Old 07-16-2012, 04:38 PM   #376
5th wheel's Avatar
hello everyone
i have the F104w wr1 wolf.
dose anyone know if you can raise the ground clearance on the front of this car?
and what type of tires would you recommend for this car on asphalt parking lots
all it wants to do is spin out with box stock tires.. i would like to use rubber tires
other than foam.i do have a high traction t-bar on it and the diff is tight.as the manual said to do.nothing but spin outs any help here.. thanks
5th wheel is offline   Reply With Quote
Old 07-16-2012, 10:42 PM   #377
Kevin CBR's Avatar
Originally Posted by 5th wheel View Post
hello everyone
F104W is same front end as the F103. Can not raise the front ground clearance other than running a taller tire compared to a shorter tire (if you are running foam). If you want to run rubber tires, you will need to order the F103 tires. TQ Racing (http://www.tqrcracing.com/) stocks F103 tires. When I ran my F103, I used the Pit Shimizu rear tires and the Ride front tires. For me, the Ride tires gave better steering than the Pit Shimizu tires. If you are running on a medium to low grip outdoor track, loosen the diff a little. A tight diff is best for high traction tracks (asphalt or carpet). I used the Ride #24000 front tires and the Pit Shimizu #PS-0545 rear tires with the Ride # 25000 front rims and the ride # 25001 rear rims.
Panda
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Kevin CBR is offline   Reply With Quote
Old 07-17-2012, 03:32 PM   #378
robk's Avatar
Trader Rating: 22 (100%+)
hello everyone
Assuming your not racing Tamiya races...
You can take a dremel and remove material from the bottom of the steering arm. Then add a spacer on top of the steering arm to basically lower the arm. So if you take off 2mm, you add a 2mm spacer back on top of the arm. This should get you 2mm more clearance
Old 07-17-2012, 05:06 PM   #379
5th wheel's Avatar
ok thank for your help
Old 07-17-2012, 05:07 PM   #380
5th wheel's Avatar
ok thank you also for your help
Old 07-17-2012, 08:05 PM   #381
idbdoug's Avatar
Trader Rating: 33 (100%+)
Can you run the f1r in a wide configuration? Or if want to run wide should I get the ultra conversion?
Idbdoug
idbdoug is offline   Reply With Quote
Old 07-17-2012, 08:26 PM   #382
texastc's Avatar
Idbdoug
I run the F1R in wide version. Ill let you drive it Saturday, and you can try Roberts Ultra. Wheel base is a tad longer on F1R.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
texastc is offline   Reply With Quote
Old 07-18-2012, 03:12 AM   #383
idbdoug's Avatar
thanks.
idbdoug
Old 07-20-2012, 06:19 PM   #384
5th wheel's Avatar
i have the wr1 wolf f104w on a exotek chasis can any one give a new guy a set up fore asphalt on rubber tires need to learn how to do this stuff motor is novak 21.5.. I got a 63 spur and 22-t pinion metric...edge ESC..thanks
Old 07-20-2012, 06:35 PM   #385
Start here:
Tamiya F104 Pro!
Then go here:
RIDE & SHIMIZU F1 RUBBER TIRES
That took about 2 minutes using the search button. Whew! Happy reading.
TwoWheel is offline   Reply With Quote
Old 07-20-2012, 07:13 PM   #386
texastc's Avatar
Set it up as per manual first. the 0542 Hard rears and either 0544 soft or 0547 medium fronts. For 104W width cars. Same compounds as the 104 tires but for the wide cars. Most adjustments you will probably make will be side springs.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
Old 07-21-2012, 08:09 AM   #387
tudor_47's Avatar
Been using my F1r all season now, well 4-5 outings and as many races, to my dissapointment I always seem to have big isssues with rear grip.
I am now running F104W(F103) foams (they worked very well for a friend on his F103)
I have the straight line speed and the car feels OK in my hands on the bench but it will not corner as it i supposed to,
when I get into the corner the car spins out.
We are running 13.5T motors an our straight is some 50 meters.
Car setup.
front
F104 arms with RSector widening kit (widest)
rear
F104 motor pod, side damper with 20Wt(?)
main damper
side spring harder than default, had to try something, barely touching the links
F104 diff, rsector widening kit
body: Mclaren (tam#51430)
It feels like the car looses all traction in the rear as soon as it comes up in speed.
I am surrounded by other F104, F109 FGX and F103 and the all work OK with the motor/speed I am wanting to run.
So far I have pulled the car apart a few times and redone the links side damper/main damper (have fixed issues with stuck links and not good side damper) but car is still not working OK.
I have tested many different types of foam wheels...and some rubbers too
But if anyone know of a foam combination that works in a little quicker speeds I am up for testing another set.
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 07-21-2012, 10:09 AM   #388
robk's Avatar
Car setup.
front
rear
main damper
What front end is everybody else running?
Old 07-21-2012, 08:20 PM   #389
texastc's Avatar
Im not sure of the terminology, or of my theory. But with the with the widetrack front end at max width, could that be the issue? Help me here but with the upright still being at 180mm and the axle/wheels extended outward, wouldnt that cause scrub/drag/badthings? At 190mm may not be an issue, but thats almost an inch more of axle. I know what Im trying to say, just not sure of how t get it across, Hopefully someone is as demented as me and can translate. thanks. back under my rock.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
Old 07-21-2012, 09:09 PM   #390
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
as ttc said, with the widest front end, you will get added wheel scrub from slip angle when the tires are turned. its only 3/8" wider on the axle(per side).
what camber and spring are on the front end?
try to lighten the side dampening of the rear pod(free it up), add a small amount of droop and make sure the chassis is level in the middle of the car at ride height. if the center is higher than the ends(front and rear), it can become darty.
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Tamiya F103 Forum TFR Electric On-Road 2205 03-20-2017 02:30 AM
Tamiya F104 Pro! NT Electric On-Road 9345 03-16-2017 12:15 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
