Old 12-07-2004, 06:15 AM   #1
koabich's Avatar
Send a message via Yahoo to koabich
Default Belts...how tight or how loose?
Hey guys. I have been running a TC3 for the last 3 years or so. For this race season, I have switched to a 415.
Just wanted to know how tight or how loose most people run their belts.
I have been running my belts tighter for stock that I do for mod.
What do you guys think?
koabich is offline   Reply With Quote
Old 12-07-2004, 06:24 AM   #2
You want to run your belts loser for stock than modified as stock isn't as powerful so it needs as less drag to get a better top speed
Chazz is offline   Reply With Quote
Old 12-07-2004, 06:26 AM   #3
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
typically, they are run tighter for mod than stock. the common method of finding your setting is to go loose until it just skips, and then go tighter one click/notch.
you're gonna get mixed opinions, as there is a point of diminishing returns when going excessively loose. too tight obviously robs power, but too loose allows play or resonance on the loose leg, and you can risk rolling the belt over in an impact as well.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 12-07-2004, 11:32 AM   #4
Cole Trickle's Avatar
I'm running them as loose as possible, without skipping. This is for stock. I've never had any problems with my belts.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 12-07-2004, 02:09 PM   #5
Speedie's Avatar
Schumacher says they have been getting better lap times with the belts normally set rather than really loose.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Tight track RKeasler Electric On-Road 2 04-16-2008 08:32 AM
Pinch too TIGHT! rcfoolz Onroad Nitro Engine Zone 28 03-18-2008 04:41 AM
Tight or loose TC4 DIFF NUCRPTRACER Oval, Larger Scales and More 1 02-12-2007 10:08 PM
tight xxx-s Electric On-Road 6 12-27-2006 11:40 PM
Loose belts ceraf Rookie Zone 4 01-15-2005 09:30 PM
SEO by vBSEO 3.5.0
