Old 06-05-2002, 06:07 AM   #16
lem2's Avatar
Default Thanks!!!
for that wonderful tip!!!!!
lem2 is offline   Reply With Quote
Old 06-05-2002, 07:11 AM   #17
Tech Legend
Wild Cherry's Avatar
Motor spray.....
On rubber, soak for 5 minutes than grip....
Motor spray dries out the rubber so the tire will absorb more grip & get softer....
Wild Cherry is offline   Reply With Quote
Old 06-05-2002, 09:53 PM   #18
Post
Ian S:
What I've done is first clean the tires off with some motor spray and wipe clean with towel. Spray WD40 onto the towel and then wipe on the tires till you see that it is slightly wet and let it sit for about 15-20 min. Wipe off any remaining residue/WD40 from the tires and you are ready to run. **If you touch the tires, you will notice that the rubber is very soft and sticky.
Update:
I've recently done some more testing comparing it to Paragon's FX2 traction compound and again the WD40 felt much better. Actually the FX2 was very similar to Ground Effects as far as traction. Not sure if there is a difference in the formula they used. Does anyone know?
BTW, if anyone has any knowledge of the difference formulas used for the popular traction compounds out in the market, I'd really appreciate if you can share it with us.
G-spec is offline   Reply With Quote
Old 06-06-2002, 09:14 AM   #19
Tech Legend
I believe WD-40 is mainly made of disel.......
I havent heard anyone try Trinity`s Death Grip...
It blows alway the WD-40....
Of course Death grip works even better if you soak your tires for 5 minutes with motor spray....( try it)
Old 06-06-2002, 09:54 AM   #20
actually i tried another way from my last post here... MotorSpray on rag wiping tires clean wait 2 min then apply GroundEffects to tires wait 2 min then wipe off with rag that got very tacky once wiped... this is my other .02
Chris@WeaponR is offline   Reply With Quote
Old 06-07-2002, 05:37 PM   #21
The WD-40 trick is a thing that oval guys started on capped oval tires on concreet (sp) to help them soften up a bit so we can get the tire clean of all the blistered rubber, I have used it with much luck. At the norrca paved oval nats that happened 2 weeks ago it was brought to my attention that a new tire cleaner and traction additive was being used, it is called Stick-ET and id did wondres for cleaning the tires as well as increasing the traction. Just thought that some of you on-road guys might want to try. I dont know where to get it except the shop in bakersfield, showtime.
JPHRacer is offline   Reply With Quote
Old 06-11-2002, 03:18 AM   #22
ttr
ttr's Avatar
WD is not diesel, so do not try diesel oil on your tires. WD 40 is kerozene, with other words simple jet-fuel. So you can get it for cheap at an airport. Sadly the most effective tire cleaner and traction compound what is toluol with other words methylbenzene (C6H5CH3) is extremely flammable and highly dangerous if swallowed. Some serious guys use it at us, and it works pretty fast and gives a long lasting high traction even in winter.
ttr is offline   Reply With Quote
Old 06-11-2002, 12:25 PM   #23
I tell you what. WD-40 is great when your skint!
XXXS is offline   Reply With Quote
Old 06-11-2002, 01:08 PM   #24
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
ttr- Do you mean tolulene or tulenol? I've never heardof toluol, but that doean't mean you're not right....
BigDogRacing is offline   Reply With Quote
Old 06-11-2002, 01:36 PM   #25
Peter Busch's Avatar
is that what the old Paragon had in it.
Peter Busch is offline   Reply With Quote
Old 06-11-2002, 05:47 PM   #26
ttr
ttr's Avatar
Oh sorry, in english the correct name for it is toluene.
Old 06-13-2002, 10:20 PM   #27
Dragon's Avatar
Send a message via ICQ to Dragon
The first time i used my team orion street juice, i thought it smelled like insecticide.....
Dragon is offline   Reply With Quote
Old 06-23-2002, 04:49 PM   #28
skibum989's Avatar
wait a minute, you mean toulene mixed with methylbenzine is the best traction additive? that sounds dangerous...
skibum989 is offline   Reply With Quote
Old 06-23-2002, 07:01 PM   #29
shrekair's Avatar
Trader Rating: 9 (91%+)
WD-40 is a penetrant. it soaks in and opens up the pores in the rubber. bigger pores = softer rubber.
another traction additive that will actually soften the rubber go to ur local paint supply store and buy zylene and tolulene mix it 50/50. this may be a little stong so when u apply it put a little on a rag and wipe in on via the rag then race no more wipe needed.
shrekair is offline   Reply With Quote
Old 06-24-2002, 05:20 AM   #30
Jimmyd's Avatar
Default wd 40 on foams
I tried it on different types of foam with varying results.
On standard foams (green, blue etc.)it worked fairly well. Almost as good as sunscreen. takes some time for the foam to absorb the Wd 40It will also restore some of the suppleness on dried out foams.
On foams with rubber content (pink, purple, magenta etc) its excellent. Feels very grippy shortly after applying but not actually sticky which is a good thing.
Anyone else used them on foam? Lets hear from you
Jimmyd is offline   Reply With Quote
Track surface traction additive? racenut123 Electric On-Road 18 09-23-2009 03:08 AM
Gearing for Traction/Slipper for Traction RCRat Electric Off-Road 2 08-27-2008 02:55 AM
TRACTION ADDITIVE mazmo Australian Racing 9 07-16-2007 08:04 PM
Ralph Burch TQ's Nats Warm-up using Black Magic traction additive Black Magic Electric On-Road 52 05-02-2006 06:30 AM
Anyone use Z-Max Additive???? SpeedChair Electric Off-Road 0 01-27-2004 07:26 PM
