Like Tree12Likes
Old 02-24-2013, 09:27 PM   #586
josecarlo1129's Avatar
Originally Posted by edhchoe View Post
I had the same problem on my FGX exotek arms. I used sandpaper to grind away the balls. And used another finer sandpaper to polish them.
Thank you very much for the swift reply sir ed. Can you please hand me some tips on how to snap the ball out of the delrin arms. I tried to loosen it up by soaking then rotating it for sometime and could see the area (around the ball) getting bruised. Thanks in advance for any tips you'll be giving me. Cheers.
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 02-24-2013, 09:59 PM   #587
You may find that just popping the ball out and back in is enough to loosen it up. I have a pivot ball popper tool that works really good at putting the ball in but it is too big to use it to remove the ball. Basically on the pivot balls that my tool doesn't work on I'll make my own makeshift tool that works on the same principal. Use a really long 3mm screw cap head screw through the pivot ball. On the other side stack up some sort of washers or spacers wide enough for the ball to pass through and deep enough for the ball then cap it off with washers and a nut. Then all you got to do is tighten the screw and nut and it will pop the ball right out without damaging anything.
Old 02-24-2013, 10:27 PM   #588
Wow! Thanks! Such a life-saver, sir. I am asking expert's opinion here because I don't want to ruin an expensive part. Cheers and have a great day!
Old 02-25-2013, 04:24 AM   #589
Default Have the same problem!
Originally Posted by josecarlo1129 View Post
Good day!
I would just like to ask if anyone here experienced some stiffness of the pivot ball when mounted on the Exotek delrin arms? I did the proper preparation of lubricating the balls before snapping it. I have no issues on the other arm. How could I resolve this? I even soaked it on a cup of lub to loosen but to no avail. I don't want to take the ball out for I might damage the delrin arm.
I emailed exotek about this. Haven't got a reply yet. TIA.
I just finished building the Exotek 104, I had the same problem with ONE of the front upper arms. One fit perfect and the other was TOO TIGHT. I used the metal pivot balls so I couldn't sand them so I took a BALL SHAPED dremel head and removed some of the material from the inside of the arm where the ball seats. It is important to take a little bit at a time and try the ball, then take a LITTLE more and try again. It took five or six times to get it to a acceptable fit.....Remember you CANT put the material back on so take your time....
TWILL is offline   Reply With Quote
Old 02-25-2013, 05:54 AM   #590
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I switched to the battery back, electronics front setup with the 574/579 combo on carpet. These tires are awesome right out of the package. The car balance was excellent and consistent. Only my lack of practice is letting me down. I used SXT 3.0 for traction compound, full rear, 1/2 fronts. The car had just a little buildup after the run, but much less than everyone else. I felt much more in control yesterday.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 02-25-2013, 06:27 AM   #591
Thank you very much guys for the tips, particularly to edhchoe. It worked, sir. My delrin arm still looks like a virgin, HA. Cheers to all!
Old 03-04-2013, 05:52 AM   #592
Trader Rating: 26 (100%+)
Hey guys I picked up one of these brand new and it's missing the alloy shock mount that bolts to the right side of the pod is it possible to buy another one of just that part
dan200487 is offline   Reply With Quote
Old 03-04-2013, 08:44 AM   #593
Contact Mike @ Exotek through the website. I'm sure he has spares.
Old 03-10-2013, 03:43 AM   #594
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Hi everybody!
Just looking for some tips to improve turn-in (off power) on my F1R. For example, coming off the straight into a right hander, I seem to have too much rear grip, so it's a struggle to get the front to come around.
I'm running the F104 front-end (180mm).
I've gone up to a HPI gold spring on the center shock and 1000 CTS oil in the roll damper with silver AE side springs. I've also got quite a bit of rear pod droop (~2mm).
Overall, the car is a little on the pushy side, but on tighter tracks, it means I have to really slow to get around corners.
I'm normally running 571/572 combo on outdoor asphalt tracks. Today I had to switch to Ride R1's on the rear, since track temps were getting into the 45degC+ territory, and the poor Shimizu rears aren't fans of hotter temps.
Won't get a chance to run it again for a little while, but would welcome any thoughts. I guess I need to take away some rear grip - it seems very planted.
Phil.
PS: It was good enough to land me 3rd at the ACT Titles, but 1st and 2nd were quite a way ahead.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 03-10-2013, 08:47 AM   #595
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by PDR View Post
Hi everybody!
Phil.
Hi, good run.
I can suggest several things;
1 degree front CASTER
Heavier duty servo saver ( Tamiya is too soft- gives up a lot of steering response)
Soft front spring
Move the weight forward
Trim/round corners front tire insert to make insert less firm (mark this set of tires SS and use as a tuning aid by switching from these to to standard insert tires when needed)
Trim 1.5mm off the droop stop on the front arms so that you have more steering throw
A touch more drag brakes (not too much!)
Sauce front tires more/ longer
Happy racing!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-10-2013, 10:07 AM   #596
heretic's Avatar
+1 and of course the same technique can be reversed to pop the ball into the ball cup. See this pic from legendary website Overrc:
http://www.overrc.com/techniques/reg...biellette1.jpg
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 03-10-2013, 12:44 PM   #597
PDR
PDR's Avatar
Originally Posted by MikeR View Post
Hi, good run.
Soft front spring
Happy racing!
Thanks for the ideas. I guess I need to grab the adjustable front end?
Old 03-10-2013, 04:45 PM   #598
MikeR's Avatar
For the win, yes
Old 03-10-2013, 07:23 PM   #599
wheelz's Avatar
Hi everybody!
Phil.
i run 1mm under the front ball stud in the upper a-arm.
0.016 team associated front spring.
tamiya orange main spring
i run very little droop in the rear
10k in the tamiya aluminum damper tube
and associated green side springs in the front hole
4.5mm ride height front and rear
Aaron Lane
Team Associated | Reedy | Jconcepts | Exotek Racing | Airtronics l OCRC l Sticky Kicks l
B6 | B64 | F6 l TC7.1
AE Design Engineer
wheelz is offline   Reply With Quote
Old 03-11-2013, 06:23 AM   #600
My current setup is very good, but could be better.
Rear:
Kit side spring just touching
20K CRC damper grease
12 lb center spring
25 wt oil in the center damper.
1 mm sag, 2mm droop
5mm ride height
Shimizu 579s
Front:
Stock F104 Arms
1.5mm camber
Silver springs
1 mm. droop
574 fronts
Horizontal servo about 2mm back from stop.
turnbuckles in last hole on the steering upright.
turnbuckles parallel to the ground.
Symptom:
Losing steering and going mildly tight, pushing to understeer, halfway through the corner. Rear end is tracking very nice. It feels like the inside front tire is slipping when the weight transfer goes up. Either that or I have too much body roll and am running out of front droop.
Any ideas? I'm thinking stiffer front springs and heavier damping lube for the side to side damper to start.
Tamiya F103 Forum TFR Electric On-Road 2230 Yesterday 05:54 PM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3140 07-24-2017 06:43 PM
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
