Old 05-13-2012, 03:58 AM   #181
Quick question. Would the techno conversion to electric be a better choice than the standard stock electric kit? Reason I ask is because the nitro powered has the 2 speed...or can you simply run the 2 speed on an electric with or without mods?
Looking for the highest speeds possible.
Also, I see that Tekno doesn't offer the DM1 electric conversion anymore. Any word on this?
DFoxx is offline   Reply With Quote
Old 05-13-2012, 07:40 AM   #182
jayjay283's Avatar
the teckno kits cool but you will have a hard time hunting one down, That was pre dm-1 espec. you can buy the 2 speed slap it in and rc-monster makes a 2 speed 5mm shaft adapter and the gears for the motor.
heres something I posted in another thread may be of some use
mike @ rc-monster.com makes a single speed adapter for it you can use down to a 34 t revo spur (or whatever the smallest for the nitro revo) you go to http://www.rc-monster.com/rcm.php?pg=4 and order the 8mm and specify in the notes when you check out that its the traxxas revo spur edition. Good luck with the speed runs
You can fit the 46t ofna 2nd gear spur and a 19 tooth pinion stock im hitting 50+ with 4s and a 2700 kv motor
Mike @ rc monster also makes a dm-1 motor mount that would give more pinion options. The dm-1 mount is for the 1/7th but they are the same for 1/8th spec
jayjay283 is offline   Reply With Quote
Old 05-25-2012, 01:18 PM   #183
Just wanted to share my DM1 built for a high speed oval.. Don't be too harsh!
castle 2200 MMM esc
running 25-43 gearing
PlayingDirty is offline   Reply With Quote
Old 05-25-2012, 02:45 PM   #184
jayjay283's Avatar
looks cool , is that the front diffuser thing off a xo-1 ?
Old 05-25-2012, 03:13 PM   #185
Yes, it helps tremendously, the straight behind the car is a bit bumpy coming out of the turn so a lot of the 1/8 cars go air born. It flipped and slid on the roof on one of my test runs, but after installing the diffuser, it worked wonders.
Old 05-25-2012, 03:44 PM   #186
Justpassedu's Avatar
Trader Rating: 115 (100%+)
castle 2200 MMM esc
Looks nice man , looks like that's the velodrome in kissena park queens , I think I saw you running the car there Sunday .
Mugen Mbx6 Eco
Justpassedu is offline   Reply With Quote
Old 05-25-2012, 09:40 PM   #187
Thanks! Yup, I was there on Sunday. I was having a few issues with it that day, but I think I sorted the bugs out.
Old 05-25-2012, 09:43 PM   #188
Monteman's Avatar
Trader Rating: 16 (100%+)
any details on how exactly you mounted the XO-1 diffuser on there? That looks sick.
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 05-26-2012, 11:39 AM   #189
3 button head screws going through the plastic bumper under the foam. I'll post a picture later.
Old 05-26-2012, 12:30 PM   #190
Monteman's Avatar
That would be awesome. I kept looking at the front splitter on the Xo-1 wondering if it would work on the DM1, sure looks cool
Old 06-02-2012, 11:18 AM   #191
Monteman's Avatar
Do the mount holes already in the XO-1 splitter line up properly with the DM1 plastic bumper? Or is it new holes all together?
Looks like you are running the DM1 1/7 wing out back too ?
Old 06-03-2012, 07:12 AM   #192
Grenade10's Avatar
Trader Rating: 37 (100%+)
Here is a complete conversion for a DM1 from Nitro to Electric .....
http://www.ebay.com/itm/OFNA-DM1-Ele...item20c65320fb
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 06-03-2012, 05:51 PM   #193
Monteman's Avatar
Ok so i finally had a chance to get out and drive this guy. Noticed something right off the bat, it chatters hardcore in the front steering.
Brought it back inside and even on the bench stand under throttle when i turn either way it goes so far and then chatters a ton, now i thought it was a tire rub, so i took off the front tires and repeated the test and it was considerably less, but still there. i reinstalled the wheels and i cannot see anywhere where they rub...
Even at full turn there is no rubbing going on, if the wheels are straight there is no extra noise or chatter at all but i get to (if i had to guess) about 70% of the turn either way and the car just starts vibrating but i cannot find anything rubbing.
Has anyone run across this?
I'll try to post a video of whats going on to help with the diagnosis.
One thing i did notice after posting this is at full turn the pillow balls get really loose in the pockets. Is there a fix for this or do i just take a bunch of steering throw out and deal with it?
Old 06-06-2012, 10:54 AM   #194
Monteman's Avatar
Anyone else seen this pillow ball slop?
Old 06-07-2012, 11:08 PM   #195
jayjay283's Avatar
mine did that as well, I put in a savox 1258 and it wanted to turn almost 90 degrees thrashing and making bad noises (wheels, cvds?) I have the steering epa set at 60%, its more than plenty and doesnt make that noise. I figured it was the CVD and needed to wear in a bit. I havent driven it much due to a nice full speed crash into a curb (beer). I'll look at the pillow balls soon I need to readjust everything now
~1/8 Scale On-Road GT Picture Thread~ Justpassedu Electric On-Road 163 12-30-2015 10:28 AM
