Old 09-11-2012, 08:57 PM   #451
evochick's Avatar
I finally had my first real run of the F1RW,
Running the same tyres i had been running with the F103, (Pit 0545 rears and 0543 fronts),
I turned off the turbo on the tekin for the first race meeting just so i could get the feel of the car, we are allowed to run 21.5 boosted
Straight away there was so much more rear grip, so much so the understeer was quite bad, I had a set of Medium rears but i couldnít get them run in before qualifying, so i just ran the softís and sucked it up for the rest of the night.
Im also going to order a set of soft fronts to try at the next meeting.
Another Big plus with the car is its braking improvement over the 103 was huge. The F103 was always skatey under brakes, so i had braking turned down to 70%, but with this chassis i can nearly turn it back up to 100%.
Even without turbo and understeering badly, i was still running about the same pace as i was with the 103, so itís a good starting point.
Beth.
UnRetired
evochick is online now   Reply With Quote
Old 09-13-2012, 06:53 AM   #452
Rockin G's Avatar
Hello all, I recently picked up a slightly used F1R with 104 front end. It came with a 21.5 brushless and Shorty pack. It came equipped with Pit Shimzu med front, and hard rear. It is what was working at his track. Some of the fast guys are running that combo at our track too. I will be running on med traction asphault treated with soda. The seller raced with a standard pack but recently installed the shorty. He sold it to me before he had a chance to use it. He has the pack mounted in the rear posoition, but he said the other guys at his track have been moving the battery to the front position to keep the car from looping out on him. Do you concur with this statement, or do you have other recommendations?
Rockin G is offline   Reply With Quote
Old 09-13-2012, 10:42 AM   #453
MikeR's Avatar
Trader Rating: 14 (100%+)
Originally Posted by tudor_47 View Post
Well we are a small race community not that many racers, less than ten and we are all friends so I am pretty sure that none are cheating, besides it is not neccessary with tire sauce, we are running all classes without.
A sunlotion, yes well the sun could be a problem. lol...
Any F1 wheel are alloweed F103, F104, F201, FGX whatever.
Besides the obvious that I have to much grip in front, what is the key factors to a successful setup using foams?
and is there a foam front and rear that are well balanced for F1R? make and number please.
Back in the days when UF1 was wide cars with foam tires I had pretty good success using Tamiya HBR soft rears and either CRC 40's or 45's fronts glued onto f103 front wheels
http://www.stormerhobbies.com/cgi-bi...=ns&pn=CRC2393
http://www.stormerhobbies.com/cgi-bi...=ns&pn=CRC2389
http://www.stormerhobbies.com/cgi-bi...=ns&pn=EXO1122
Beth.
Punch it! Sounds like the car is almost there. A lot of racers would love to have that little bit of push but sounds like you are ready for the soft front tires.
Looks good and nice motor
If your track is med grip I would probably put on the bigger F104 shock with a 35wt oil and soft spring. Moving the battery forward can def help on bumpy fast tracks but try a little bit at a time which the F1R allows you to do. Just use strapping tape in the slots and the battery post at the front of the chassis and receiver to the back. I would go with softer side springs too.
Be sure to at least try the car as is before making wholesale changes- maybe the cars set up is ok for you. A lot of it has to do with tires.
One thing of note- pit shimutzu tires (from my experience) does not like treatment with aggressive traction compounds when it's a hot asphalt track. They simply overheat and get loose. Simply clean with something mild like Trinity Buggy Grip.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-13-2012, 10:50 PM   #454
tudor_47's Avatar
Thanks Mike;
I'll give that a go.
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 09-16-2012, 10:39 AM   #455
5VoltDetonator's Avatar
My F104 Pro does not seem to keep up with the F104 X1's at the track. I am using a novak gtb2 esc and novak 21.5, I know my esc and motor aren't the greatest but I was wondering if motor and esc make a huge differance? It seems to me that a better handling car make a bigger differance. Will the gtb2 esc fit on the F1R conversion using a standand battery pack? Any used F1R conversions out there for sale?
5VoltDetonator is offline   Reply With Quote
Old 09-16-2012, 11:42 AM   #456
texastc's Avatar
its a tight fit, and you have to mount the GTB2 on its side between the battery and the link on one side. But I used it like that for a while. I have since went to a shorty pack, and that, I believe, is the way to go. As you can move the battery forward or back, and have room to mount the esc and rx in the open spot.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
texastc is offline   Reply With Quote
Old 09-17-2012, 12:42 PM   #457
Rockin G's Avatar
Please excuse my ignorance. I bought my F1R used and thus didnt get any instructions. I have got it figured out how to raise the rear eide height, but how do I raise the front? I have the adjustable front arm set. http://www.exotekracing.com/f104-adjustable-arm-set/. I am only sitting at about 2 mm right now. The track we are currently running is a parking lot track. There are, shall we say, inperfections on the surface? It is not exactly a smooth ride. There are a couple guys out there that have their cars pretty dialed and they said I need to raise my height. Of course neither of their F1's are the exotek, so they cant help.
Before I knew any better on the rear, I just tightened the rear spring on mine, thinking it would raise the height. All that did was make my car loose. Like I was driving on ice. I had to slowly apply the throttle or it would loop. I am guessing it was a droop problem since I had it set higher at the pivot than at the rear. I changed the side springs and adjusted tension on the rear spring, moved the battey forward ESC to the rear, etc... all still slippery. As a reminder incase you have other suggestions other than what Mike R gave me above. Still need to get the bigger 104 shock. Still runing Pit med front, hard rear. Like the other fast guys at my track. Tried both with and without White can Paragon...Day was only in the 80's and overcast all day. Also hearing about Ride tires???
Old 09-17-2012, 01:06 PM   #458
Move the spacers on the front axles around to get the front ride height you want.
Old 09-20-2012, 12:34 PM   #459
MikeR's Avatar
Default F1R
Congrats Steven Jackson on the Radiopost Grand Prix F1 rubber class win!
http://www.exotekracing.com/steven-j...st-grand-prix/
Old 09-20-2012, 01:33 PM   #460
texastc's Avatar
Way to go Mr. Jackson
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
Old 09-20-2012, 02:16 PM   #461
I convinced, I will be getting one of these asap. Is there any video from that race?
Ya know instead of telling us how great a good driver can do with one of these, I bet you'd sell more if you gave one to a not very good driver like myself - then I could tell you how much better I am with it. jus sayin seem like a good Idea to me- lol
Old 09-20-2012, 02:18 PM   #462
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
TQ RC RACING in Chino, California
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-20-2012, 02:19 PM   #463
texastc's Avatar
I'm a terrible driver, I give him updates all the time its faster than me.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
Old 09-21-2012, 05:57 PM   #464
evochick's Avatar
I have some more setup tips for extremely low grip surfaces with the F1RW,
The other track i race at is a brushed concrete surface, and F1's have always been a challenge there,
I was playing around with the side springs and i found that when i wound them up a few mm, the traction improved but the car tended to wander around making it very hard to drive, but using the forward spring setting with the spring just touching did the job.
I also installed a TRG heavy steel axle to replace the carbon one, its only 30G heavier then the carbon one, but having the weight directly on the axle helped with the grip as well.
Beth.
UnRetired
Old 10-02-2012, 05:05 PM   #465
5th wheel's Avatar
Default OH NO !!
Nobody here
5th wheel is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 09:28 AM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
