Old 12-09-2011, 07:49 AM   #46
Vision's Avatar
Trader Rating: 38 (98%+)
Ncracer, what kind of track are you running on ?.
6iX, GTP2e, XO-1, DM1-E, ST-R/MP777 GT2 Hybrid, GT2-VE, GT2-E Circuit, Hybrid Vorza, Rampage XB-E, Slash Platinum, tc5R
Vision is offline   Reply With Quote
Old 12-09-2011, 10:56 AM   #47
ncracer409's Avatar
The tracks we race on are on road corse lots of turns with one straight away rest is turns but its a fast track
Serpent 966 nova plus 35
Kyosho gt2
Traxxas kyle busch
Revo 3.3
Mugen mrx4
ncracer409 is offline   Reply With Quote
Old 12-09-2011, 01:15 PM   #48
Vision's Avatar
My setup is a work in progress. 100k in the center diff so and stock oil with red's up front and white springs in the back. I'm looking to do 40k in the front diff and 10k in the rear with the yellow springs up front.
Can the car turn in quick with the 120k you use in the front ?.
Old 12-09-2011, 03:00 PM   #49
ncracer409's Avatar
Just got the single speed done i ended up putting a 27 t pinion and a 42t spur gear yes a 42 its a hpi gear it will fit the holder with a little cutting that the smallest spur gear i could find the part number is 76952 if yall are curious to try it yourselves but it works awsome i am running the ccmm 2200 on 6s
Kyosho gt2
Traxxas kyle busch
Revo 3.3
Mugen mrx4
Old 12-09-2011, 03:03 PM   #50
ncracer409's Avatar
It spools up quick
Kyosho gt2
Traxxas kyle busch
Revo 3.3
Mugen mrx4
Old 12-09-2011, 08:12 PM   #51
Vision's Avatar
That's a nice option, it should be really quick with the 27T and 6s!. I'm working on getting a 40T ofna hyper 9 spur to work. It bolts up to the jammin diff, but the jammin outdrive has too much play, so I will need the hyper 9 outdrive.
Right now I'm using a 44T Kyosho spur, works well since it's plastic.
Old 12-10-2011, 03:30 AM   #52
ncracer409's Avatar
Just ran the car it did very well on the 27t pinion i just put the 30t pinion on gonna try it today
Kyosho gt2
Traxxas kyle busch
Revo 3.3
Mugen mrx4
Old 12-10-2011, 08:02 AM   #53
Vision's Avatar
30T is going to be crazy!.
Old 12-12-2011, 04:14 PM   #54
Just got my carbon chassis from Steve!! its freaking awesome! fit and quality is top notch. Thanks again Steve! has a 25t on right now with plenty of space left! 30t here i come!
rc8e,sc8e,losi 8ight2.0t,1/16 kyle busch, axial exo terra, and dm-1 spec e,traxxas xo-1
gt2 ve race spec audi r8, 1/16 ken block. hpi vorza, kyosho drx ve.
boostin250x is offline   Reply With Quote
Old 12-14-2011, 07:25 AM   #55
Vision's Avatar
Anyone know what the stock shock oil is on the dm1?
Old 12-14-2011, 11:21 AM   #56
FangsCPO's Avatar
The manual states 80wt, front and back.
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 12-14-2011, 06:11 PM   #57
Vision's Avatar
Thanks good to know.
Old 12-17-2011, 04:53 AM   #58
Can someone comment who has this car regarding the front and rear 'play' or looseness at the wheels,particularly at the wheel bearing area. How much play would you say your car has when moving the wheels up and down and side to side. I am almost ready to buy this car,but this bugs me(looseness)...so is it anything to be concerned about? Thanks,Huck
Huck50 is offline   Reply With Quote
Old 12-17-2011, 08:55 AM   #59
Grenade10's Avatar
Trader Rating: 37 (100%+)
I run the nitro version as well as the electric. There is some play at the arms into the bulkheads. You can change the hinge pins to drill rods and ream the arms and blocks to get a perfet fit. Also if needed you can shim the arms tighter than what the kit spacers will do, think thin shims. No play in the bearings. Since it has pivot balls with adjusters in the hunbs, you can tighten them up to the point it will not move.
Just watch how tight you get all of these, as the suspension can/will bind if you get some grit in the suspension. If it starts handling strange, pull apart and clean.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 12-17-2011, 09:10 AM   #60
Thanks...much appreciated.Any companies doing hinge pins for this car,such as STRC?( I e-mailed them)...how about other upgrades for this car? Thanks,Huck
STRC are not doing any pins for the Ofna.
~1/8 Scale On-Road GT Picture Thread~ Justpassedu Electric On-Road 163 12-30-2015 10:28 AM
