Old 02-27-2012, 07:46 AM   #136
Thumbs up HK 2560kv
has anyone tried the Hobbyking 2650kv version?
I hear that motor has more poles than the castle version and gives more torque and runs cooler....
and about 55bucks!
brushless55 is offline   Reply With Quote
Old 02-27-2012, 06:59 PM   #137
and about 55bucks!
I have not. I am a firm believer in that you get what you pay for.
Associated RC8Te - MMM 2200kv
OFNA DM-1 Spec e
ml8163 is offline   Reply With Quote
Old 03-20-2012, 12:41 AM   #138
wrong17's Avatar
Trader Rating: 107 (100%+)
Does anyone know if the IPANEMA Wide 49mm tires will fit on the front of a DM1 Spec e? I know it will fit in the front but not sure would it be okay for the front too.
thanks!
http://mytoyz.wrong17.com
wrong17 is offline   Reply With Quote
Old 03-24-2012, 05:17 AM   #139
Default How fast for a Ofna DM-1 Spec e car
Just curious as to how fast my Ofna DM-1 Spec e car should theoretically go with the following equipment: Castle 2200kv motor combo,Thunder Power 6s 6600 mAh 65c battery,Sweep EXP belted tires,stock gearing(13/49).generally speaking?! Thanks.
Huck50 is offline   Reply With Quote
Old 03-24-2012, 05:20 AM   #140
thanks!
Maybe if you re-wrote your post,you may get more responses,as it is now,very confusing. I THINK I know what you are asking,but not 100% sure. Thanks
Old 03-24-2012, 12:44 PM   #141
Monteman's Avatar
Trader Rating: 16 (100%+)
http://www.scriptasylum.com/rc_speed/top_speed.html
i use this for tinkering with gearings and so on.
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 03-26-2012, 04:11 AM   #142
Thanks, I used that for my Rustler to figure out how fast it's capable of.but not sure what numbers to punch in for differential gear ratio,transmission gear ratio for the Ofna? Can I use Ofna Ultra GP drop down values?....maybe they are the same for my DM-1?
I get 46.61 mph.....that seems a little low?!??Thanks.
Old 04-02-2012, 06:26 PM   #143
Trader Rating: 18 (100%+)
i was wondering were i can find some aluminum a arm hinge pin holders? i saw them on igt but there out of stock. any help would be greatly appreciated
ebomb is offline   Reply With Quote
Old 04-02-2012, 10:51 PM   #144
RC Passion's Avatar
Try www.maxvelocityracing.com
They add weight but they are rock solid!
RC Passion is offline   Reply With Quote
Old 04-03-2012, 01:34 AM   #145
kcunamay's Avatar
Trader Rating: 20 (100%+)
thanks!
If you're asking if they will fit on the front, the answer is yes. However you won't be able to turn as your wheels will scrub.
Jai Cunamay - Racing 1 class sucks.
kcunamay is offline   Reply With Quote
Old 04-03-2012, 11:55 AM   #146
LOL..
I know someone who is running the HK2560kv 6 pole motor in his EMaxx and says it out runs the CC1512 2650kv motor he had in it.. plus it runs cooler and uses less amps
Old 04-03-2012, 02:00 PM   #147
jayjay283's Avatar
Nothing wrong with HK stuff or teying to save a buck, but when/if it blows you are done. No sending it to castle and get a new one for $50 repair fee. Also a 1512 is too small for an Emaxx,
jayjay283 is offline   Reply With Quote
Old 04-06-2012, 11:52 AM   #148
so after running my new dm1 e , i have to say I'm pretty happy overall with it. i was a little skeptical at first, i had to ditch the stock tires and rims cause i blew the foams out. but i pick up a set of sweep pre mounts and the car handles decent. was wonder what everybody is doing to these cars? as in setup or hop ups?
Old 04-06-2012, 12:50 PM   #149
Just curious as to what you are using for a motor combo and battery. Have you tried different gearing yet,other than stock(13/49)? Thanks,Huck50
Old 04-07-2012, 05:52 AM   #150
I'm using a castle 2200kv w/mmm running a gens ace 5s ,17/49 soon to drop spur to a 47t
~1/8 Scale On-Road GT Picture Thread~ Justpassedu Electric On-Road 163 12-30-2015 10:28 AM
