Old 11-13-2011, 09:53 PM   #1
Default Cyclone TC Flipped Belts Working Oneway
I'm not sure if this has been discussed, but I was unable to search any information. I figured out how to still get the full fuctionality of the spool/oneway with flipped belts.
I recently purchased a Cyclone TC with exotek chassis and flipped belt setup. It has been bothering me that i could only use the spool or ball diff with the flipped belts. So I went on a little mission to correct this issue. And the process is quite easy to my findings.
All that is needed to use the oneway is to correct the direction of the oneway bearings. You can either press them out, or ruin them, and get new exact replacements pressed in, in the correct direction of course. To my knowlegde hpi uses two manufactures for the oneway bearing. One germany and one japan. I was easily able to locate the german ones inf hf0612
Is this new news? And or i'm I the only one that really likes oneways.
peteyo is offline   Reply With Quote
SEO by vBSEO 3.5.0
