Old 05-23-2012, 08:09 AM   #346
May be just a club race, but this was my first race with the F1R. I had built the car months prior... but didnt know what i was doing apparently. This Second attempt seemed to be much more driveable.
http://www.uf1houston.com/index.php?...tml/_/results/
621clay is offline   Reply With Quote
Old 05-23-2012, 11:13 AM   #347
MikeR's Avatar
Trader Rating: 14 (100%+)
Originally Posted by tudor_47 View Post
Thanks Mike!
I have a set of F103 foam in the mail from Ebay, so that should hopefully sort things out. I have also been looking at the rsector widening kit, but I find it somewhat expensive. A F103 front end will do the trick but then I need a new body so that will have to wait.
13.5 should be OK, drove last year with my old F109 with 13.5T. Track is large, OK to drive 1:5 cars on.
i too hope for higher track temp!
The spring, I'll see if I can get my hands on a softer one.
Again Thanks Mike!
Any time
Originally Posted by [RC10TC] View Post
Got my f1r last week and raced it at my local track on Sunday. All I can say is WOW!!!
this is the best handling f1 rubber car that I've ever driven. I was using the shimizu front soft and rear hard tires with stock inserts. Car handled great!
I hope this will revive the f1 class around here.
Good job fellas!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-23-2012, 02:40 PM   #348
Trader Rating: 24 (100%+)
Thanks for the help folks ! Mike, fellow club member buying a new F1R conversion after seeing mine. I'm a hell of a salesman considering I haven't run this car yet !! Also, just got my new arms and springs in the mail. Great service !!
Anybody using that TRG side shock instead of the 12R unit on their F1R ?? Only found one comment in previous posts.
Regarding the upper mount, the stock F104 unit only provides for 0 and 1 degree camber. Anybody share opinions on the 3R or Yeah Racing alloy units which allow adjustments up to 3 degrees ?
BTW, anyone know whats happened with Chevron ? Seems most of their bodies are unavailable.
Evoracer is offline   Reply With Quote
Old 05-24-2012, 12:10 PM   #349
MikeR's Avatar
Thanks Mike!
Again Thanks Mike!
Make sure when you go to softer springs that the center chassis does not bottom out. May need to raise ride height and preload collar.
Old 05-29-2012, 04:32 PM   #350
Default what version do i have?
I bought this over the weekend up at the Ventura Race track. In the parts bag it has the small blue shock and other graphite pieces.
Thanks Brian
bribtb is offline   Reply With Quote
Old 06-05-2012, 06:29 PM   #351
JayL's Avatar
Best Body?
Best Front wing?
Best Rear Wing?
I had heard F60 body(51397) and newer mclaren wings(51430), true?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 06-05-2012, 11:27 PM   #352
Trader Rating: 21 (100%+)
Thanks Brian
Uh wow, interesting front end. It's definitely not an F1R though. I don't think i've ever seen an exotek chassis with stepped sides like that.
silencery is offline   Reply With Quote
Old 06-05-2012, 11:29 PM   #353
Originally Posted by JayL View Post
Best Body?
Best Front wing?
Best Rear Wing?
Generally a matter of opinion. In my limited experience, F60 seems to be the most popular.
Old 06-06-2012, 12:41 PM   #354
robk's Avatar
Trader Rating: 22 (100%+)
I have run both back to back. Maybe, MAYBE, the McLaren wing has some more downforce, but it might just be my imagination.
Old 07-06-2012, 09:42 AM   #355
macavant's Avatar
Trader Rating: 61 (100%+)
New F1R conversion checking in. This time it's for a F103GT. Tracktime shakedown is planned for tomorrow over @ the NorCal hobbies asphalt track. I opted for the Exotek alloy twist nuts for the removal of the rear damper mount - highly recommend this setup.
Still enough clearance even with the biggest LiPo pack I have :
likes the oldskool RC action...
F103.F201.F103GT.F1R3☆F104WGP.F1Ultra☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 07-06-2012, 09:57 AM   #356
pejota's Avatar
keep us posted... i have an F103GT sitting around in a box...
pejota is offline   Reply With Quote
Old 07-06-2012, 10:48 AM   #357
MikeR's Avatar
Best Body?
Best Front wing?
Best Rear Wing?
I prefer the F60 body. Much easier to build, paint and sticker up and possibly more stable.
It is an Exotek- EXO104 (discontinued) that has been dremeled a bit.
Old 07-06-2012, 12:01 PM   #358
JayL's Avatar
thanks Mike! and Thanks for my killer parts you just sent me
Old 07-06-2012, 12:36 PM   #359
MikeR's Avatar
Thank you for letting me send you the parts!
Old 07-07-2012, 01:32 PM   #360
I'm running into some issues with the front tires (Shimizu 571/72) skipping on high-speed sweepers on carpet. Any suggestions for this? Is damping the kingpin with a heavier grease the general solution?
I know it may not be a problem specific to the F1R, but just thought i'd throw it out there.
Thanks!
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 09:28 AM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
