INDI Motor Dyno
INDI dyno
i don't know much about it but a friend i race with is buying one. he's been looking at dynos for several months, the guy does lots of research on products and usually buys the best availible
I have one, and I really think it is worth the price!! It helps you decide changes you do to a motor are better and allows the user to determine which of their motors are better for each particular situation. I also use it to break in motors, and to run my lathe!!! Well hope this helps!!
This is one of the most versatile pieces of equipment on the market...especially considering the price and the size.
Completely variable voltage output from 1-7 volts.
With the adjustable voltage output you can use the Indi Dyno to power slave motors, break in brushes, adjust timing on mod motors (and use the amp draw and rpm), and setup ESC's and servos without the need to charge a battery pack.
STLNLST....THANKS! It was a good run.
