Old 03-29-2014, 10:13 PM   #346
JayRC66's Avatar
I got the Ofna DM1 Spec nitro race roller (80% built). I want to convert it to electric. What is the most proficient way to convert it. Will the OFNA 1/8 GTP & Late Model Dirt Oval Electric Conversion Kit work on it? Thanks the help
Jovanny S.
Losi, Serpent, Schumacher, Ofna.... yea I got a little bit everything.
JayRC66 is offline   Reply With Quote
Old 03-30-2014, 09:51 AM   #347
Grenade10's Avatar
Trader Rating: 37 (100%+)
The GTP and Late Model are a totally different design. To do it well, you need the chassis and servo/esc/motor platic mount and the the electric motor mount. All the diff's, suspension and center drive are the same. You might also want to get the center single speed shaft and gear.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 03-30-2014, 05:13 PM   #348
JayRC66's Avatar
Thumbs up
Thanks I will try it out.
Jovanny S.
Old 04-05-2014, 09:18 AM   #349
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
If you going that route you might as well buy my graphite chassis to convert it. It lighter and has a bigger slot for the motor mount for higher
gearing speed run.
www.snrgraphite.com
SNR Graphite is offline   Reply With Quote
Old 04-05-2014, 09:36 AM   #350
Grenade10's Avatar
gearing speed run.
+1 on that conversion.
Old 04-08-2014, 11:34 AM   #351
Grenade10's Avatar
Default Ferrari Body
This will NOT fit either the DM-1 or GTP but if you have a long wheel base Kyosho or Team-C, OFNA V2 car it is a perfect fit.
GT-8 Nitro / Electric Ferrari Body
Old 04-20-2014, 01:09 AM   #352
koval's Avatar
Default Ofna dm-1 110mph+ castle 1717 motor mount
Hello from greece,
i have seen many people during the past years converting dm-1's for high speed passes ,problem as everybody knows is that we cant gear up our dm-1's with the stock motor mount .
This is a motor mount that i made especially for the castle 1717 bl motor and huge pinion gears up to 40t.
I also made another motor mount for 1/8 type motors like leopard 40 series or castle 1515
In the next days there ll be ready a battery tray for 8s lipo and hv esc's like castle xl2 .
This motor mount can be placed so as the motor is faced to the front or in the rear side of the car without any modifications .
Any suggestions for the battery trays will be helpfull cause i ve made some prototypes but the final product is not ready yet ,think that a double side battery trays backwards and the motor attached to the front will be identical especially for the 1/7 dm-1 .
More details of the conversion at http://brushlessmaniac.blogspot.gr/2...brushless.html
koval is offline   Reply With Quote
Old 04-20-2014, 12:20 PM   #353
ViperZ's Avatar
What bodies is everyone running on their DM-1 Spec Electrics?
I have a the Ofna X3 and wonder how well it fits the DM-1e
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 04-20-2014, 01:58 PM   #354
Grenade10's Avatar
Should work as I just put a OFNA McLaren on an X3. I have not run the new body yet, as I'm doing some comparison and needed to keep the body the same. I think the new body looks great, but aero dynamic should be also good.
Old 04-20-2014, 03:14 PM   #355
ViperZ's Avatar
I was asking as I don't own a DM-1. I have a TRX Rally GT8 conversion running the Ofna DP8 body (McLaren) and it just fits. I had to use lower shock towers from a XO-1 to allow the DP8 body to sit at the right height.
A fellow forum member is running a similar Rally GT8 setup and is extensively modifying his rear towers to clear the X3 body. He use to run the DP8 body with no issues, but is needing to get even lower to fit the X3.
My thoughts were to maybe pick up a DM-1 for this X3 body, but I would like to know if it fits first. The X3 chassis maybe lower thus fitment of the DP8 would not be an issue, however vice verse could be...
Old 04-20-2014, 07:05 PM   #356
Grenade10's Avatar
Today I don't have the total answer today, but rear is similar. I put the DM1 rear body mount on the X3, to help support the DP8 body. X3 is off the shock tower, and wider than the DM1. Front with stand up shocks is only one hole lower with the X3 body. However, the windshield is back farther, and not sure if it will clear the fuel tank. Should know that answer after the Novarossi thus next weekend.
Old 04-20-2014, 08:18 PM   #357
ViperZ's Avatar
Okay, that's good to know.. I'm in no real hurry, so can wait for the final answer
Thanks!
Koval, I'm very interested in those motor mounts you are making. I need to do a bit more research regarding what will fit. Thanks!
Old 04-20-2014, 10:18 PM   #358
FLoJo's Avatar
You can run just bout any body that is gt1 size 325-330mm on dm1 , I don't see why the x3 wouldn't work on dm1 seeing as it has lay down shocks , all body's from kyosho inferno nitro gt1 fit dm1 also if u can find any
KYoSHo iNFeRNo GT1-E RCMoNSTeR CaSTLe2200 <> KYoSHo iNFeRNo GT2Ve Tekin 2650
oFNa LM DO CaRBoNFiBeR CaSTLe2650 <> TC4 FT
ZDRaCiNG TRuGGy <> HPI NiTRo RS4 .21oS
PRoBoaT STiLeTTo <>TRaXXaS SPaRTaN
FLoJo is offline   Reply With Quote
Old 04-20-2014, 10:43 PM   #359
ViperZ's Avatar
Just wanting to be sure is all, It seems the laydown shocks would actually be taller in overall height than a uprights up front (but I'm just speculating), and I was wondering about the back clearance as well as I had indicated.
Thanks!
Old 04-20-2014, 11:06 PM   #360
Suspended
just see some website have the newest ofna X3E RTR,including servo,mootr,esc,remote-controller and receiver battery.
any one knows where can i got it ?
POLE is offline   Reply With Quote
~1/8 Scale On-Road GT Picture Thread~ Justpassedu Electric On-Road 163 12-30-2015 10:28 AM
