Exotek F1R
#1621
Anyone know if the F1R2 is allowed on the Tamiya track??? I've added the IFS and it barely is a Tamiya any more. Interested in joining you fellas for the Tuning Haus race but would like to get some track time in first...this being my first F1 and all
#1623
Bring it out to the Tuning Haus race. Should be pretty easy going and a good F1 learning experience!
#1625
http://www.f1italianseries.it/#!New-...f2f7a6a92d7b65
Looks like the IFS will be illegal in europe. I hope it doesn't catch on here .
#1626
The whole reason F1 caught on was the scale realism of the class. What is more scale and realistic than a working suspension?
#1628
Had my fist crack at F1 this weekend at the Tamiya track. Took a couple of laps and it was.....AWFUL! I was spinning out everywhere. So my friend came up to me and told me you need to drive it differently. You mean I can't drive it like I stole it??!!!!!! So I hand him the controller and takes a couple laps. Gives me back my controller and says the car seems fine. GRRRRRR!!! So there is much I need to learn...especially throttle control...and to not yank the throttle while turning. By the third pack I was getting the hang of it. F1 certainly takes finesse. By the 5th pack my lap times were coming down but consistency wasn't there. Haven't driven on-road in ages but it was fun as hell! And the scale realism was so cool. Can't wait for this Saturday!!
#1629
Pit by Aaron and I if you wish. We usually pit under the awning by the ramp of the drivers stand.
#1630
Currently I'm running Aaron's setup with 20wt oil, flouro spring and 1mm of pod droop. I want to lock up the rear just a tad more. Will adding more rear droop help much? Or should I try to play with the front end and try to take out steering instead?
#1631
Thanks for the invite Mike! I'm going to try to stick to F1 at least for the winter series and go from there.
Here's my Tamiya track set up;
https://app.box.com/s/tt4jthl1sxlkzl12cx5ubwg06fg0w5so
#1632
I was running at the Tamiya track with the "kit" front tires(belt removed) and 72 rears.
Hmmm...Looking at your setup there are some big differences between Aaron's. You're running the short wheelbase? Also how do I measure front droop? Or rather where should I measure front droop?
Sorry for all the questions. Just trying to get up to speed as quickly as possible since I've had very limited track time. After this I'll be running carpet so all this will be thrown out the window haha.
#1633
Short WB gets better on power traction but also better mid corner rotation.
I measure under the lowest part of the front arm- no wheels, chassis on the board.
#1634
What tires are you running? Was it asphalt or carpet? Tires are huge deal
Also crc blue is 20k, yes?
thanks!
