Old 12-27-2011, 10:44 AM   #91
Originally Posted by Joat View Post
what did you use for upper links, mine are getting sloppy
I used Mugen mbx5 ball links, they seem to stay tight forever, nice and free up & down.
Lazer Guy is offline   Reply With Quote
Old 12-27-2011, 10:54 AM   #92
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
I run Ultra GTP2 with rear PBS suspension much easier to adjust toe in on the fly for more or less traction.
www.snrgraphite.com
SNR Graphite is offline   Reply With Quote
Old 12-27-2011, 01:17 PM   #93
Thank you Steve
Do you set toe by eye at the track or with a setup station ??
Whats the most toe in that you have use ??
Thank you again
Old 01-04-2012, 02:02 PM   #94
Default Did I buy the wrong servo?
Guys,
I've got a servo question for you. I bought the DM-1 Spec e and I went ahead and bought the Hitec HS-7940TH servo. After a little more research, I'm worried that I should have bought the HS-7945TH instead.
HS-7940TH Specs
Speed (6.0V/7.4V): 0.07 / 0.06
Torque oz./in. (6.0V/7.4V): 181 / 222
HS-7945TH Specs
Speed (6.0V/7.4V): 0.12 / 0.10 second @ 60
Torque oz./in. (6.0V/7.4V): 250 / 319
Does the HS-7940TH have enough torque?
Associated RC8Te - MMM 2200kv
OFNA DM-1 Spec e
ml8163 is offline   Reply With Quote
Old 01-05-2012, 04:19 AM   #95
moved!
Huck50 is offline   Reply With Quote
Old 01-05-2012, 04:37 AM   #96
Originally Posted by Vision View Post
Without modifying the chassis the largest pinion I could fit with the 44T spur was 22T. I think you are gonna have to cut the crap out of the chassis to fit that 30T. Got pics of your setup ?
Where is everyone buying their gears,unfortunately Ofna only makes a 17(largest) tooth pinion and a 47(smallest) spur gear,Kimbrough and Robinson don't do any.I am looking for maybe a 22 pinion and 44 spur gear Mod.1Thanks,Huck.
Old 01-06-2012, 08:01 AM   #97
After some sniffin' around,I found Castle Creations carries 5mm bore Mod1 pinions and also Tekno here:http://www.teknorc.com/index.php?cPa...f5bc46b67e,but .Who carries the smaller spur gears in Mod.1? Thanks,Huck
Old 01-06-2012, 07:13 PM   #98
Anyone?
Originally Posted by ml8163 View Post
Guys,
HS-7940TH Specs
HS-7945TH Specs
OFNA DM-1 Spec e
Old 01-07-2012, 10:00 AM   #99
Here are some pictures of my new ride!
OFNA DM-1 Spec e
Old 01-09-2012, 07:07 PM   #100
44t will not work you have to modify the holder.
What were you looking for any suggestion?
What exactly has to be done to the gear holder to accept the smaller 44,45,46 tooth spur gears?. Pics would be great if possible. Thanks,Huck
Old 01-12-2012, 04:56 AM   #101
Hi: I am trying to find out where everyone is aquiring their smaller 44,45,46 spur gears,but seems to be a big secret,lol! Also, can I modify the gear holder with normal household tools,or do I need to use a lathe? Hope someone can help! Thanks,Huck
Old 01-12-2012, 09:29 AM   #102
You would use a mill not a lathe,lathe is for round, mill is for slots and such.
If you had some good files you could enlogate the motor mounting holes and slide the motor away from the spur.
Joat is offline   Reply With Quote
Old 01-12-2012, 10:35 AM   #103
Thanks,but the gear holder that needs to be modified is round,so a lathe is needed or a rotary table for a milling machine,to reduce the diameter of the hub to fit the smaller bore of the 44,45,46 spur gears. Elongating the motor mounting slots won't make any difference as to whether or not the smaller bore of the spur will fit the gear holder.Thanks
Old 01-12-2012, 10:58 AM   #104
Thanks,but the gear holder that needs to be modified is round,so a lathe is needed or a rotary table for a milling machine,to reduce the diameter of the hub to fit the smaller bore of the 44,45,46 spur gears. Elongating the motor mounting slots won't make any difference as to whether or not the smaller bore of the spur will fir the gear holder.Thanks
Sorry thought you said motor mount, yes a lathe for the gear holder, or a rotary table for a mill,I would use a lathe over the mill,Ive done the gtp2 on my lathe no problem, easier to setup then my rotary table on my mill
Old 01-13-2012, 12:55 PM   #105
Which servo is everyone using? I need one for my new DM-1 Spec E car. Tried a Savox SC1232SG and it's too deep and hits the chassis before being tightened down. Thanks,Huck
~1/8 Scale On-Road GT Picture Thread~ Justpassedu Electric On-Road 163 12-30-2015 10:28 AM
