Old 12-06-2004, 10:01 AM   #1
Default need tc4 help
need tc4 help
hey guys give me some setup help.ive got a tc4 and need more on power steering.im happy with the car off power.heres my current setup
shocks outside hole
30 wt oil
2 hole piston
blue spring
4 degree castor blocks
2 degrees kick up
longest camber link holes
inside hole on tower
30 wt oil
gold spring
short camber link
2 degree rear toe block with losi
1 degree blocks on the car backwards
to make the rear toe 1 degree
rear hinge pins level no anti/pro squat
tires are cs27s
the track is medium to high bite asphalt
with a couple of sweepers wher im struggling
any thoughts?
bear is offline   Reply With Quote
Old 12-06-2004, 10:13 AM   #2
dr_hfuhuhurr's Avatar
Trader Rating: 69 (100%+)
Go to the tc4 thread
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 12-06-2004, 11:54 AM   #3
raving-monkey's Avatar
Send a message via MSN to raving-monkey
how many holes on the rear piston?
less holes might help...or smaller holes
raving-monkey is offline   Reply With Quote
SEO by vBSEO 3.5.0
