Old 10-27-2011, 02:43 PM   #1
Default TC4 ...used and abused
so my tc4 should be here in the mail tomorrow
the pictures look great but who knows,,,,,if they are even his pics
Im a newbe and looking for info
what would make this car abused?
what parts should i be looking at first to replace?
do these cars do all right in vta? or should i be looking for something else?
urban is offline   Reply With Quote
Old 10-27-2011, 02:45 PM   #2
Trader Rating: 66 (100%+)
Car can work in VTA. Check the chassis for cracks or splitting along the edges. If you see any, you can seal with CA glue. Check the diffs to make certain they are smooth. Also look at center drive shaft for damage. Bearings may need cleaning or replacing depending on how it was taken care of by previous owner.
nutz4rcyktw is offline   Reply With Quote
Old 10-27-2011, 03:27 PM   #3
check worn outdrives, for minimum play
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 10-27-2011, 03:51 PM   #4
aarivers's Avatar
Trader Rating: 13 (93%+)
The TC4 (and 3 for that matter) is an excellent choice for VTA. I know 1/2 of the fastest guys here run TC4's in VTA. Like olly said check the outdrives for wear, you'll probably want to rebuild the diff's and shocks after you get it. Don't over tighten the front diff when you rebuild it or you'll end up shearing the head off the middle bolt.
Good luck with the new car and let us see some pics once you get it.
USVTA - Schumacher Mi4LP
aarivers is offline   Reply With Quote
Team Associated TC4 Kenshin Electric On-Road 14930 10-18-2016 05:57 AM
LOSI XXX-S, Tips and Tricks, Open Mod, etc John Stranahan Electric On-Road 1027 08-30-2016 07:41 AM
SEO by vBSEO 3.5.0
