Old 06-08-2012, 09:09 AM   #196
Monteman's Avatar
Trader Rating: 16 (100%+)
reducing EPA was my plan of attack, just didnt know how far i could go without crippling the steering. i was down to 75% last night and they would still chatter.
Curious if it is a design flaw on the carrier, there is almost zero play when the wheels are straight, but you pass that point in steering and the top pillow ball goes loose.
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 06-11-2012, 02:09 PM   #197
Default sway bar upgrade
Hi everyone,
does anyone know if the OFNA GPX4 22160 ALUM. CNC FR ANTI-ROLL BAR a direct replacement for the plastic 40719 on the ofna dm1 spec car?
jahno30 is offline   Reply With Quote
Old 06-11-2012, 09:27 PM   #198
asc6000's Avatar
Trader Rating: 15 (100%+)
those body posts need to go, flush mount buttonheads screw em on
Originally Posted by PlayingDirty View Post
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 06-12-2012, 06:08 AM   #199
Grenade10's Avatar
Trader Rating: 37 (100%+)
Spare Chassis and other parts for a DM1 Electric or all the parts to convert a nitro car to electric!!
http://www.ebay.com/itm/140766290171...84.m1555.l2649
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 06-18-2012, 04:08 AM   #200
jayjay283's Avatar
as Ice Cube said " it was a good day"
jayjay283 is offline   Reply With Quote
Old 06-18-2012, 09:32 AM   #201
Originally Posted by jahno30 View Post
Hi everyone,
The GPX 4 is a 1/10 scale and will not fit.
You may want to try :
http://www.ybslowinc.com/
He makes one off items and also some parts for DM-1
D Starks is offline   Reply With Quote
Old 06-28-2012, 12:18 PM   #202
ybslowinc.com
Thanks, I just sent them an E-mail
Old 07-03-2012, 08:37 AM   #203
wrong17's Avatar
Trader Rating: 107 (100%+)
After have lots of problem keeping the DM1 on the ground while going over 90mph. I came up with an idea of sealing bottom of the car by making a cover with a pegboard. I guess you can say it's more like a borrowed idea from Traxxas' X0-1. I wanted to test out this concept before I make a better version of it. To make a long story short, it really works. The DM1 was a lot more stable at high speeds. I guess this mod it not too bad for an hours worth of work.
I put the car over the wooden pegboard and traced the chassis on to the board so I will know where to cut.
Afer a few rough cuts, here is what I came up with.
Test fit the cover on the car, and it seems to fits okay. The board is held on with 4 cable-ties on each arm of the car. Then I duct tape the board to the chassis and covered all the holes with painters tape
After a few runs, this is how it looks.
Here is a video of the car with the lower chassis cover. It was was not at full speed when it past the radar gun. I tried to do a second pass but hit a reflector on the ground and crashed.
+ YouTube Video
http://mytoyz.wrong17.com
wrong17 is offline   Reply With Quote
Old 07-03-2012, 09:10 AM   #204
dasrustler's Avatar
Trader Rating: 35 (100%+)
Nicely done
Losi 5ive 2028 MGM Compro 400A 80.9MPH |FG 4WD Brushless MGM 250A 107MPH
Savage XL MMM 1800KV | LST2 Mamba Monster 1600KV
Muggy Mamba XL 1717 | | GTP2E MMM 2200KV 123MPH
SCX10 Defender| Losi 8ight 2e 106MPH | HT-FPV NAZA GPS
dasrustler is offline   Reply With Quote
Old 07-18-2012, 05:16 PM   #205
Trader Rating: 45 (98%+)
Smile New Owner!!
I just ordered a DM-1 Spec E after talking to a buddy trying to decide over that one or the GTP2e. He said I'd be better off with the DM-1 as he said it's more durable. I only plan on parking lot/empty street runs with a few trips to our 1/8 on-road circuit.
However the terrain mostly will not be clean for parking lots. There will of course be little pebbles, leaves, dirt, and rocks.
I have a spare MMM/2200kv combo laying around I plan on using along with a Hitec 7954SH (.12 sec 433oz/in @ 7.4V). Would this servo be okay or too slow? I come from rock crawling so all the servos I have are all over 300 oz/in. and none have a transit time of under .12 sec. I will probably need a CC BEC too right?
Any upgrades I should get right off the bat to make it stronger?
alexchen86 is offline   Reply With Quote
Old 07-21-2012, 11:49 PM   #206
FangsCPO's Avatar
Does anyone know who else caries 1/8 scale on-road lids for these GT8s? IGT Hobbies doesn't have much of anything. Any other supplier out there??
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 07-22-2012, 12:07 AM   #207
If out if stock just order it, normally takes less the a week for them to get it
Joat is offline   Reply With Quote
Old 07-24-2012, 03:52 PM   #208
I'm the new proud owner of a DM-1 Spec E!! Not bad $229 shipped off tower. I plan on either purchasing a new MMM 2200kv combo or pulling it off my Rc8Be...
Running gear:
MMM 2200kv on 4s
Hitec 7954SH
Question is do I need a CC BEC? I plan on only 90% parking lot bashing with occasional practice runs at our 1/8 on-road track which is about 30 min away.
Of course the unboxing!! Man that is a sexy chassis and motor mount not to mention the sweet big bores are rear diffuser!!
Anything I need to upgrade right off the bat?
Old 08-05-2012, 01:17 PM   #209
Bmr4life's Avatar
Trader Rating: 50 (100%+)
Can anyone explain how the motor mount is adjusted? Is the pinion range wide?
Too many RC's to list.
Bmr4life is offline   Reply With Quote
Old 08-05-2012, 08:15 PM   #210
FLoJo's Avatar
I beleive you adjust by the screws on bottom of chassis but I could be wrong, think you can go upto 24 tooth pinion IIRC
KYoSHo iNFeRNo GT1-E RCMoNSTeR CaSTLe2200 <> KYoSHo iNFeRNo GT2Ve Tekin 2650
oFNa LM DO CaRBoNFiBeR CaSTLe2650 <> TC4 FT
ZDRaCiNG TRuGGy <> HPI NiTRo RS4 .21oS
PRoBoaT STiLeTTo <>TRaXXaS SPaRTaN
FLoJo is offline   Reply With Quote
~1/8 Scale On-Road GT Picture Thread~ Justpassedu Electric On-Road 163 12-30-2015 10:28 AM
