Like Tree12Likes
Old 03-07-2012, 09:48 AM   #286
Originally Posted by MikeR View Post
Yes, the the rear posts- moved forward for improved motor clearance.
Thanks!
With the battery in this configuration what holds the battery in place in the front and on the other side?
Old 03-07-2012, 01:37 PM   #287
BadSign's Avatar
Trader Rating: 15 (100%+)
Default servo choice
just curious, what servo do most of you use?
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 03-07-2012, 02:07 PM   #288
texastc's Avatar
I'm using a Savox 1251
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 03-08-2012, 10:40 AM   #289
MikeR's Avatar
Originally Posted by silencery View Post
Looking forward to the rims. Any rough ETA MikeR?
I won't hold you to it, but if there's any news, I'd like to know so I can decide if I should just mount to Tamiyas for now.
Thanks!
Looking at late April early May if testing goes well.
There is a carbon bar and post on the front side.
KO 2143. The best low-pro
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-08-2012, 01:29 PM   #290
Cool thanks! Order placed
Old 03-08-2012, 09:12 PM   #291
robk's Avatar
Trader Rating: 22 (100%+)
K to tha izz O
Old 03-08-2012, 09:58 PM   #292
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Do you have to put a fuse inline with that servo also? I have the KO PDS-2123FET, on my corally rdx had to put a fuse inline with it.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 03-09-2012, 09:58 AM   #293
MikeR's Avatar
It is just plug and play for any of the brushless esc that I own.... LRP, TEKIN, SP, Novak
Old 03-09-2012, 05:21 PM   #294
Now that I have my Exotek FGX-EFX chassis on the way I had another question...just a minor thing really...but I noticed on the FGX-EFX the lower chassis extends to just past the front suspension while the FGX and McKune chassis stops the lower chassis plate right below the front suspension...was there a specific purpose to extending it? I'm guessing probably to help brace the nose a bit better...
Old 03-10-2012, 02:03 PM   #295
BadSign's Avatar
Originally Posted by robk View Post
K to tha izz O
Thank you, gentleman. Now, anyone got a spare they're willing to give away
Old 03-11-2012, 06:38 PM   #296
dfiantii's Avatar
Are you guys wiring your rides with 12/14 or 16 gauge wire?
TLR 22 2.0
Old 03-11-2012, 06:47 PM   #297
Victor Vector's Avatar
16 is plenty big enough for the amp draw from a 21.5.....
Jacko
Jack Balchin.
Timezone Hooligan
IBEW Local 48-retired (Definitely, great pension.)
Victor Vector is offline   Reply With Quote
Old 03-11-2012, 10:41 PM   #298
Odin544's Avatar
Trader Rating: 93 (100%+)
Jacko
+1 All I used in mine was 16 ga from tqracing. Super flexible stuff.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 03-15-2012, 10:41 PM   #299
MikeR's Avatar
Yes, to add extra bracing to the nose area specifically to try and reduce any tweak. The more secure the ends of the top plate are the more likely flex will be generated at the center of the top plate which is ideal to reduce tweak. Of course it will make the nose more durable as well.
Old 03-16-2012, 07:44 AM   #300
ChadRacing's Avatar
Hello, i was wonder if you all can help me out. I am trying to help a fellow racer with his F1R. We are running on a High-bite carpet track that is roughly 90x40. For about the first 3 mins of the race, the car is planted very well with fast times around 11.1-11.4 secs. The last 3 mins, the front tires fade out extremly and cause a push thru out entire corner. These lap times would be anywhere between 12.5 - 13.0 secs. Loss of about 1 sec per lap. What would cause this? And what setup advice do you have if not a setup for the chassis.
Here is the setup we are running as of now:
F1R Chassis w/F104 front end
15wt oil in side shock
i think 15 or 20 wt center shock with tamiya white spring(not sure on lb)
Med front springs on king pins
soft rear springs
2.5 caster
roughly 1 degree total of toe out
Pit tires 572 and 574
I am trying to use my car as a comparison to set his up. I am running avg of 10.9 - 11.3 sec laps thru the whole 6 min race on same track.
This is my setup:
F104 X1
Med front springs
Soft center spring
CRC 5000 tube grease on dampner
High-bite t plate
2.5 caster
1 deg total toe
pit tires 571 and 572
Thanks in advance for any help
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Tamiya F103 Forum TFR Electric On-Road 2230 08-18-2017 05:54 PM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3140 07-24-2017 06:43 PM
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
