Old 11-04-2013, 08:22 AM   #721
Mechintosh's Avatar
Just picked up an F1R. When running on Med to High grip carpet, my inside rear wheel is picking up causing the car to "Diff" out. The car corners awesome but I can not get back on the power as soon as I would like. Any suggestions to help solve this issue.
Pits 571/572
RH 4.8mm
White/Red Tamiya center spring with Upgrade shock
Black Side springs - AE
Shorty towards the rear
Soft Tamiya Springs up front
Steel Axle
Roll tube, not shock. Tamiya upgraded version
2 Camber
Xray T4-14,T4-15, X1
Pro Mini Truggy Mid Motor Mafia Xfactory
Serpent SRX4, 811 TE-e
Kyosho RB6, MP9e TKi
Mechintosh is offline   Reply With Quote
Old 11-04-2013, 09:07 AM   #722
Rick Vessell's Avatar
Pits 571/572
RH 4.8mm
Steel Axle
2 Camber
Try heavier oil in the damper tube and stiffer side springs. I currently run Blue AE side springs and 80K in the tube. If the rear is still lifting/loose try a stiffer center spring.
Just moving the battery forward will help a lot with the problem. I run my pack full forward almost everywhere I've run.
Good luck!
Futaba, O.S. Engines, Trakpower, HB Racing, SpeedPassion USA, Eggroll Inc., Vesselli Racing
Rick Vessell is offline   Reply With Quote
Old 11-04-2013, 09:32 AM   #723
MikeR's Avatar
Trader Rating: 14 (100%+)
Pits 571/572
RH 4.8mm
Steel Axle
2 Camber
Pretty common for the F104 Tamiya ball dif on high grip carpet. The F104 ball diff tends to be too free. Tighten it up or better yet install a F103 ball diff (still works with 104 wheels). F103 style thrust bearing doesnt counter spin so easily, when tightened, thus giving you better launch out of corners
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 11-14-2013, 07:59 AM   #724
Mechintosh's Avatar
I added the Thrust Bearing, and I am running it as tight as I can get it. I am still "diffing" out. Will continue to work on it.
With my 104v2, I had almost no steering even with the battery forward, with this F1r I am no traction rolling with the battery in the rear. What is the best way to tame the traction roll?
Old 11-14-2013, 08:03 AM   #725
robk's Avatar
Trader Rating: 22 (100%+)
Battery forward glue outsides of front tires
robk is online now   Reply With Quote
Old 11-15-2013, 12:13 AM   #726
tudor_47's Avatar
Originally Posted by MikeR View Post
Testing going well. More updates to follow. Eta Nov 2013.
http://www.exotekracing.com/news.php?newsid=17
November is here, we are all curoius as to what you've come up with.....
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 11-15-2013, 04:40 AM   #727
Trader Rating: 21 (100%+)
+1
RS_ZACH is offline   Reply With Quote
Old 11-15-2013, 06:08 AM   #728
Very curious!
Stoph79 is offline   Reply With Quote
Old 11-15-2013, 06:12 AM   #729
+1 keen to hear some news.
J-PaP is offline   Reply With Quote
Old 11-15-2013, 10:57 AM   #730
wheelz's Avatar
Man that car looks familiar from somewhere... Cannot wait!!!!
Aaron Lane
Team Associated | Exotek | AKA | LRP | Airtronics l OCRC l Sticky Kicks l
B5m | B44.3 | Exotek F1R3 l TC7
wheelz is offline   Reply With Quote
Old 11-20-2013, 04:15 AM   #731
Hello
I'm searching for the "EXOTEK F1R steering crank set [1178]"!
It's no more avaible here in Germany...
Anyone got one or better two for sell?
Please PM.
Regards, Gero
Gero is offline   Reply With Quote
Old 11-22-2013, 01:52 PM   #732
Mechintosh's Avatar
Moved Battery forward to gain in steering and reduce the traction roll. Running 571/572's which I have the front sidewall CA'd. Initial turn in is awesome, but at med to high speed middle off the steering goes away. If I run the non CA'd tires, car rolls over. Any suggestions how to pick up the steerng on the ed high speed corners? Maybe I am just over driving the car. I am about .4 off the really fast cars at my local track.
The diff still diffs out with the thrust bearing. I just got a new F103 setup and will swap out. Hopefully it is just worn spring washers.
Old 11-22-2013, 03:05 PM   #733
godzukihop's Avatar
Trader Rating: 31 (100%+)
Make sure you have the correct diff balls? Stock spur gear 3mm diff balls, Kimbrough spur 1/8 diff balls. I made this same mistake and it drove me crazy.
JOHN's MOBILE RACEWAY | 180 RACEWAY | Jackson RC Track
Murnan Modified because HP is intoxicating!!! | VP RACE FUEL |
G-FORCE HOBBIES | Fordham Hobbies | ASHFORD HOBBY | TEAM CAMDEN
RC AMERICA / XRAY / HUDY / TEAM POWERS
godzukihop is offline   Reply With Quote
Old 11-25-2013, 10:53 AM   #734
wheelz's Avatar
Hey guys check out the website for pictures of the new car!!!
http://www.exotekracing.com/f1r2-pro...ion-eta-dec-3/
Aaron Lane
Old 11-25-2013, 10:55 AM   #735
nrtv20's Avatar
saw that earlier as well, car looks fantastic!
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 09:28 AM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
