With Quote
Old 11-25-2013, 08:27 PM   #748
Trader Rating: 22 (100%+)
Excited~! Is there a pre-order?
JoeyE is offline   Reply With Quote
Old 11-25-2013, 11:46 PM   #749
Thanks Sir!
Thanks, MikeR.
Best Regards,
Old 11-26-2013, 02:11 AM   #750
Giorgio's Avatar
Thanks Sir!
Hi Mike...
Seems that you like the feature we introduce first on I-mola and Su-zuka.....
www.fenix-racing.com
www.fenixracingshop.com
Giorgio is offline   Reply With Quote
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 09:28 AM
Tamiya F104 Pro! NT Electric On-Road 9327 01-11-2017 01:04 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
SEO by vBSEO 3.5.0
