Like Tree11Likes
Old 05-22-2013, 02:37 PM   #691
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by shadowracer24 View Post
Does anyone know where I can get the F1r kit at ,can"t seem to find one anywhere.
PM MikeR. Even he "Mr. Exotek" is out of stock.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 06-12-2013, 01:42 AM   #692
tudor_47's Avatar
I run the F1R with a F104 motor pod, But i have found best results using F103 rear tires (foam)
I think that using the F103 motor pod would enable me to use more of the rear tire?
so question is , can I replace parts of the motor pod with F103 parts using the same F1R parts?
Thanks!
/Johnny
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 06-12-2013, 08:28 AM   #693
As long as you have a place to mount the side to side damper mount, you are fine. The only thing different between the pod sides is the axle height adjuster location.
Old 07-07-2013, 09:05 PM   #694
RonF's Avatar
So why is the F1r conversion out of stock and discontinued? I would like to upgrade my pro without buying a new car (v2).
VBR,
Ron
F104pro, Turnigy Turbo 80amp, 21.5 trackstar, LRP esc and Rs 540
RC10 original, RC10 graphite, RC10 4wd MIP SP1 version, RC10T
RonF is offline   Reply With Quote
Old 07-09-2013, 07:58 PM   #695
NutDriver's Avatar
Trader Rating: 15 (100%+)
Check with Exotek. Mike R is good about responding to inquiries.
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 07-11-2013, 07:50 PM   #696
The Captain's Avatar
Whats a good battery for the f1r? I need to start buying stuff for this upcoming fall season. We are running 21.5. I was using the track power shorty, not sure what kind of condition it's in now, but it seemed to work just fine last season.
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is offline   Reply With Quote
Old 07-12-2013, 07:29 AM   #697
idbdoug's Avatar
Trader Rating: 33 (100%+)
Fantom racing 4600mah shorty
idbdoug
idbdoug is offline   Reply With Quote
Old 07-12-2013, 08:31 AM   #698
NutDriver's Avatar
I'm going to give the 4600MaH 2s shorties that F1Paintlab has a try.
USVTA member #111
Old 07-14-2013, 04:12 AM   #699
Does anyone know of an editable setup sheet for the F1R?
Thanks!
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 07-14-2013, 01:54 PM   #700
Can someone give me a part number for the spacers used on the servo horn shown here:
I also need the part numbers for the aluminum side spring holders, and a better side damper. Thanks!
-Derrick-
Old 07-14-2013, 04:24 PM   #701
macavant's Avatar
Trader Rating: 64 (100%+)
check for these:
high torque servo saver: TAM51000
side damper: TAM54413
spring holder: TAM54478
likes the oldskool RC action...
F103.F201.F103GT.F1R3☆F104WGP.F1Ultra☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 07-15-2013, 10:36 AM   #702
MikeR's Avatar
Trader Rating: 14 (100%+)
Thanks!
Hi,
Just use the 104v2 sheet. F1R came out first but surprisingly the 104v2 has the same set up features
F104V2 blank setup - TeamTRF.com
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 07-15-2013, 10:39 AM   #703
MikeR's Avatar
Thanks Mac for the other part numbers.
For the spacers just stack normal 3mm hinge spacers.
Currently I'm just using a 4mm long 3mm spacer.
3racing makes them.
Old 07-15-2013, 08:07 PM   #704
macavant's Avatar
Oh THAT spacer...
missed that completely.
I had to use varying spacers to get the steerings links even on my F1R with these:
TAM53539
Old 07-16-2013, 03:05 AM   #705
Originally Posted by MikeR View Post
Hi,
Thanks!
Space for rent!
Tamiya F104 Pro! NT Electric On-Road 9357 06-05-2017 08:51 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
