Like Tree1Likes
Old 11-18-2015, 02:45 PM   #76
wohoo - finally my first post on RCtech
Let me jump right into it: Is there a trick how to properly mount the pinion on the slim shaft with this brass insert they give you in the kit? The pinion always comes loose with the LRP Vector Micro Motor I'm trying to use. It also has the a slim shaft, so I need to use the insert... I don't get it to keep the pinion fixes though
DonManolo is offline   Reply With Quote
Old 11-18-2015, 04:30 PM   #77
sakadachi's Avatar
Hey welcome Don!
I've not encountered slippage on the Sport Tune380 so I can't say. Your LRP motor is high output (6900kv) so I bet the torque itself just causes it to slip.
I don't need that much power so I use a HobbyKing S2838 motor running 2S. It's 2800kv output and still quite fast running a 15T pinion (much faster than the SportTuned 380 motor, faster than a 21.5T FWD m-chassis). It uses the 3.17mm shaft, so no sleeve adapter needed. And the motor fits without modifying the steering linkage.
4PKS-R, DX4S, EX-5UR: Sabre4WD Mini, SabreFD Mini, M01, M02, M03, M04, M05 (2), M05ProV2, TA05 M-Four, CupRacer, BSR M-Rage, WR02, GF01 (2), CC01 (2), CW01, CR01, DF02, TT02B, TA02, RS4, MicroRS4, MR01, MR03-S (2), MR03VE, DigiQ (7), & more.. Updates of projects I am working on in my profile page.
sakadachi is offline   Reply With Quote
Old 11-18-2015, 11:20 PM   #78
heretic's Avatar
Some people use a piece of antenna tube instead of the brass insert. HTH
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 11-19-2015, 06:54 AM   #79
niznai's Avatar
Use some retaining compound like the one sold by Loctite for retaining bearings on shafts and such.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is online now   Reply With Quote
Old 11-19-2015, 02:27 PM   #80
sakadachi's Avatar
That's a good idea. Is this product removable? Not that I need it, just wondering.
http://www.henkelna.com/industrial/r...unds-14963.htm
Old 11-24-2015, 06:01 AM   #81
sakadachi's Avatar
Got around to making a front upper camber arm for the front. The solid plastic rod was bothering me as the camber setting was too aggressive for my liking even with the longer "A" rod.
I used 2 damper ends with one of the two trimmed off by 1mm, used a 9 or 10mm set screw per side. I now have adjustment from positive camber to the "A" rod length. I'm currently using -0.5 degrees.
Old 11-24-2015, 06:26 AM   #82
niznai's Avatar
Yeah, it's just going to be a little bit more difficult. But it's not going to come loose on its own at any rate.
Team Greasy Weasel
Old 11-24-2015, 06:32 AM   #83
sakadachi's Avatar
Thanks for the info. I'll keep this product in mind if I encounter something like this in the future.
Old 11-29-2015, 09:34 PM   #84
sakadachi's Avatar
Decided to run 55mm Shimizu's instead of the Tamiya D60's. Also lowered the upper deck back to stock height, removed motor fan, lowered body, 3.5mm ride height. Blue springs up front, White (?) stiffest springs on the rear. I also shortened the damper throw.
Very grippy and fast on my track. ..
Little dirty from all the tire dust on the body..
Old 11-30-2015, 07:00 AM   #85
Aitutaki's Avatar
looks very nice
Aitutaki is offline   Reply With Quote
Old 01-14-2017, 09:13 AM   #86
aracefan's Avatar
Trader Rating: 38 (100%+)
Woo-Hoo! Just ordered a TA-05 M-Four. Late night impulse purchase. Couldn't pass it up though as I'm not sure how much longer they would have these in stock at that price. They are going for about $100 more and up on ebay right now. I'm such a Tamiya fanboy.
Looking forward to getting it now!! Will probably be picking your brain sakadachi here in the near future.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
Old 01-14-2017, 12:46 PM   #87
sakadachi's Avatar
Congrats! I love my M-Four.
aracefan likes this.
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 03:10 AM
Four Seasons R/C Racing Hackatack Northwest Racers 6862 09-09-2015 03:46 AM
Tamiya TA05 IFS rcforum Electric On-Road 1132 12-18-2014 05:19 AM
"Tamiya Class" racing...Help me choose - TA05 vs TA05R pgeldz Electric On-Road 84 08-09-2008 09:03 PM
