Like Tree11Likes
Old 12-17-2012, 04:50 PM   #526
vabroom's Avatar
Thanks, Kevin, good to know. Do you like it better than the stock X1?
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 12-18-2012, 09:25 PM   #527
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Yeah it works better and is smoother around the track. So far Im really happy with making the change.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-22-2012, 09:22 PM   #528
Trader Rating: 57 (100%+)
Is there a PDF of the instructions anywhere?
PROMODVETTE is offline   Reply With Quote
Old 12-24-2012, 04:52 AM   #529
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default Side Dampner
I picked up a used f1r.
The side dampner leaked horribly. I rebuilt it with new orings from associated and still leaks pretty bad. It basically looks like an r5 side dampner but black. Am I missing something or do they just leak horribly?
J.Gonzalez is offline   Reply With Quote
Old 12-24-2012, 06:26 AM   #530
I ordered am f1r a couple days ago, can't wait for it to arrive!
@ J.Gonzalez, probably missing something. I have built many ae side shocks and exotek black side shocks. They can be tricky to bleed the air from but I have never had one leak. Only problem I have run across with the exotek ones is the piston breaking free from the shaft but that would not cause a leak. Before you screw the plastic ends on did you make sure the o-ring is sitting perfectly flat? If not that means there is too much oil in it and the end cap is probably going ok crooked and letting the oil out.
racer robert is offline   Reply With Quote
Old 12-24-2012, 07:40 AM   #531
mkiiina's Avatar
Trader Rating: 69 (100%+)
Iunno if thats a good idea Robert... you are fast enough as it is with that silver can box stock car!
mkiiina is offline   Reply With Quote
Old 12-24-2012, 09:17 AM   #532
Yeah but its a wide car. I want to make sure I'm still fast with a narrow car.
Old 12-24-2012, 10:07 AM   #533
Kevin K's Avatar
I had issue with my shock as well the piston broke off the shaft. I replaced it with the new damper tube from the X1/V2 and it works much better IMO.
Old 12-24-2012, 11:20 AM   #534
The side damper is an AE one done in black...honestly I think this is an interestingly designed shock but has one major design flaw in the cap. Because the threading is so fine the plastic of the cap often strips and can leak or even come completely apart. They really should have used an aluminum collar to hold the cap on like on the top of the CRC shock or Hot Bodies shock. I currently have a damper tube on mine that I took off of one of my pan cars.
Old 12-24-2012, 05:58 PM   #535
edhchoe's Avatar
Trader Rating: 41 (100%+)
My cap must have completely come off also. I couldn't tell what was going on. The car drove fine. LOL. I will clean it up and take a look. I like it soft in the rear anyway.
Edit: The cap had not popped off. It was fine.
edhchoe is offline   Reply With Quote
Old 12-25-2012, 02:07 PM   #536
Would this Tamiya oil filled roll damper work?
http://www.speedtechhobbies.com/inde...roduct_id=1728
Old 12-25-2012, 02:34 PM   #537
edhchoe's Avatar
That will work.
BTW, would that be TCS legal?
Old 12-25-2012, 02:39 PM   #538
On a F1R? probably not... but probably on a F104 being it is made for them and a tamiya hop up option.
Old 12-25-2012, 02:43 PM   #539
edhchoe's Avatar
Shoot. I thought I was on f104 forum. Sorry.
But the part should fit on f1r, right?
Old 12-26-2012, 01:52 PM   #540
liljohn1064's Avatar
F1R is almost a roller. I'm opting for the servo forward/horizontal config. I need to stop by the LHS for 16mm screws and about 6mm worth of spacers for each side. I ended up cracking one of the side spring perches, so much for the don't over tighten warning. The LHS should have those too. I still have to trim down the outer ring on the rubber tire rims, paint the centers, mount and glue tires. My tire truer and a file will make quick work of the rims. I'm hoping to have it on the track by the first weekend in Jan.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
