Like Tree11Likes
Old 02-21-2012, 05:36 PM   #241
MikeR's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Taman View Post
Which rear offset gives you 5mm ride height, is it S1,S2 or S3? Also on the front whats the combo of F2,F3,F4 that gives you 5mm front ride height?
I've looked in the F60 manual bit can't see where it explains the heights
thanks
There is no definitive answer for that. Depends on your tires, battery weight, spring selection, on and on. You just need to go by trial and error till you get the right height.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-21-2012, 05:40 PM   #242
MikeR's Avatar
Originally Posted by BadSign View Post
Can you run a diffuser on the F1R, and which one? Zen, TRG, or ABC?
You can yes if it's for the F103. Cut and install as shown. I've found though they are a bit fragile. Seems the polycarbonate they use seems brittle...
There are 2 extra holes on the rear of the F1R pod plate. You can attach the difuser there as well if you trim them to fit- including the stock hard plastic F104 difuser.
Old 02-21-2012, 05:57 PM   #243
Trader Rating: 37 (100%+)
Exotek,
So if I had a box stock F104 and bought an Exotek chassis kit F1R would the below parts be all that I need extra to make it look like the one pictured on the Exotek website?
http://www.exotekracing.com/f1r-conversion/
Tamiya F104 Alu. Diff Housing Set
[TA-54158]
Tamiya F104 Alu. Motor Mount R/L
[TA-54166]
Tamiya F104 Clamp Type Wheel Hub
[TA-54240]
Tamiya F104 Carbon Rear Shaft
[TA-54162]
Nexus is offline   Reply With Quote
Old 02-21-2012, 06:00 PM   #244
texastc's Avatar
I run the tamiya stock f104 diffuser.
Exotek F1Ultra Tamiya TRF101 SpeedPassion LM1 and SP1 and another Exotek F1Ultra on the way.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
TCdoesRC
texastc is offline   Reply With Quote
Old 02-21-2012, 06:23 PM   #245
MikeR's Avatar
Originally Posted by Nexus View Post
Exotek,
[TA-54158]
[TA-54166]
[TA-54240]
[TA-54162]
Hello!
Looks like also;
Exotek FRONT BULKHEAD HEX SCREWS- TITANIUM
Tamiya 54154 Carbon Reinforced Uprights - Front F103 / F104
Tamiya 54249 Aluminum Turnbuckle Shaft - 3x32mm (2pcs)
Tamiya 53901 F104 TRF DAMPER
Tamiya spur gear spacer adapter
1/10 SPUR GEAR WITH 1/8TH DIFF BALLS (68T 48 PITCH KIMBROUGH IS A GOOD START)
EXOTEK F104 SERVO MOUNTS
Tamiya alloy servo saver #?
I think there are some steering ball ends needed but I'm not sure what the stock F104 has included.
Old 02-21-2012, 11:20 PM   #246
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
So what is the effect of shorter or taller spacer?
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 02-23-2012, 09:26 AM   #247
MikeR's Avatar
Hi, which spacers? Spacers are all over this car
Old 02-23-2012, 09:27 AM   #248
MikeR's Avatar
duplicate
Old 02-23-2012, 09:28 AM   #249
MikeR's Avatar
Stephen Jacksons series finale winning car;
Old 02-23-2012, 10:11 AM   #250
Send a message via ICQ to JiuHaWong
Any 190mm conversion kit coming?
JiuHaWong is offline   Reply With Quote
Old 02-23-2012, 10:17 AM   #251
If there is...please just use a 5mm spacer on the non-diff side of the rear axle...I don't want to have to replace my Qteq clamping hub
Old 02-23-2012, 01:20 PM   #252
MikeR's Avatar
I'm working on something simpler- +4mm off set molded wheels for the F104. They will be more Shimizu friendly as well.
Old 02-23-2012, 01:53 PM   #253
very cool...any time frame?
Old 02-23-2012, 10:36 PM   #254
tudor_47's Avatar
perfect!
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 02-23-2012, 11:55 PM   #255
Will this be for the front and rear?
Either way I'm in put me down for 2 sets (8 wheels)
Darnall is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9357 06-05-2017 08:51 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 08:28 AM
