Old 12-05-2004, 01:55 AM   #1
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default Volt Threshold
Hi all.
just wanting to know what"VOLT THRESHOLD' means.
im new to electric racing and just wanting to make sure im charging right.
i have the ind 16x9 charger.
mike
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 12-05-2004, 10:54 AM   #2
Basically it means how much voltage you can put into a cell(s) before the charge stops. For example, I have an older Tekin BC112c and it has several charge profiles, such as P1 which allows the voltage to cutoff within .03-.05 volts of a full charge. Then, there's the P2 charge which allows the charger to cutoff around .06-.08 volts of a full charge. Those numbers are for the 6 cell pack, not individual cells. The only thing voltage threshold is for is to allow you to tailor the charge to acquire peak performance from a pack. For Ni-Mh batts you might want something with a very low threshold and for Ni-CDs you'd want something a little higher due to the difference in charge methods needed for top performance. Hope this helps without being too difficult to understand.
2BAD4ALL is offline   Reply With Quote
Old 12-05-2004, 11:47 AM   #3
Baja's Avatar
low for NI-Mh like .0008?
Baja is offline   Reply With Quote
Old 12-05-2004, 12:05 PM   #4
adamkerrnz's Avatar
Volt Threshold:
3~20mV/cell for NiCD,
3~15mV/cell for NiMH
adamkerrnz is offline   Reply With Quote
Old 12-05-2004, 02:34 PM   #5
mikecatts's Avatar
Default thanks all
thanks all.ill give it a go
Eagle racing CDC, threshold value set-up FUK_WRX Electric On-Road 0 06-26-2003 07:59 AM
voltage threshold fasterdanu Electric On-Road 5 02-22-2003 12:59 AM
Voltage Threshold? James Nguyen Electric On-Road 4 06-25-2002 02:24 AM
