Old 07-24-2012, 08:24 PM   #406
cocojam's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Big Daddy Cool View Post
I'll look into that. thanks!
Yes, the Exotek manual recommends that or silicone sealer. I dabbed on some of the latter on my springs and it looks like they will hold them in place. I'm also thinking of tethering the springs with thin fishing line so I won't lose them even if they still pop off. It wouldn't be such an issue if we had these parts readily available in our area though.
If you want to try out the magnets, I have some small neodymium disc magnets that might do the job. Just let me know. Im also doing my own modification on my 104X1 upper front suspension arms which are very much prone to bending. Got the idea from the Exotek 104 adjustable arms conversion set.
SJF01 - F103RM - F104Pro - 3rF109 - TB EvoV
Wild Willy 1 - Road Wizard - Can-Am Lola
Dynamic 1500 - Wilga 2000 - Zephyr V70 - FMS FW190 - TWM Skylink
TWM Katana - Zeta Horten BV38 - Freewing Pandora
cocojam is offline   Reply With Quote
Old 07-29-2012, 11:03 PM   #407
Trader Rating: 15 (100%+)
Default Front end
Has anyone tried a longer king pin like 36 mm to be able to adjust the angle of the arm? And if so what was the part number for it
AARON YOUNG is offline   Reply With Quote
Old 07-30-2012, 05:53 AM   #408
robk's Avatar
Trader Rating: 22 (100%+)
If you want to adjust upper arm angle, remove the 2 spacers under the camber setting plate, and mount it directly to the lower arms. Then use spacers to set upper arm angle.
Old 08-01-2012, 05:30 PM   #409
5th wheel's Avatar
Has anyone tried out the Ride tires yet on asphat .. type A soft on a f-104W..is that a good tire for parking lot running
5th wheel is offline   Reply With Quote
Old 08-02-2012, 07:30 AM   #410
tudor_47's Avatar
A pictyure of my F1R in the wet...
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 08-02-2012, 09:39 AM   #411
MikeR's Avatar
Trader Rating: 14 (100%+)
103 Ride tire's are ok but I dont think they have as much grip or steering as Shimizu PS-0541 (F1-S F103) /PS 0542 (R1-H F103).
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-04-2012, 05:28 PM   #412
5th wheel's Avatar
Default Exotek
Thanks. Mike just got my Exotek put together looks good But the one piece that holds the side spring on top is stripped out were you cant adjust it..it came in the kit that way..
Old 08-06-2012, 05:45 PM   #413
MikeR's Avatar
For quick service shoot Exotek an email
Old 08-06-2012, 05:57 PM   #414
scribbler's Avatar
I was wondering what people thought about the single bell crank setup, instead of the more traditional servo set up?
What could the possible benefits be. Your just moving weight further back in the chassis.
Opinions please
scribbler is offline   Reply With Quote
Old 08-07-2012, 05:55 PM   #415
5th wheel's Avatar
Thank you.Sure will.I will try and get to it sometime this week.
Old 08-07-2012, 11:56 PM   #416
iPearl's Avatar
Trader Rating: 94 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
Is there a way of EXO104 users to get the Lower deck somehow ?
I didn't like the F1R feeling on our tracks so i prefer to stay with my EXO104 Lower deck.
I would want one as a spare ...
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 08-08-2012, 01:08 AM   #417
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Haven't got my F1R handling the way I'd like (being polite), so I've embarked on a complete rebuild.
My home track is outdoor, low-medium grip asphalt with a straight of around 32m.
Two items I'd like some feedback on:
  • My current weight is 1100g. 650g over the rear wheels and 450g over the front. Is that too rearward biased?
  • When I removed the motor mount, I noticed the pod movement wasn't even left-to-right. On further inspection, I discovered that the pivot ball holder had two dimples on the underside where the two smaller screws go in. Not sure of the terminology, so I've attached a picture. The two screws that go through "A" have caused dimples at "B", stopping the assembly from pivoting evenly (the dimple on one side is bigger than the other). I have a spare/replacement. Should I partially pre-drill these holes, or use a washer to stop them going in too far?
To clarify, the two main handling issues at the moment:
  • the car is reluctant to turn in
  • the car is unstable in faster corners. Has a tendency to hook at midcorner if it's carrying much speed.
These traits are visible with both rubber (571/572) and foam tyres.
T4 | X1 | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 08-08-2012, 01:14 AM   #418
PDR
PDR's Avatar
Oops - double post
Old 08-08-2012, 01:24 AM   #419
Hugh Jazz's Avatar
Phil.
If you take the sides springs off, does the pod feel free left to right?
Are the links free. the screws on the links that secure the pivots should not be tight just nipped up enough to stop them falling out.
I can have a look at it for you at CC if you would like
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 08-08-2012, 01:30 AM   #420
PDR
PDR's Avatar
Dan - thanks.
The pod is reasonably free (not having much experience with link cars), but movement is not even. The link screws don't appear to be overtightened, in fact, there is the minutest amount of play (not really visible, but can be felt) on at least one of them.
If I don't get it sorted before CC, I'll bring it along. Got my own demons to sort out on the tourer
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 Today 07:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 09:28 AM
Tamiya F104 Pro! NT Electric On-Road 9327 01-11-2017 01:04 PM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
SEO by vBSEO 3.5.0
