Like Tree10Likes
Old 04-29-2013, 08:10 AM   #646
Rick Vessell's Avatar
Originally Posted by mikpiz View Post
Would love to see that set up sheet , just built a f1r and am getting into F1 racing ( UF1 midwest rules ) and could use some hints to get this thing dailed in .
Sorry, this got away from me. I'll have a sheet up asap.
Rick Vessell is offline   Reply With Quote
Old 05-02-2013, 03:56 PM   #647
MikeR's Avatar
Trader Rating: 14 (100%+)
Sorry so late- work work work
Originally Posted by 5th wheel View Post
Ok thank you. What's a good tire to run on in Florida for f1 on a black top parking lot. That will fit on your wheels. Pits thanks
I'm guessing for your track Shimizu 72 hard rears and 71 soft fronts or 73 med fronts depending on how much steering you need.
Originally Posted by tudor_47 View Post
OK I'll refrase
will the electronics that I now have between the link and the battery still fit if I switch to this new chassis?
It will be an even tighter fit- about 2mm less on each side. You should be running a shorty lipo and just mount the on/off switch on the side plate like most F1 racers!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-10-2013, 08:05 PM   #648
edhchoe's Avatar
Trader Rating: 41 (100%+)
Just letting you know my F1R is up for sale in For Sale section.
Sold.
edhchoe is offline   Reply With Quote
Old 05-13-2013, 10:52 AM   #649
Suspended
wheres itt at...lol
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
Old 05-13-2013, 11:26 AM   #650
Suspended
mike...are the rims gonna be in soon..i need some for reedy
Old 05-13-2013, 01:03 PM   #651
MikeR's Avatar
Another shipment coming in this week thx
Old 05-13-2013, 11:21 PM   #652
tudor_47's Avatar
Talking
I ran my F1R successfully last Sunday(12 of May) with foams, this is great!
I could not get the car to function with the foam wheels
but after rebuilding this winter and introducing the uni crank steering (Exotek) and using shorty batteries. I am now able to run with last year winner at the same pace.. I TQ'd and got fastest lap during the final.
Setup: i have the electronics between the battery and the links. The transponder sits under the steering.
Great car!
Oh,
we run 35 minute final with a mandatory battery change stop of 4 minutes. during the summer we run 8 races and it all comes up to a final race where the winner is decided, points are collected during the summer. In the race last sunday I missed alot of racetime as I had choosen to run rubbers, it was raining some so I gambled that it would rain... however it dried up so I switched to foam tires, loosing valuable race time.
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 05-14-2013, 07:49 AM   #653
Suspended
thx mike..don't know if you remember me from srs a few years back..lol..anyways is there a way I can make a pre order or you let me know when they are available so I can order asap and have them shipped priority or overnight?? thx,
Ray
Old 05-14-2013, 08:14 AM   #654
Suspended
also I have the older conversion with the laydown servo and bellcrank..do you recommend going with the standup servo up front?? is there a performance advantage to either?? I am goin to place order as soon as rims come in..with the new 2.5 mm chassis also
Old 05-14-2013, 10:16 AM   #655
As promised here is my setup. I do apologize for the delay. No setup sheet at the moment so here's the long form
Front:
Width - 182mm
Spring - Tam black w/.7mm preload
No spacers under camber plate
1.5mm spacer under camber ballstud
1.5 deg. camber
4.5 deg. caster
Exotek adjustable arms
1 deg toe out
Tam alum uprights, inline axle, one hole forward from rear position for toe link
Pardus spec tire, CA inner and outer sidewall up to tread
7/8 sauce, outer edge dry
Ride height 3.5mm at front of chassis
Wing - F60 with Exotek brace
Center:
TRF full size shock
3 hole piston
450wt oil
Gray Tam spring (very hard), set preload so chassis has very slight sag
Forward hole on shock mount
1.5mm under forward ball stud for clearance
2.5mm under rear ball stud
4.5mm droop
X1 damper tube with 80K
AE gold side springs just touching
Rear:
Width 183mm
X1 counterweight
Spur 93
Pinion 31
Motor - SP MMM3.0 21.5 with 30deg board set full retarded
Pardus spec tire, CA outer side wall up to tread
Full sauce
Ride height 4.0mm
Wing - F60
Body - Tam F60
ESC - SP GT super stock mounted on end behind servo
Servo - Futaba BLS951 horizontal with Tam servo saver
Battery - Trakpower 4400 shorty full forward behind ESC
Old 05-14-2013, 11:38 AM   #656
texastc's Avatar
^^^ gold
Exotek F1Ultra Tamiya TRF101 SpeedPassion LM1 and SP1 and another Exotek F1Ultra on the way.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
TCdoesRC
texastc is offline   Reply With Quote
Old 05-14-2013, 04:43 PM   #657
MikeR's Avatar
Hi, Wheels just came in
Seems for rubber most are comfortable with the standard servo location. Just a tad more steering and probably more predictable off power with these narrow cars. Wide is probably another story
Nice! Thanks for your support Rick.
Old 05-14-2013, 05:03 PM   #658
NutDriver's Avatar
Trader Rating: 15 (100%+)
Mike,
Are you still making the F1R? I am aware of the new, thinner chassis. Also, can we order the wheels from Exotek Racing now?
scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 05-14-2013, 05:09 PM   #659
EricF's Avatar
Can you use a mini servo in these cars or is it best to use a low profile servo?
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 05-14-2013, 05:43 PM   #660
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Front:
Width - 182mm
1.5 deg. camber
4.5 deg. caster
1 deg toe out
Center:
TRF full size shock
3 hole piston
450wt oil
4.5mm droop
Rear:
Width 183mm
X1 counterweight
Spur 93
Pinion 31
Full sauce
Ride height 4.0mm
Wing - F60
Body - Tam F60
Some quick questions:
  • Where do you measure the .7mm preload on the shock?
  • How do you measure the caster?
  • You mention CA on the sidewalls, so I'm assuming this is a carpet set-up. Would it work for asphalt?
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9357 06-05-2017 08:51 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
