Old 02-20-2012, 01:25 PM   #226
Originally Posted by MikeR View Post
You do have the good stuff then
This is what I do for more steering;
Zip tie the servo saver- tightens up the spring for more initial steering
Add more front camber
Zero front toe in
Add a little bit of rear pod droop
Soft front springs
As a last resort I move my shorty pack forward.
You can also go heavier on the side springs and top spring but I think it makes the car too aggressive and inconsistent for asphalt.
How much camber have you found works best with the F1R...I was running 1* and just installed 2*...but am considering taking it all the way up to 3*
Old 02-20-2012, 01:55 PM   #227
MikeR's Avatar
Trader Rating: 14 (100%+)
I'm up to the max- 2.5 on the option Tamiya block for some tracks.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-20-2012, 02:03 PM   #228
MikeR's Avatar
We had an excellent day at UF1 series finale over the weekend. Congrats again to Steve Jackson for getting TQ and scoring max points by winning all 3 mains. I think it's safe to say the R-sector 190 widening kits are the real deal- too bad they only just came out last week.
Here is the A2 main. Exotek F1R is the TQ car in white and red. The race gets really exciting at the 8 minute mark
+ YouTube Video
Old 02-20-2012, 02:26 PM   #229
Ah ok...I'm using the 3Racing block which doesn't have the half degrees...maybe I will go 3* then. Thanks!
Old 02-20-2012, 04:06 PM   #230
Can someone provide the part no to those flex links. Would like try the on my F1R. Thanks,
Originally Posted by InspGadgt View Post
Because I don't have to mess with springs. The flex plates work very well. I don't worry about springs collapsing or having to set each side just right...just bolt them on and go. If you look closely back at the pic I posted you can see them...no one seemed to notice
jgee888 is offline   Reply With Quote
Old 02-20-2012, 08:41 PM   #231
Trader Rating: 36 (100%+)
+ YouTube Video
Great video!
Exotek,
So if I had a box stock F104 and bought an Exotek chassis kit F1R would the below parts be all that I need extra to make it look like the one pictured on the Exotek website?
http://www.exotekracing.com/f1r-conversion/
Tamiya F104 Alu. Diff Housing Set
[TA-54158]
Tamiya F104 Alu. Motor Mount R/L
[TA-54166]
Tamiya F104 Clamp Type Wheel Hub
[TA-54240]
Tamiya F104 Carbon Rear Shaft
[TA-54162]
Nexus is offline   Reply With Quote
Old 02-20-2012, 10:34 PM   #232
Taman's Avatar
Trader Rating: 64 (100%+)
I'm at Step 11 in building my F1R - where do you get the "Stock Spacer" from (goes onto "H" for the front shock ball stud mount)? I can't seem to find it in my F60 kit and it's not the sort of part I have lying around.
Toms 84C, Nissan R91CP, Porsche 956, TRF 417 V5.
Taman is offline   Reply With Quote
Old 02-20-2012, 10:46 PM   #233
Odin544's Avatar
Trader Rating: 93 (100%+)
haha I never could figure out what stock spacer they were talking about. I ended up just using some aluminum ballstud shims. I'm using a screw from the bottom side with shims to adjust height and Tamiya (53599) 5mm Alum Ball Nut.
Odin544 is offline   Reply With Quote
Old 02-20-2012, 10:51 PM   #234
Taman's Avatar
cheers, any pariticular height the "Stock Spacer" needs to be?
Old 02-20-2012, 11:05 PM   #235
Odin544's Avatar
No, Its a tuning aid. You may run more or less than the next guy. I've got mine raised a little front and rear so that the center shock spring wont rub on the side damper.
Old 02-20-2012, 11:16 PM   #236
Taman's Avatar
Great thanks for that! I ended up using 3 blue washers I had spare from my RM-01 build as I didnt need them for the servo mounting.
This is a great looking car, can't wait to drive it.
Old 02-20-2012, 11:21 PM   #237
Odin544's Avatar
http://www.bmiracing.com/webstore/ca...de0fe52ec63070
Old 02-20-2012, 11:45 PM   #238
Originally Posted by Odin544 View Post
I'm not sure the long ones are on the site yet as the ones I have are from a prototype car...the next version of the Copperhead 12 and 10 will have the longer links that are the same length as the AE ones. You will also need the pivot balls and pivot ball housings and the front stand offs. I asked on the Copperhead thread if they would have link kits available so you can put them on other cars and Jason said he would. Also with mine I used an old set to cut spacers and lowered the links so it will better clear the body...without lowering them you'll have as much clearance as the stock links...but lowering them significantly decreased how much I need to cut out to clear the body.
Old 02-21-2012, 02:39 AM   #239
Taman's Avatar
Which rear offset gives you 5mm ride height, is it S1,S2 or S3? Also on the front whats the combo of F2,F3,F4 that gives you 5mm front ride height?
I've looked in the F60 manual bit can't see where it explains the heights
thanks
Old 02-21-2012, 06:16 PM   #240
BadSign's Avatar
Trader Rating: 15 (100%+)
Default Diffusers?
Can you run a diffuser on the F1R, and which one? Zen, TRG, or ABC?
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9331 02-06-2017 09:32 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Carpet Racing in Southern Illinois!!! jrp Wisconsin & Illinois Racing 3139 01-13-2017 09:28 AM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
