Old 01-09-2013, 05:35 PM   #286
dangerwr's Avatar
I have seen photos of a carbon chassis for this car here on RCTech. Any idea where I could find one?
Losi 8ight 2.0 EP - MMM & Tekin 1900Kv
Losi 8ight-T 2.0 EP - MMM & Tekin 1550Kv
Durango DEX410 - Orion R10 Pro & 8.5T
TLR 22 - Orion R10 Pro & 13.5T
dangerwr is offline   Reply With Quote
Old 01-09-2013, 05:37 PM   #287
Monteman's Avatar
Trader Rating: 16 (100%+)
The only "other" chassis I personally have seen for them is the SNR graphite.
Didn't know there was a carbon option out there.
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 01-12-2013, 08:53 AM   #288
Can someone post a link of which velcro strap from tower would accommodate two 3s lipo's. Would the one from Associated work?
ducatiti is offline   Reply With Quote
Old 01-24-2013, 07:10 AM   #289
How do you get a 1:1 gear ratio?
I purchased a 44t spur gear to realize it doesn't fit the gear holder.
Even if you mod the aluminum spool to fit the smaller spur the center bore is larger than it needs to be so you have to be perfect otherwise it'll end up out of center.
Where can I find a spur with a smaller center bore? Ill use the count sunk holes to screw into the spur to stop it from rotating freely.
Also is there a way to relocate the motor to the front driver side to accommodate two packs?
speedyb4 is offline   Reply With Quote
Old 01-24-2013, 07:55 AM   #290
Monteman's Avatar
Check out the center spool options over at RcMonster, might have what you are looking for.
Old 01-24-2013, 10:02 AM   #291
Thanks. What size is the shaft the spool goes on between the eclips?
I found some spurs and pinions in all different sizes teeth count bore sizes. Also made of different materials. Steel. Stainless. Aluminum. Haven't checked if there is plastic
Essentially the spur design for this car is a pinion as it has a set screw to lock into place.
These could work if you want to get down to a 19t spur and a 46t pinion. I just don't know the diameter of the shaft.
Old 01-25-2013, 09:43 AM   #292
you need the single speed conversion with 8mm for revo spur from monsterrc
then you get this one
HPI racing Vorza Flux on 6s , Ofna GTPe2 Ultra 100MPH speedrunner , Merv with BB and MMP
Mosf3t is offline   Reply With Quote
Old 01-29-2013, 06:01 PM   #293
Here's something to look at.
D8T Tekno V4
Inferno GT2 VE
CobraWasHere is offline   Reply With Quote
Old 01-29-2013, 06:25 PM   #294
FangsCPO's Avatar
Looks great but you need a wing or else it will have horrible traction in the back. You need that down force pressure the rear wing creates. Unless she's going to be a shelf queen than it's no big deal. Just my .02.
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 01-29-2013, 07:50 PM   #295
The wing has just not been painted yet.
D8T Tekno V4
Inferno GT2 VE
Old 01-29-2013, 09:26 PM   #296
Monteman's Avatar
Very NICE!!!
Old 01-30-2013, 02:36 AM   #297
Trader Rating: 45 (98%+)
At first I was like how did you make the that IGT2 fit our DM-1 Spec E chassis...until I saw your rc-monster tray and your signature....this is primarily a OFNA DM-1 Spec E thread
alexchen86 is offline   Reply With Quote
Old 01-30-2013, 06:09 AM   #298
Hey I see you're from Houston. Are there GT races in Houston?
D8T Tekno V4
Inferno GT2 VE
Old 01-30-2013, 01:34 PM   #299
There are every now and then at Mike's Hobby Shop in Porter, TX. They used to run Inferno GT1 and GT2 nitro....then heard about people running OFNA's and electric conversions. No official race class as far as I know. I spoke with the manager of that track who used to be at Mike's for about 12 years.
If you're down to run 1/8 GT on-road maybe like a little shakedown run at Mike's PM me! I just built my OFNA DM-1 Spec E with parts I had laying around.
Running stock gearing...MMM/2200kv...Sweep 55 shores hard compound....7955TG...and really that's about it. Just moved my ebuggy stuff over. I don't think I even have a CC BEC on it lol.
Do you have any off road rigs too we can go out on a weekend and just do some runs on and off road!
Hit me up
Alex 832-461-6399
Old 01-30-2013, 04:57 PM   #300
I'm so jealous of you Ofna guys getting to run a rear diffuser. I wonder what it would take to fit one to my IGT2...
D8T Tekno V4
Inferno GT2 VE
~1/8 Scale On-Road GT Picture Thread~ Justpassedu Electric On-Road 163 12-30-2015 10:28 AM
