Like Tree11Likes
Old 02-08-2013, 10:22 PM   #571
F1Junky's Avatar
Originally Posted by TWILL View Post
Built a F104 Black version 1 and never raced the car. Now they are racing F1 in Toledo and some locals in the Cleveland have cars so I'll try it again. I love the Exotek products so I had Brad @ Paintlab send me what I need to build another car ( I sold the first one), and I look forward to this class and F1 racing in Toledo. I can only hope that we get some people to start running this class at THE GATE!!!!
That's awesome, I actually meet two guys out Toledo at the Track for the UF1 series.
F1Junky is offline   Reply With Quote
Old 02-08-2013, 11:27 PM   #572
MikeR's Avatar
Trader Rating: 14 (100%+)
News- Mark Smyka wins and TQ's Snowbirds while piloting an F1R!
http://www.redrc.net/2013/02/mark-sm...-f1-snowbirds/
http://www.exotekracing.com/f1r-wins-snowbirds/
Great job Mark!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-09-2013, 05:38 PM   #573
Default I need info.
Great job Mark!
I will be starting my Exotek F1 build at the beginning of the week, I was going to build the car with the speedo in the rear but after seeing Sykas car I am having second thoughts. Can someone please tell me the handling difference between having the short pack in the middle of the chassis vs having it towards the rear of the car. I will be running indoor carpet.Thanks
TWILL is offline   Reply With Quote
Old 02-11-2013, 06:00 PM   #574
5th wheel's Avatar
Default f-104
My f-104 with the gt 430 body
5th wheel is offline   Reply With Quote
Old 02-16-2013, 08:19 PM   #575
BadSign's Avatar
Trader Rating: 15 (100%+)
Originally Posted by smyka View Post
Hey guys and gals just figured i would let you know i had a 104x that i converted to a f1r and then put adjustable front end on it. i ran it at the snow bird nationals and i will say hands down this car was the class of the field i tqed by almost a lap 11 sec total lap times were 11.8 to 12.5 and i won the main by well over 3/4 of a lap and i ended up just driving it eay after the 2 minute mark to make sure i didnt crash or break
mark smyka
I have a quick question, what battery are you using? It looked like a CRC from the phot but I wanted to be sure.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 02-19-2013, 06:45 AM   #576
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Anyone have any input on how 574 F3 soft, 579 R3 Soft Pits will work on carpet? I ordered some as I just can get a consistent handle on the 571/572 set.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 02-19-2013, 07:07 AM   #577
I use 571/574 on the carpet in dallas. The F3softs work just fine for us. The 572's work good but they glaze in a few laps and become useless. We are on pretty old ozite and only use black can paragon if that makes a difference.
I could not get enough steering out of medium fronts and have no experience with R3softs.
The 574's almost give me too much front grip and the car needs to be set up carefully to avoid traction roll. But once its dialed in the thing is on rails for 15 minutes.
racer robert is offline   Reply With Quote
Old 02-19-2013, 07:44 AM   #578
Great, I can dial out traction roll. I agree on the 571s. I went from traction roll to push in 5 laps. Then the rears got full of gunk off line. From that point on, the car was a boat. Its frustrating because my FGX comes off with no buildup at all.
Old 02-19-2013, 08:56 AM   #579
edhchoe's Avatar
Trader Rating: 41 (100%+)
Hmm. I noticed the same thing about the 572R. It gets gunk all over it. But I didn't notice handling become compromised. 571F stays relatively clean.
I will try 574f/579r combo next time since I have those as well. I will also test 574f/578r and 573f/578r combos if I have time.
I use SXT 3.0.
Do you file or sandpaper new tires at all?
edhchoe is offline   Reply With Quote
Old 02-19-2013, 09:50 AM   #580
I take the mold seam down with sandpaper, then clean with WD 40 or simple green. I stay off the contact patch so I don't accidentally flat spot my tires. I prefer SXT 3.0 myself.
The building our club is in have the heat off when not in use, so the concrete under the carpet stays at whatever the ambient temp of the air is through the week (50 or 55). We only use the building 3 days a week. The track surface does build up some traction, but it usually takes half a day of heating for the surface temp to change at all. Traction is very dependent on tire temps.
I really miss being able to just drop in and lay down some serious laps.
Old 02-19-2013, 10:58 AM   #581
scr8pn4205's Avatar
I got an f104 v2 and wondering what extra parts are needed to make the f1r conversion work?
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 02-19-2013, 11:18 AM   #582
If you have a V2, the rear pod is not compatible. The conversion is for the original F104 T-bar car and you will need that pod type. All the front end parts swap over directly. The only other recommendation is to use the current roll damper instead of the 2 way shock that come in the F1R kit.
Old 02-19-2013, 11:44 AM   #583
edhchoe's Avatar
The only major different set up one can do to f1r vs f104v2 is the steering system.
I run both f1r and f104v2 set up similarly and they both perform well.
I would not convert f104v2 to f1r.
Old 02-24-2013, 09:14 PM   #584
josecarlo1129's Avatar
Good day!
I would just like to ask if anyone here experienced some stiffness of the pivot ball when mounted on the Exotek delrin arms? I did the proper preparation of lubricating the balls before snapping it. I have no issues on the other arm. How could I resolve this? I even soaked it on a cup of lub to loosen but to no avail. I don't want to take the ball out for I might damage the delrin arm.
I emailed exotek about this. Haven't got a reply yet. TIA.
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 02-24-2013, 09:19 PM   #585
edhchoe's Avatar
I had the same problem on my FGX exotek arms. I used sandpaper to grind away the balls. And used another finer sandpaper to polish them.
Tamiya F104 Pro! NT Electric On-Road 9357 06-05-2017 08:51 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
